Why different objects behave differently with light?
  • Thread starter MalayInd
  • Tags
    Light
In summary: Yes, the electrons in matter act like a mass on a spring. The electric field of the light wave oscillates these and depending on the material the electrons are damped more or less - transmitting the field or not. This is why a mirror reflects light while a wall does not.
MalayInd
33
We can see our image in a mirror but not in a wall. The explanation is that mirror reflects the light falling on it whereas the wall does not. But if the wall does not reflect light, how can we see the wall?
Another question, an object reflects some part of light, refracts other and absorbs some part.Why this happens and how does it depends on the nature of matter?
Why different objects behave diifferently with light?How can the behaviour be explained?
Keep Smiling
Malay
The wall reflects some of the light (not as much as the mirror), but also diffuses it... the light doesn't necessarily reflect with the same angle of incidence (the wall is not as "smooth" as the mirror).
An object reflects, absorbs and transmits light. This depends on many many factors. Including whether the material conducts electricity, the crystal structure etc.
A basic way to think about it can be to assume that electrons act like a mass on a spring. The electric field of the light wave oscillates these and depending on the material the electrons are damped more or less - transmitting the field or not...
That's a basic way to look at it, if you want to know more, google photonics.
Both the wall and the mirror reflect light. But there is an important difference between the way a mirror reflects light and a wall reflects light.
At microscopic dimensions, the wall is rough whereas the mirror is smooth (the bumps being smaller than the wavelength of the light). So the light from the wall disperses on reflection but the reflected light from the mirror has the same characteristics at the incident light. Ever wonder why you polish shoes by rubbing really hard to get a nice shiny reflection?
AM
Ok I understand the basic idea.
You are talking about the elctrons in the matter. Right?(If yes, I understood it).
Now one question about light wave:
Light is an electromagnetic wave whick can travel in vacuunm. What are sources of oscillating fields in vacuum?
Now I have wondered on the following question for a long time.We know that waves carry energy from one place to another and we are living in a sea of waves,some of them we use and others remain useless.(e.g radio waves are used only when radio is on, at all the other times energy is wasted)Is there any way to extract energy out of waves?
Keep Smiling
Malay
FAQ: Why different objects behave differently with light?
Why do some objects reflect light while others absorb it?
The behavior of objects with light depends on their physical properties, such as their surface texture, color, and chemical composition. Objects that appear shiny or smooth usually reflect light because their surfaces are able to bounce light off in a regular and predictable manner. On the other hand, objects that appear dull or dark usually absorb light because their surfaces are not able to reflect light as efficiently, and instead, the light is absorbed and converted into heat energy.
How does the color of an object affect its interaction with light?
The color of an object is determined by the wavelengths of light it reflects. For example, an object appears red because it reflects red wavelengths of light and absorbs all other colors. Objects that appear white reflect all wavelengths of light, while objects that appear black absorb all wavelengths of light. This is why objects of different colors behave differently with light - their ability to reflect or absorb specific wavelengths determines their appearance.
Why do some objects appear transparent while others are opaque?
The transparency of an object depends on its physical structure and the way it interacts with light. Objects that are transparent have a molecular structure that allows light to pass through them without much interference or scattering. On the other hand, objects that are opaque have a molecular structure that causes light to be absorbed or reflected, making them appear solid and impenetrable.
How do different materials affect the way light behaves?
Different materials have different properties that affect the way light interacts with them. For example, glass is transparent because its molecular structure allows light to pass through it without much interference, while metal is opaque because its molecular structure causes light to be reflected. Additionally, some materials have the ability to bend or refract light, such as a prism, while others can polarize light, like polarized sunglasses.
What factors determine the amount of light an object reflects or absorbs?
The amount of light an object reflects or absorbs depends on several factors, including its color, texture, and chemical composition. Bright and smooth surfaces tend to reflect more light, while dark and rough surfaces tend to absorb more light. Additionally, the chemical makeup of an object can influence its interaction with light, as some substances are more reflective than others. The angle at which light hits an object can also affect the amount of light it reflects or absorbs.
