- #36
- 68,393
- 22,249
You need the deisel engines and their generators to power the electric azipods...DaveC426913 said:Which, I dunno, seems to suggest it may not by diven by azipods after all.
Arjan82 said:Some user account. Apparently a wave struck from the side. This means the orientation of the ship at that time was indeed with the wind and waves coming from the side. This is not an ok orientation for such a ship to be in...
I thought we weren't allowed to discuss perpetual motion devices here...berkeman said:You need the deisel engines and their generators to power the electric azipods...
Arjan82 said:So, I'm pretty sure that a ship of this size can not be stopped in such a way that it causes people to be knocked over.
Of course we all have, but the issue is how much thrust can those propeller pods deliver versus the mass of the ship. If they are monster engines compared to the ship's mass, then you can get more of an impulse. But it's hard to believe that the propeller pods would be sized so big and powerful to generate such large accelerations for such a massive ship. After all, when would a cruise ship need to take super-quick evasive maneuvers?m1ke said:have you not heard of “Newton’s Third Law of Motion”?
Of course but turning fast can tilt a ship a long way.m1ke said:“Newton’s Third Law of Motion”?
m1ke said:I’m surprised to have to bring this up considering this is a “physics forum”, but have you not heard of “Newton’s Third Law of Motion”?
A ship traveling at 20 knots will not knock anyone over, nor will it cause their uteruses to fall out.m1ke said:This is really all easily answered by these principles. The very size and weight of that cruise ship and the force at work to propel it through the water would then be felt through the entire ship itself and that would easily knock people over or send them tumbling.
It doesn't have to be a matter of thrust and mass, it's a matter of torque and moment of inertia which will make a ship roll / list. If a large wave turns up and you take the wrong action, you can end up with a worse situation than if you didn't bother to steer at all.berkeman said:but the issue is how much thrust can those propeller pods deliver versus the mass of the ship
Have you ever been down below on a big ship in heavy weather - or even just a moderate sea? A very slight list is enough to make you fall over if you are not expecting it. The two sensory inputs - change of where "down" is and the visible clues due to vertical lines and walls need only to disagree a bit to make you unsteady.DaveC426913 said:How big do the engines need to be to decelerate it (in the viscous medium of water) to knock people over
A cruise ship travelling at 20 knots and suddenly experiencing a full propulsion shutdown causing the props to essentially seize in place would create massive, but only momentary amounts of great friction when you consider aerodynamic principles. The stopped props on the ship, once you consider the sheer size of these propellers which are designed to move as much water with a very low rpm making it nessecary to increase the friction generated under propulsion with big thick blades that when halted, work just like the air brakes.DaveC426913 said:
The question is how fast can it stop (or turn).
The Spirit of Discovery weighs in at 58,000 tonnes.
How big do the engines need to be to decelerate it (in the viscous medium of water) to knock people over?
How big is big here? This ship is 236 meters and has stabilizers. Did you look at the video? That is not during the accident. It hardly moves, even in this weather (that is, up until the point the engines shut down...). Also, list itself is not that important (up to a certain extent), the accelerations are the problem, that is what makes you topple over. Try to imagine (or compute...) the forces needed to get significant accelerations on a mass of 58000 tonnes. The waves can do that however, if they come from the side. But the engine or steering simply does not.sophiecentaur said:Have you ever been down below on a big ship in heavy weather - or even just a moderate sea? A very slight list is enough to make you fall over if you are not expecting it. The two sensory inputs - change of where "down" is and the visible clues due to vertical lines and walls need only to disagree a bit to make you unsteady.
Yes. All of which is a much more applicable than "...but Newton's third Law!"m1ke said:A cruise ship travelling at 20 knots and suddenly experiencing a full propulsion shutdown causing the props to essentially seize in place would create massive, but only momentary amounts of great friction when you consider aerodynamic principles. The stopped props on the ship, once you consider the sheer size of these propellers which are designed to move as much water with a very low rpm making it nessecary to increase the friction generated under propulsion with big thick blades that when halted, work just like the air brakes.
I'd disagree with that. A temporary change in the local perceived vertical is extremely confusing and even dangerous. A list of just over 5 degrees can give you the impression of a sideways force of 10% of your body weight. That can throw you over easily if you are not ready for it and even if it takes several seconds to develop. We've already agreed that the 0 to 60 acceleration of a ship with even the most powerful engines is far too long to cause the effects described. I'm trying to present an alternative which is actually common experience.Arjan82 said:Also, list itself is not that important
Yeah, now that you menton it, you're right. When you're on a ship so large that you might as well be on land, you don't walk or stand with caution, and there's no horizon to orient you. It wouldn't take much.sophiecentaur said:Have you ever been down below on a big ship in heavy weather - or even just a moderate sea? A very slight list is enough to make you fall over if you are not expecting it. The two sensory inputs - change of where "down" is and the visible clues due to vertical lines and walls need only to disagree a bit to make you unsteady.
You only have steerage way if there is relative motion between ship and current. After an hour or so after engines off (or sooner than that), you can consider the ship as stationary. The rudder can have no effectm1ke said:Lastly one poster mentioned how a ship without propulsion is not affected by the rudders which is not correct as oceans have currents which can easily move a large object like a ship without propulsion in a modestly predictable manner.
