Why did I find 9.41 and not 9.81 m/s² ?
  • Thread starter Ellio
In summary, @PeroK and @Orodruin said that there may be factors such as the air surrounding the room, the measurement error, and bias in the students' results. @PeroK also said that if you trust your measurement in relation to the others, you would say that it depends on how much you trust your measurement. @PeroK also said that after seeing the results of the class, he decreed that from then on, g is 9.6 m/s2.
Ellio
"Calculate the acceleration of the falling object with your research."
slope = Δy/Δx
x = 1/2 × a × t²
Hello I hope you are all very well !
So I have a practical work in physics.
The experiment was to release a long tape with a mass of 40g at the end from a certain height. An instrument would hit the tape 50 times/s and put a mark each time. From that we had to do a graph x(t²) and a series of exercises.
1) The slope of the graph ≅ 4,707 (0,610/0,1296)
2) 4,707 = 1/2 × a × 1
<=> a = 9,414
It may sound like a stupid question but why is my result not equal to 9,81 ? 9,81m/s² is the acceleration of all object falling on the surface of the Earth right ?
What did cause this inequality of 4% ?
Ellio said:
Homework Statement: "Calculate the acceleration of the falling object with your research."
Homework Equations: slope = Δy/Δx
x = 1/2 × a × t²
<=> a = 9,414
What do you think may be the factors?
The air surrounding the room, I presume.
There are also always measurement errors. How was your experiment set up? Did you do a proper error analysis?
In addition to what @PeroK and @Orodruin mentioned, I want to place your question in a more general framework and ask you, why are you distrusting your measurements? If I asked you to measure the length of a table and came up with 2.65 m and I said, "No it's 2.45 m", would you say (a) "But I measured it and it's 2.65 m" or (b) "Yes, boss, whatever you say. I must have done something wrong." Are you results invalid just because someone you consider more authritative than you contradicts them? Are you the "boss" or not? It's tricky isn't it? At some point, when you do science, you have to trust yourself and call the shots the way you see them after you have eliminated all paths that might have led you astray.
I would say it depends on how much you trust your measurement in relation to the others. In the case of gravitational acceleration, students tend to expect 9.8-ish.
There is also significant bias in students presenting results. I had a high-school teacher tell me that if you make a histogram of student results for g, you typically get a very nice gaussian centered around 9.8 m/s^2 - except that it is cut-off at 10 m/s^2...
Likes robot6
I agree.
I've had a related experience about 20 years ago with a class of about 220 students doing the g measurement. The students were split in groups of 3 so we are talking about 70 separate measurements. The average over all reported values came out to be 9.6 m/s2 with a standard deviation of about 0.3 m/s2. The outliers were were limited to no more than 10.4 m/s2 but there was a remarkable but honest 2.4 m/s2. After seeing the results, I decreed that from then and until the end of the semester the value of g is what the entire class thinks it is, 9.6 m/s2, and that value should be used in all calculations where numerical answers are required. After the semester was over, students could use whatever value they wanted for g. Some students were disconcerted, "Can you do this?", to which I replied, "You and 220 of your peers measured came up with that average value. Which do you believe, your and your classmates or something printed in a book and why?". At the time I thought that it would be a worthwhile exercise, but the students hated using a value the "knew" to be wrong it so I didn't repeat the experiment.
@Ellio , let me ask you this. When the weight in your experiment was falling, was gravity the only force acting on it? Could there have been any other forces?
What held the tape in such a way that the instrument was able to mark it? Can a mark be made without hindering the tape at all? What other hindrance may affect the tape?
Well, thank you all for your answers. But I wasn't really claiming thay my measurement were 'wrong'. 4% of deviation is indeed nothing, I'm of course leaving my answer.
I just wanted to know by curiosity what are the factors that could cause this very slight deviation (atmosphere, ...).
Think more mechanically.
Could any forces be interfering with the free fall of the weight?
I think the two factors causing this deviation are the vibrator (hitting the tape 50 times/s) and the measurement of the distance between each mark with a ruler (±1mm of error)
But isn't there any other that I could have forgotten ?
There may be that much error in individual marks but to affect your estimate of g what matters is the cumulative error along the tape. Could it have become stretched by 4%?
You previously mentioned air drag on the tape. You didn't answer my question re what holds the tape in place so that marks can be made on it... presumably some sort of guide.
This was the instrument. The band was held where there's the red circle. The yellow arrow shows the vibrator which hit the band 50 times/s.
(The tape was of course vertical in the experiment.)
Is your setup as shown here? If so, note that the use of 200 g is recommended because "If the mass used is too small, it will not give accurate results because of air drag and friction on the paper tape." You used 40 g.
Likes robot6
Ok thank you very much ! (Yes it's the setup we used.)
Related to Why did I find 9.41 and not 9.81 m/s² ?
1. Why is the acceleration of gravity different at different locations?
The acceleration of gravity, or the force that pulls objects toward the center of the Earth, varies at different locations due to several factors. These include the shape and rotation of the Earth, as well as the distribution of mass within the Earth. Additionally, variations in altitude and the presence of other large objects with gravitational pull can also affect the acceleration of gravity.
2. How is the acceleration of gravity measured?
The acceleration of gravity is typically measured using specialized equipment such as a pendulum or a free-falling object, which can calculate the time it takes for an object to fall a certain distance. This measurement is then used in the equation a = g to determine the acceleration of gravity, where a is the acceleration and g is the gravitational constant.
3. Why is the acceleration of gravity often rounded to 9.8 m/s²?
The acceleration of gravity is often rounded to 9.8 m/s² for simplicity and convenience in calculations. The actual value of g varies slightly depending on location, but 9.8 m/s² is a close approximation that is easy to work with in equations and measurements.
4. What factors can affect the accuracy of measuring the acceleration of gravity?
There are several factors that can affect the accuracy of measuring the acceleration of gravity, including air resistance, friction, and the precision of the measuring equipment. Additionally, human error and external forces such as wind can also impact the accuracy of measurements.
5. Can the acceleration of gravity change over time?
While the acceleration of gravity can vary at different locations, it is generally considered a constant value. However, small changes in the Earth's rotation or distribution of mass can cause slight variations in g, though these changes are typically too small to be noticeable or have a significant impact on measurements.
