Why capacitors and inductors affect the phase and resistors
In summary: I want to know, capacitors and inductors, resist (react? impede?) the change of voltage (and current?) because there is some electrical inertia involvedas they store voltage (and current) they act as a temporary source, which is a bit out of phase with the original sourcecombined together, these two "sources" make the whole voltage and current of the circuit to have a different phase (and value?) of the one of the original sourcethis is my understanding so far, I
physior
182
hello!
why capacitors and inductors affect the phase of both current and voltage of a AC circuit and resistors don't?
let's say we have an AC circuit with resistors only, then there is no change in the voltage and current as imposed from the voltage/current source, right?
but what happens when we add a capacitor or inductor? why phase changes? and why voltage phase change and/or current phase change? and we mean change, in comparison to what exactly?
please elaborate in simple terms! you may use a mechanical analogue or something!
thanks!
Capacitors strongly resist voltage changes and inductors strongly resist current changes. They are active components compared to resistors which can handle instantaneous changes in voltage/current. You need to study the math of how these elements work.
I know the maths, I need to know the physical mechanism behind it
I guess I don't understand your question. The math describes the physical mechanism. The phase changes fall out directly from the math.
what I understand so far:
resistors oppose the flow of current and lower the voltage, as energy is being consumed into heat
but they don't resist to the change of current or voltage as imposed by the source
for some reason that I want to know, capacitors and inductors, resist (react? impede?) the change of voltage (and current?) because there is some electrical inertia involved
this is my understanding so far, I don't know if it's correct!
the root of that 'inertia' seems to be the built up charge in the capacitor (and the built up magnetic field in the inductor?)
it's really complicate to imagine how this actually work in every of the different phases (not phases like phi, but phases like different time periods) of the AC
in the beginning, the AC voltage starts from zero and increases, this makes the voltage of the capacitor to built up and increase (with a phase difference? if yes, why?)
then, how the capacitor's charge react to the decreasing increase of AC, to its plateau, to its decreasing, to its zeroing, to its inversion of its polarity, etc
anyone can relate to what I am talking about? anyone thought of these too?
I'd say that's an excellent understanding.
I don't think that's quite the best way to look at it (although I may be misunderstanding your view) because it is not the "build up" of charge/current that is the issue it is the resistance to any CHANGE in the charge/current. This is beginning to sound circular because one way to interpret what I am saying is "the resistance to change happens because of the resistance to change", which is not helpful, but I can't think of a good way to express it. Do you see what I'm getting at, though?
If you understand what capacitance and inductance are, you should understand why capacitors and inductors resist changes in voltage and current. Do you know what those two terms mean and how capacitors and inductors work?
Right. That's another way of saying what I said in post #4
Physior, in some ways your question sounds like "I don't understand inductors and capacitors but I want to understand why they do what they do". It is inherent in the understanding of these element to understand why they do what they do. The math describes it.
I know capacitance only as an equation of area of plates, distance between them, etc
I know that capacitors store charge in their plates when we put them in a circuit
Then I suggest reading more on capacitance, along with inductance if you know little about it.
but I don't have any question about capacitance or how capacitors work on DC
Capacitance is the ability of a body to store an electrical charge.
This is something easy to understand, and don't know how this relates to my question
If that's all you know, then you've got a lot to learn. Specifically you need to learn how capacitance and inductance work together to give electrical reactance, which is the opposition to a change in either voltage or current: http://en.wikipedia.org/wiki/Electrical_reactance
Note that inductors and capacitors work differently in AC circuits than they do in DC circuits. Or, rather, that a DC circuit is a special case of an AC circuit where the frequency is effectively zero, so you don't see most of the effects you usually see in an average AC circuit.
Look at the wiki article I linked and hit up google. There should be plenty of articles online that explain electrical reactance, capacitance, and inductance. I'm about to head to bed otherwise I'd elaborate a bit more on the topic.
Likes abecedarian and Doug Huffman
I find many mathematical manipulations in these articles and not a simple understanding
can't you explain as nicely I did in my number 5 post?
I gave a good explanation, not sure if it is correct, but can be understood by anyone, without using maths
understanding the maths is not always the case
I can understand algebraic manipulations, but I need to understand the physical mechanisms behind them
So did you not read my post #8?
Likes physior
Imagine this sort of dialogue about quantum theory and relativity.
IMO -- Resistors CONVERT energy from Electrical to Heat - it is then lost from the circuit ( Real POWER)... however Inductors and Capacitors (ideally) only STORE energy (granted the do convert to M and E field rep) - in an AC system they store and return energy in every cycle ( 50 / 60 times a second) ... this is referred to as imaginary power - because you have current and voltage - but you are not loosing any energy.
As for the change - we refers to the Phase angle of the current - relative to the voltage.
The phase shift is actually a bit of a special case for AC voltages/currents. The *actual* formulas for capacitors and inductors that relate the voltages to the currents involve a simple derivative (for the capacitor) or integral (for the inductor). It just happens to be that the derivative of a sine wave is the cosine wave, which is nothing but a 90 degree phase shift. The integral of a sine wave is a negative cosine wave, which is yet another 90 degree phase shift, but the other direction.
EDIT:
Capacitor formula:
Inductor formula:
(obviously the inductor formula becomes an integral when you solve it for 'i')
As others said, capacitors resist the CHANGE in voltage, and indictors resist the CHANGE in current. In AC analysis, resistance to CHANGE is the same as a phase shift of 90 degrees.
