- 4,436
- 3,234
- TL;DR Summary
- Why can't the US make auto microprocessor chips?
Why can't these companies make auto microprocessor chips?
Sure they would be able to, but for a new CPU to appear in actual (automotive) production takes some years (an by that time the actual shortage is supposed to end).dlgoff said:Why can't these companies make auto microprocessor chips?
HopefullyRive said:... by that time the actual shortage is supposed to end
Wow, that article lists very many reasons. The one reason that surprised me was this:Filip Larsen said:Arstechnica (via wired.com) had a piece on that recently: https://arstechnica.com/gadgets/2021/11/why-the-chip-shortage-drags-on-and-on-and-on/
At the same time, US-imposed sanctions on Chinese companies like Huawei, a leading manufacturer of smartphones and networking gear, prompted some Chinese firms to begin hoarding as much supply as possible.
Thanks Filip. Very informative.Filip Larsen said:Arstechnica (via wired.com) had a piece on that recently: https://arstechnica.com/gadgets/2021/11/why-the-chip-shortage-drags-on-and-on-and-on/
Wow is right. Thanks for that link: https://www.wired.co.uk/article/china-microchip-autonomy-huaweianorlunda said:Wow, that article lists very many reasons. The one reason that surprised me was this:
A surge in demand for various chips is causing shortages for select 200mm foundry capacity as well as 200mm fab equipment, and it shows no signs of abating in 2021.
Foundry customers will face a shortfall of 200mm capacity at select foundries at least in the first half of 2021, and perhaps beyond. Those customers will need to plan ahead to ensure they obtain enough 200mm capacity in 2021. Otherwise they could get locked out of the market altogether, or may need to pay a premium for that capacity.
The 200mm market is a sizeable business for device and equipment makers alike. More than 200 fabs in operation worldwide today produce chips using 200mm (8-inch) diameter wafers. Chipmakers use these 200mm fabs to manufacture chips based on mature processes, ranging from the 350nm to the 90nm nodes. Analog, display drivers, power management ICs (PMICs), and RF devices are among the chips produced in 200mm fabs.
Many of these devices aren’t manufactured in today’s state-of-the-art 300mm fabs. The 300mm fabs are used to process the most advanced chips, although they also manufacture devices at mature nodes from 65nm to 28nm.
Fast forward to today and industry sources suggest 200mm fabs are at capacity across foundries. With production lines maxed out, chip makers must either expand capacity in existing fabs or build new ones. Both options require more equipment — of which, there is also a shortage. Most original equipment manufacturers (OEMs) no longer produce 200mm equipment (with some notable exceptions). Even if new equipment across the process supported 200mm, lead times can be up to 18 months for new equipment from OEMs, meaning, increased expenditure on new equipment today won't yield increased capacity until 2022 at the earliest. OEMs are also looking for legacy machines, some 20 to 25 years old, in order to remanufacture them to support smaller wafers. In short, all of the sudden, vintage equipment is a hot commodity.
I don't believe there is a single explanation.artis said:@nsaspook what you say is truly interesting. One thing I don't get. CPU's and IC's are in high demand and fluctuating that I can understand but stuff like power transistors of all sorts (BJT, MOSFET, IGBT, etc etc) I always thought that this market is rather stable given those devices are used in small part by DIY enthusiasts and in large part by manufacturers but the products they come in normally don't fluctuate like smartphones or computers. I'm talking about amplifiers, washing machines, power supplies etc.
So I cannot understand why all of a sudden the fabs that produced these items cannot do so anymore?
Is it the "toilet paper" thing, where everyone gets scared of the news and buys out all BJT's or FET's in all stores and leaves empty shelves and a exponential growth in demand?
artis said:One thing I don't get.
DaveE said:Efficient economies are fragile economies
f95toli said:this has driven demand for not just phones etc but all type of consumer electronics and appliances.
Well you already said it yourself. It's a good thing we don't run our grids like that and those that are run like that often fail when certain critical conditions are met like in Texas recently.anorlunda said:Surplus capacity to take care of fluctuations in demand, can be considered unnecessary.
At present, mature process nodes in both 200mm and 300mm fabs are tight, if not sold out. “In the last few years, there has been a surge in demand for a wide variety of chips that are made on 200mm and mature CMOS technology nodes ≥28nm whether that be on a conventional CMOS, bipolar CMOS DMOS or RF-SOI based process platforms. These devices include MCUs, PMICs, digital display driver ICs (DDICs), RF ICs, and the image signal processing (ISP) wafers needed to fabricate backside illuminated CMOS image sensors. This demand is also underpinned by technical trends in several market segments,” said David Haynes, managing director of strategic marketing at Lam Research.
“The supply issues for automotive ICs are well documented, but at the same time there is increased demand from consumer products, new 5G enabled devices and display applications,” Haynes said. “The situation is further compounded as many IDMs and foundries that make these chips make not one but several of these products. Historically, they have been able to rebalance fab capacity to address increased demand for a certain product type, but when demand for so many products are surging at the same time, it’s difficult or impossible to flex output in this way. Although there have been increases in global capacity for some device types, for example display drivers, recent reports suggest that the overall industry is yet to attain supply-demand parity.”
Again, thanks all. Lots of info to absorb.dlgoff said:Thanks all. You all have been very helpful.
The US does have the capability to make auto microprocessor chips, but currently, most of the production is done in other countries due to lower labor costs and more advanced technology.
Yes, the US is highly dependent on other countries for auto microprocessor chips. In fact, about 80% of the chips used in US-made vehicles are imported from other countries.
The consequences of not being able to make auto microprocessor chips in the US include potential supply chain disruptions, increased costs for automakers, and potential delays in new vehicle production.
Yes, the US government can provide incentives and support for domestic chip production, such as tax breaks and funding for research and development. However, it may take time for these efforts to have a significant impact.
Yes, there are efforts being made by both the government and private companies to increase US production of auto microprocessor chips. For example, Intel has announced plans to invest $20 billion in two new chip factories in Arizona, and the US government has proposed a $50 billion investment in domestic chip manufacturing as part of the infrastructure bill.
