Why do antibonding orbitals have more energy than bonding orbitals?
In summary: Of course you can do the latter, and make it work, but it is not necessary.In summary, the conversation discusses the interaction between two out of phase electrons and the creation of a node in the anti bonding molecular orbital. It also brings up the question of why electrons are always in two states and why they can't have other phase differences. The conversation also touches on the concept of the Aufbau principle and its role in determining the electronic configuration of molecules. However, it is important to note that this principle is not directly related to the way molecules are formed in reality. Lastly, the conversation discusses the concept of constructive and destructive interference in molecular orbitals, but it is important to approach this concept with caution and not rely on it
Frigus
337
160
Suppose their are two electrons which are out of phase and they interact to create node due to which those electrons will be automatically present in anti bonding molecular orbital but we say antibonding molecular orbital have high energy...now there problem is that if their is no energy available and the electrons are out of phase then if they interact they will be in higher energy state but due to absence of energy they can't go their but they have created node in between nuclei so remaining orbital is antibonding orbital so where will electrons go and I also have another question that why electrons are always in two states that is in phase and out of phase why can't they have some other phase difference in between them.
Their is also one thing which is itching me is that "we say due to aufbau's rule electrons go in bonding orbital first due to low energy so does this means that the way electrons will interact is depended upon the situation because to have bonding orbitals electrons should be in phase which means that state of electron was not decided earlier."
These things have blown my mind.
Thanks
Hemant
Chemistry news on Phys.org
What you wrote there is very confusing. What exactly do you mean by "two electrons which are out of phase."
Molecules are not built up with electrons "of a specific phase" coming together.
The Aufbau principle is a method to figure out the electronic configuration of the ground state of the molecule. It has nothing to do with how molecules are form in reality from the collision of atoms or molecules.
I was watching this video and at 1:14 he said that if electrons are in phase they will do constructive interference and if they are out of phase they will do destructive interference.
From this a doubt came to my mind that why does electrons can always be in phase or out of phase why doesn't some another combination occurs between them.
Can you please specify some part which I am not able to explain properly or should I rewrite this whole question again.
The video tries to present things in such a simplified manner that the result is basically wrong. I understand where the guy is coming from, but this approach can lead to a lot of confusion.
When constructing molecular orbitals for the hydrogen atom, you can consider them (= approximation) as the sum of two atomic orbitals, one from each hydrogen atom. Two linear combination are possible,
\Psi_\mathrm{bonding} \propto \phi_a(1) + \phi_b(2)
and
\Psi_\mathrm{anti-bonding} \propto \phi_a(1) - \phi_b(2)
where a/b labels the orbitals and 1/2 labels the atoms. The resulting molecular orbitals appear to show, in-between the nuclei, constructive or destructive interference.
I think it is better to consider the molecular orbitals as mathematical constructions first, and then populate them with electrons (like you do with atoms) then to conceptualize them as electrons interfering with each other.
Likes jim mcnamara and BvU
FAQ: Why do antibonding orbitals have more energy than bonding orbitals?
1. Why do antibonding orbitals have more energy than bonding orbitals?
Antibonding orbitals have more energy than bonding orbitals because they have a higher number of nodes, which are regions where the electron probability is zero. These nodes create a repulsive force between the bonding atoms, making the bond weaker and the antibonding orbital higher in energy.
2. How do antibonding orbitals affect the strength of a chemical bond?
Antibonding orbitals weaken the strength of a chemical bond by creating a repulsive force between the bonding atoms. This is due to the higher energy and increased number of nodes in the antibonding orbital, which counteracts the attractive force of the bonding orbital.
3. Can bonding orbitals become antibonding orbitals?
No, bonding orbitals cannot become antibonding orbitals. Bonding orbitals are formed by the constructive interference of atomic orbitals, while antibonding orbitals are formed by the destructive interference of atomic orbitals. Therefore, the two types of orbitals cannot transform into each other.
4. How does the number of electrons in an antibonding orbital affect its energy?
The number of electrons in an antibonding orbital affects its energy by increasing it. As more electrons occupy the antibonding orbital, the repulsive force between the bonding atoms becomes stronger, leading to a higher energy state for the orbital.
5. Are antibonding orbitals always higher in energy than bonding orbitals?
Yes, antibonding orbitals are always higher in energy than bonding orbitals. This is due to the nature of their formation, with the destructive interference of atomic orbitals creating nodes and a repulsive force between the bonding atoms. Therefore, antibonding orbitals will always have a higher energy state than bonding orbitals.