Is that what you were asking about?
physior said:
What about it? Do you even know the numerous books that explain them in simple words without mathematics and previous knowledge? Don't play the smartas
No, which ones are these, "numerous books that explain them [quantum theory and relativity] in simple words without mathematics and previous knowledge?"
physior said:
The first link in google mentions many books:
http://www.perkel.com/nerd/relativity.htm don't be that lazy Especially when you play the smartas
Well, to begin with, I do not use G00gle. Second, I have a fine collection of original source materials. Perhaps preeminent among them is a xerox copy of Stephen Hawking's BLACK HOLES AREN'T BLACK in typescript with manuscript special characters and drawings (part of my collection of Gravity Research Foundation prize winning essays). Another from my classroom days is Samuel Glasstone's The Sourcebook on Atomic Energy (Krieger 1979).
physior
be nice and stop the offending language else you will find your thread locked and yourself possibly banned
Dave
Likes Doug Huffman
Physior, first try to get a better understanding of how capacitors and inductors respond to D.C. From there it's an easy step to see how they respond to A.C. Consider for example an uncharged capacitor connected to a battery and switch. When the switch is first closed the current I is at its maximum value being limited only by the resistance of the circuit. At that instant the voltage V across the capacitor is zero because there is no charge on the plates. As time goes on the charge buids up. The result is that I gets smaller as V gets bigger. When fully charged I is zero and V is at its maximum value.You should see that I and V are out of phase. Now look up capacitor discharging and inductor charging and discharging.
Likes Symmetry777
Capacitance has its analogue in a water reservoir. Connect a tube to the bottom of a water reservoir.
Now run a current I of water into the reservoir .
The water pressure V at the bottom is proportional to the mass of water Q in it.
Q=CV with C=A/g. A is the cross section of the reservoir.
Now I=dQ/dt=CdV/dt.
One of the best ways to understand reactive components is through resonant LC circuits.
The fundamental difference between resistors versus capacitors and inductors. Resistors turn the voltage across them times the current through them into heat (voltage drop). But for the most part capacitors (lead) and inductors (lag) don't dissipate heat.
Energy stored in a capacitor comes out again in the opposite direction from which it went in.
Energy stored in an inductor comes out in the same direction as it went in.
This let's you build resonant LC circuits where energy circulates between a capacitor an inductor at a particular frequency: this is the traditional basis of a radio receiver circuit.
Cited Source:
http://electronics.stackexchange.com/questions/77763/inductors-what-are-they-used-for
Look, you can spend all day going back and forth here on the forums, but in the end the only way you'll understand why voltage and current lag in an AC circuit is to look into reactance, inductance, and capacitance. You'll find PF to be of much more use to you if you do this on your own and then come back with specific questions. It's very difficult to teach someone about broad topics like this using a forum. There's simply no substitute for a good textbook on the topic.
Likes rumborak, Symmetry777 and Doug Huffman
  • #31
Yes. There is no substitute for some serious work on your own, sorting out your own difficulties, step by step, rather than demanding help at every hurdle, as it arose. People did pretty well when there was no Internet with an endless supply of people prepared to answer every question. They used to read books and papers and things and, perhaps once week (if they were lucky) they went to a tutorial. People used to get degrees and doctorates that way. Amazing'.
  • #32
Questionable link removed by mentor
This is a genuinely AWFUL reference. The guy himself admits he doesn't understand things very well, and then he goes on to demonstrate exactly that.
Ya think maybe his statement "I have gone beyond some of the predictions of Einstein, Hawking, and others and made some of my own predictions." is a clue to his reliability?
Likes berkeman
  • #33
I left this thread for a while and major things happened
you didn't like my link? do you still doubt there are simple explanations to things like relativity?
com'on there's even a complete idiot's guide!
http://www.amazon.com/dp/1592571859/?tag=pfamazon01-20
will you delete that link too as unrealiable?
  • #34
It's not that there aren't simple explanations, it's that you linked to a very poor source of information. The explanations given in that link are simply not very good if you're looking to learn real physics.
We will if you attempt to use it as a reference and it ends up being inaccurate. Then it shows that the book is a poor reference as well.
Now, I suggest we get back on the original topic or I'm going to lock this thread.
Likes Doug Huffman
Related to Why capacitors and inductors affect the phase and resistors
1. Why do capacitors and inductors affect the phase and resistors?
Capacitors and inductors are reactive components that store and release energy in an electrical circuit. This storage and release of energy causes a phase shift in the current and voltage, which in turn affects the overall resistance of the circuit.
2. How do capacitors and inductors affect the phase and resistors?
Capacitors and inductors have different reactance values, which means they impede the flow of current in different ways. This leads to a phase shift in the current and voltage, and ultimately affects the overall resistance of the circuit.
3. Do capacitors and inductors always affect the phase and resistors?
Yes, capacitors and inductors always affect the phase and resistors in an electrical circuit. This is because they are reactive components that store and release energy, which causes a phase shift in the current and voltage.
4. Can capacitors and inductors be used to control the phase and resistance in a circuit?
Yes, capacitors and inductors can be used to control the phase and resistance in a circuit. By adjusting the values of these components, the phase shift and overall resistance can be manipulated to achieve desired results.
5. What happens if a circuit does not have capacitors or inductors?
If a circuit does not have capacitors or inductors, it will have a purely resistive behavior. This means there will be no phase shift in the current and voltage, and the resistance of the circuit will only depend on the values of the resistors present.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
