Why do all elementary particles spin?
In summary, spin is a fundamental property of what defines each particle. It's a consequence of the postulates of QM and the rotational invariance of space. The rotational invariance is usually imposed by postulating that spacetime is Minkowski space (although this isn't necessary if we're only interested in the spin; we could consider the non-relativistic spacetime as well). This forces us to consider representations of the covering group of the Poincaré group on Hilbert spaces, and it turns out that it's natural to identify each irreducible representation with a possible particle species.
samsara15
Any ideas here? For that matter, why should the spin of each particle always be the same? Or can we do no better than to say they do, and that its spin is a fundamental property of what defines each particle?
It's a fundamental part of the definition of each particle species. It's a consequence of the postulates of QM and the rotational invariance of space. The rotational invariance is usually imposed by postulating that spacetime is Minkowski space (although this isn't necessary if we're only interested in the spin; we could consider the non-relativistic spacetime as well). This forces us to consider representations of the covering group of the Poincaré group on Hilbert spaces, and it turns out that it's natural to identify each irreducible representation with a possible particle species. ("Possible" because not all of them correspond to particles that exist in the real world). Within each irreducible representation, the spin is the same.
Chapter 2 of Weinberg's QFT book describes this stuff pretty well, but it's not really easy. I still don't fully understand this stuff myself.
Thanks for the references. Not sure I fully understand, but the general drift of your argument is comprehensible enough to give me something to reference.
Figure that out, and you'll win a Nobel Prize. :smile:
"Why do all elementary particles spin?"
If only we knew. The property we call spin is derived from some very deep interaction with spacetime at the quantum level (for which we currently have no physical theory). By the time this interaction is transmitted all the way back up to our macroscopic version of spacetime (for which we do have a physical theory) we see an effect we call "spin".
Spin is a reminder of just how much we don't know.
The pion, otherwise called the pi meson, has no spin. The pion is the lightest particle with no spin. There are actually 3 pions, one with zero charge, and two with charge equal to + or - 1 electron (or proton) charge. Their masses are about 1/7 the mass of a proton. They are all unstable (radioactive), and decay into two photons (pi zero) or a muon and a neutrino (pi plus and pi minus).
but pion is no elementary particle..
The spin is a symmetry property under rotation. The pion does have spin, it just happens to be zero, and it's quite an important property !
. What about the pi zero, which is its own antiparticle?
The pion isospin triplet has one given Lorentz spin of course, the same for the 3 members of the isotriplet. They are pseudoscalars. I don't understand the subtlety here.
The spin is basically a "number" that labels the way the mathematical entities describing a particle (function, vector field,...) transform under a "rotation"..
However to understand why half-integer spins are also possible one has to know a bit of group theory (the fact that we must use SU(2) as a rotational group and not the normal SO(3) )
The lowest mass particle that has isospin I= 0 is the eta particle at mass = 547 MeV. Does the eta have spin, even if its isospin equals zero? Or is isospin = 0 equivalent to having no spin? Is the eta particle an elementary particle?
it is a pseudoscalar meson, isosinglet state.
The physical eta meson is a mixture of the octet and singlet eta-meson.
the singlet eta meson has quark-wavefunction:
(1/sqrt 3) (u,u-bar + d,d-bar + s,sbar)
The octed eta meson has quark-wavefunction:
(1/sqrt 6) (u,u-bar + d,d-bar - 2s,sbar)
For more info, there is a great chapter about it in the Particle Data group.
So no, the eta is a meson, a composite particle.
And don't mix isospin with spin...
are all these things figured out in bubble chambers?and by spin are physicists referring to the spiraling patterns left in bubble chambers? lots of questions because I am uneducated
dangerbird said:
are all these things figured out in bubble chambers? by spin are physicists referring to the spiraling patterns left in bubble chambers?
NO. LOL.
The reason for why particle make spirals is that charge particles spiral in electric and magnetic fields, it is called the Lorentz Force.
Spin is related to transformation properties under rotation groups.
malawi_glenn said:
NO. LOL.
dunno half of what you just said but hmm ok. thanks
here are articles:
http://en.wikipedia.org/wiki/Spin_(physics )
http://en.wikipedia.org/wiki/Lorentz_force
Lorentz force is taught in first course in electromagnetism, which is like the 2nd or 3rd course you have in physics at collage.
If you tell me at what level at studies you are, I can recommend books etc. for you
spin is the angular momentum when the particle interacts with other matter.
no not accurate, spin is the rotation transformation property. An non interacting particle also have spin.
i see
Related to Why do all elementary particles spin?
1. Why do elementary particles have spin?
Elementary particles have spin because they are fundamental units of matter and energy, and spin is one of their intrinsic properties. Much like mass and charge, spin is a fundamental characteristic of particles that cannot be explained by any other underlying factors.
2. What determines the direction and magnitude of an elementary particle's spin?
The direction and magnitude of an elementary particle's spin are determined by the particle's properties such as its mass, charge, and interaction with other particles. Spin can also be affected by external factors such as magnetic fields.
3. How is spin related to the behavior of elementary particles?
Spin is related to the behavior of elementary particles in several ways. For example, it affects how particles interact with each other, how they respond to external forces, and how they decay. Spin is also a key factor in determining the stability and lifetime of particles.
4. Can the spin of an elementary particle change?
Yes, the spin of an elementary particle can change through certain interactions with other particles. For example, the spin of a particle can change during a collision or decay process, or when it interacts with a magnetic field.
5. What is the significance of spin in particle physics?
Spin is a crucial concept in particle physics as it helps to classify and distinguish between different types of particles. It also plays a key role in the fundamental forces and interactions between particles, and helps to explain many phenomena observed in nature. In addition, spin is a fundamental aspect of quantum mechanics, which is the theoretical framework that describes the behavior of particles at the subatomic level.
  • Quantum Physics
