Why did Dirac want a first-order equation?
  • I
  • Thread starter carllacan
  • Tags
    Dirac
In summary, Dirac developed his equation as a first-order wave equation for the electron in order to avoid the issues with higher-order equations and to find a solution that was compatible with the principles of quantum mechanics and relativity. This was a result of his contemplation on the problems with second-order equations and his understanding of the Poincare group and local interactions.
carllacan
274
If I understand it correctly Dirac developed his equation because he was looking for a relativistic first order wave equation for the electron, rather than a second-order one like the Klein-Gordon equation.
Why did he wanted a first-order equation? Is it because the probability current is not positive-definite for higher than second order equations?
The wikipedia article gets into why Dirac chose first order instead of second order here:
Dirac's coup
Dirac thus thought to try an equation that was first order in both space and time. One could, for example, formally take the relativistic expression for the energy replace p by its operator equivalent, expand the square root in an infinite series of derivative operators, set up an eigenvalue problem, then solve the equation formally by iterations. Most physicists had little faith in such a process, even if it were technically possible.
As the story goes, Dirac was staring into the fireplace at Cambridge, pondering this problem, when he hit upon the idea of taking the square root of the wave operator...
https://en.wikipedia.org/wiki/Dirac_equation
There's also some discussion on physics stackexchange about it here having to do with the 1/2 spin of fermions which implies a first order equation:
http://physics.stackexchange.com/qu...-dirac-equation-and-bosons-a-second-order-one
Likes bhobba and carllacan
Ok, so to sum up in case someone googles his way to this post:
If the equation for the wavefunction is of second order the boundary conditions must include the initial value of its first time derivative, which can be negative. The expression for the current density involves the time derivative of the wavefunction, so if the value of that derivative was negative at some point (which as we have said cold happen) then you would have a non positive definite probability current, which is nonsensical.
Dirac's first motivation is invalidated already by himself. There is no working interpretation of relativistic QT in terms of "wave mechanics" a la Schrödinger's non-relativistic equation. The reason is that you necessarily are lead to a many-body theory with non-conserved particle numbers and thus also the existence of antiparticles. The most convincing argument for the Dirac equation we know today is the representation theory of the Poincare group together with the assumption of local interactions and the existence of a stable ground state, leading to the CPT and spin-statstics theorem and are the basis for the very successful Standard Model of elementary particle physics.
Related to Why did Dirac want a first-order equation?
1. Why did Dirac want a first-order equation?
Dirac wanted a first-order equation because he believed that the equation for the electron should be simpler and more elegant than the second-order equation proposed by Schrödinger. He also wanted to incorporate the principles of both special relativity and quantum mechanics into one equation.
2. What is the significance of a first-order equation in physics?
A first-order equation is significant because it allows for a more complete and accurate description of physical phenomena. It also simplifies calculations and makes it easier to incorporate other principles or theories into the equation.
3. How did Dirac's first-order equation contribute to the development of quantum mechanics?
Dirac's first-order equation, also known as the Dirac equation, provided a more complete and accurate description of the behavior of electrons, taking into account both special relativity and quantum mechanics. This helped to further develop and solidify the principles of quantum mechanics.
4. Was Dirac's first-order equation immediately accepted by the scientific community?
No, Dirac's first-order equation faced some resistance and skepticism from the scientific community at first. However, with further experimentation and evidence, it was eventually accepted and is now an integral part of modern physics.
5. How does Dirac's first-order equation differ from Schrödinger's second-order equation?
Dirac's first-order equation takes into account the principles of both special relativity and quantum mechanics, while Schrödinger's second-order equation only incorporates quantum mechanics. Additionally, Dirac's equation is a more accurate description of the behavior of particles with spin, such as electrons.
11K
