Why didn't the Big Bang form a Black Hole?
In summary, the Big Bang did not form a black hole because it was an expansion of space rather than a collapse under gravity. The universe's rapid inflation and the distribution of energy prevented the conditions necessary for black hole formation. Instead of concentrating mass in a small region, the Big Bang dispersed energy and matter across an expanding universe, leading to the structures we observe today.
peterraymond
TL;DR Summary
Why didn't the big bang form a black hole?
(pop science) It seems like the mass in the universe at the point of origin was way higher and the size way smaller than required to form a black hole, so why didn't our universe just sit forever as a single black hole? From a figure for the mass of the universe you could calculate the event horizon diameter. I can imagine that maybe it was a universe expanding, not just a massive object, but shortly after there was plenty of mass inside that universe that was very closely packed, so there could still be very many black holes forming shortly after the big bang, or a single one sitting out there someplace.
Space news on Phys.org
peterraymond said:
(pop science)
Is not a good source for learning actual science.
Because it was rapidly expanding. All of the calculations cited in pop science sources about how much mass there was in how small a volume vs. what would be required to form a black hole are only valid for a static object surrounded by vacuum. They are not valid for a rapidly expanding universe which is roughly the same density everywhere.
Likes Orodruin
Thanks for the replies. It did seem like it would be a FAQ - I just hadn't seen it. My "(pop science)" label was included not to say I had learned something from pop science, but just a warning that that was the level of the questioner.
One part of the answer leads naturally to another question I've been thinking about, but that will take a little longer to craft.
Thanks again.
  • Skeptical
Likes berkeman
This is what the thread level is for. If you only have pop science knowledge about the subject you should pick thread level B. Level I indicates undergraduate level knowledge.
I have a question about this answer. I believe a few millions of years after the big bang, the observable universe, if it was surrounded by vacuum, had enough density for an event horizon. But larger black holes get less dense as the size increases. So does it mean that there are only 2 possibilities: that either A the universe is infinite and consistent density therefore no event horizon or B the universe is not infinite, but has an event horizon since the part we can see had sufficient density in the past to have an event horizon, and if the part we can’t see has the same density, it must be surrounded by an event horizon, since larger black holes are less dense?
You left out the "static object" part. Our observable universe has always been expanding. It has never been static. So even if we assume (contrary to our best current models) that outside our observable universe is vacuum, it still would not have formed a black hole. The expansion makes a difference.
No. Again, you're leaving out expansion, which is crucial. See above.
Likes Devin-M
Also ... It wasn't. At least not according to the basic cosmological models, which assume the entire universe to be homogeneous - that includes regions outside the currently observable universe.
Likes Devin-M
FAQ: Why didn't the Big Bang form a Black Hole?
Why didn't the Big Bang form a Black Hole due to its immense density?
The Big Bang didn't form a black hole because it wasn't a localized event in space; it was an expansion of space itself. The density was indeed immense, but it was uniformly distributed across the entire universe rather than concentrated in a single point.
Was the initial singularity of the Big Bang similar to a black hole singularity?
While both singularities involve extremely high densities, the initial singularity of the Big Bang and a black hole singularity are different. The Big Bang singularity represents a state where the laws of physics as we know them break down, but it involves the entire universe and an expansion of space, whereas a black hole singularity is a localized point within an existing space.
Could the rapid expansion of the universe have prevented black hole formation?
Yes, the rapid expansion of the universe, known as inflation, played a crucial role in preventing black hole formation. This expansion diluted the density of the universe very quickly, making it less likely for regions to collapse into black holes.
How does the concept of cosmic inflation relate to black hole formation?
Cosmic inflation refers to a period of extremely rapid expansion in the early universe. This expansion stretched the fabric of space-time and smoothed out any potential irregularities that could have led to localized high-density regions, which might have collapsed into black holes.
Are there any conditions under which the Big Bang could have formed black holes?
Theoretically, if certain regions of the early universe had slight over-densities, they could have collapsed into primordial black holes. However, the overall uniformity and rapid expansion of the universe make such occurrences rare and not representative of the Big Bang as a whole.
