Why Can't My Computer Do Simple Arithmetic? - Comments
In summary: I remember the day I finally got a program to print out the Fibonacci sequence on a terminal. It was a relief!Thanks for the memories.
  • #36
Jarvis323 said:
It's not a problem with the standard, it's a limitation of how accurate you can represent arbitrary floating point numbers (no matter the representation). I believe that the common implementations can exactly represent powers of 2 correct?
If the fractional part is the sum of negative powers of 2, and the smallest power of 2 can be represented in the mantissa, then yes, the representation is exact. So, for example, 7/8 = 1/2 + 1/4 + 1/8 is represented exactly.
Technology news on Phys.org
  • #37
The simplest example of a malfunction I can think of is 1/3+1/3+1/3=0.99999999. The main thing I remember from way back when (in my early teens) was that my computer had 8 decimal digits similar to a calculator, and the exponential 10 times for the number of decimal places followed by "E". The oddity that sticks out is that I remember trying to comprehend a 5 byte scheme that it used.
But regardless you have to compromise in some direction giving up speed in favor of accuracy or does the library system "skim" through easier values to increase efficiency? (I mean the newest system(s)) I'm guessing there are different implementations of the newest standards? I'm almost clueless how it works!
Another is sine tables, had to devise my own system to increase precision there, too! (nevermind found this:)
"The standard also includes extensive recommendations for advanced exception handling, additional operations (such as trigonometric functions), expression evaluation, and for achieving reproducible results."
from here: https://en.wikipedia.org/wiki/IEEE_floating_point
  • #38
Mathematica does rational arithmetic, so it gets it exact: Sum[1/10,{i,10} ] = 1
  • #39
Mathematica is written in Wolfram Language, C/C++ and Java.
As the link states, Wolfram only deals with symbolic computation, functional programming, and rule-based programming. So arithmetic and other computational math problem solvers are computed and handled in C or C++, whose main aim is also to boost the software performance.
PHP:
float a = 1.0 / 10;
    float sum = 0;
    for (int i = 0; i < 10; i++)
        sum += a;
    std::cout << sum << std::endl;//Output 1
  • #40
Silicon Waffle said:
Until now, nothing I could find in the C and C++ standard libraries can do correct computation with floats. I don't understand why the committee have done nothing about this even though there are already external libraries to do this, some of which are for free online.
What, exactly, do you mean by "correct computation with floats"?
Strictly speaking, no computer can ever do correct computations with the reals. The number of things a Turing machine (which has infinite memory) can do is limited by various theories of computation. On the other hand, almost all of the real numbers are not computable. The best that can be done with a Turing machine is to represent the computable numbers. The best that can be done with a realistic computer (which has finite memory and a finite amount of time in which to perform computations) is to represent a finite subset of the computable numbers.
As for why the C and C++ committees haven't made an arbitrary precision this part of the standard,
YAGNI: You Ain't Gonna Need It.
Likes Silicon Waffle
  • #41
Mathematica is an implementation of the Wolfram Language. It's not written in the language it implements.
Depending on how you enter an expression, Mathematica may use machine representation of numbers. For example, if you enter Sum[0.1, {i, 1, 10}] - 1 into Mathematica, you'll get , but if you enter the sum the way Mark did, Sum[1/10, {i, 1, 10}] - 1, the result will be 0.
  • #42
I assume the symbols you enter e.g "Sum[...]" is manipulated by Wolfram which will call its already implemented methods done in C/C++ to compute the "sum" as requested. The result will be sent back to Wolfram to be displayed as an output.
  • #43
That wouldn't necessarily imply that the C/C++ code is using primitive floating point types. I don't know about Wolfram, but I think a good Math package would allow you to choose.
  • #44
Early computers used BCD (binary coded decimal), including the first digital computer, the Eniac. IBM 1400 series were also decimal based. IBM mainframes since the 360 include support for variable length fixed point BCD, and variable length BCD (packed or unpacked) is a native type in COBOL. Intel processors have just enough support for BCD instructions to allow programs to work with variable length BCD fields (the software would have to take care of fixed point issues).
As for binary floating point compares, APL (A Programming Language), created in the 1960's, has a program adjustable "fuzz" variable used to set the compare tolerance for floating point "equal".
There are fractional libraries that represent rational numbers as integer fractions, maintaining separate values for the numerator and denominator . Some calculators include fractional support. Finding common divisors to reduce the fractions after an operation is probably done using Euclid algorithm, so this type of math is significantly slower.
  • #46
Possibly it can, I am trying to figure out just what your question is about. If it is a PC( maybe a MAC also) then click the START button in the lower left, then ALL PROGRAMS, next ACCESSORIES and there should be a "Calculator" choice. Within it a choice probably called VIEW will show several different models of hand calculators that you click thru to run.
  • #47
You missed the point of my article, which is this -- if you write a program in one of many programming languages (such as C or its derivative languages, or Fortran, or whatever) to do some simple arithmetic, you are likely to get an answer that is a little off. It doesn't matter whether you use a PC or a Mac. The article discusses why this happens, based on the way that floating point numbers are stored in the computer's memory.
