MHB Why Do Different Calculations of a Probability Problem Yield Different Results?
  • Thread starter Thread starter schinb65
The discussion centers on calculating the probability that a randomly chosen person owns either an automobile or a house, but not both, based on survey data. The correct answer is determined to be 0.5, which can be confirmed using both a Venn Diagram and the probability formula. The formula used is \(P[A \cup B] - P[A \cap B]\), which simplifies to \(P[A] + P[B] - 2P[A \cap B]\). Participants confirm that both methods yield the same result of 0.5, validating the calculations. Understanding the correct application of the probability formula is essential for accurate results.
schinb65
A marketing survey indicates that 60% of the population owns
an automobile, 30% owns a house, and 20% owns both an automobile and a house.
Calculate the probability that a person chosen at random owns an automobile or a house, but not
both.
I am Told that the answer is .5, I did this problem 2 different ways and I received different answers, and .5 is one of the answers.
If I draw a Venn Diagram I receive .5 and that makes sense.
I also tried this, \(P[A\cup B]=P[A]+P-P[A \cap B]\),
I assume that I have something incorrect in the formula since I do not get the right answer. Would I be able to use this formula?
Mathematics news on Phys.org
Welcome to MHB, schinb65!
both.
A Venn Diagram is best. ;)
But yes, you can also use that formula.
\begin{aligned}
P[\text{A or B but not both}] &= P[A\cup B]-P[A \cap B] \\
&=\big(P[A]+P-P[A \cap B]\big)-P[A \cap B] \\
&=P[A]+P-2P[A \cap B] \\
&=60\%+30\%-2\times 20\% \\
&=50\% \\
\end{aligned}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
