Why Do Different Solving Methods Yield Different Results for (sin(x)/x) = x?
  • Thread starter k_squared
In summary, computers have inherent limitations when it comes to solving equations with irrational numbers. Due to their discrete nature, they can only approximate the exact solution and may give different results depending on the representation of the functions involved. This is one of the reasons why computers are not infallible and why it is important to understand their limitations.
Mathematics news on Phys.org
Computers have inherent limitations. The answer is in fact still zero.
When a computer uses a numerical method to approximate the solution to an equation such as the one you gave, it simply can not calculate the answer exactly. It turns out that different representations of functions can give different computational results, which you have just seen.
(Why are computers ultimately inaccurate? Consider an irrational number like pi, 3.1415926... etc. Pi never ends. Well computers are inherently discrete systems and so a computer can NEVER represent an infinite decimal like pi. A computer only has so many bits and can only represent rational numbers ultimately. The computer's number line has "gaps".
Couple this limitation of computers with the following fact. It turns out that there are way more irrationals than there are rationals on the real number line. So much more in fact that if you picked a number at random off of the real number line, the probability that you would pick a rational is 0. Not 0.0000000001. Flat out zero.)
Moral of the Story:
This is one of the reasons computers are not the end all be all. A good thing to know.
Yet another example of a number that a digital computer cannot represent exactly is .1. When converted to binary it becomes an infintly repeating decimal and must be rounded off.
You mean, "a binary computer" not "a digital computer". There are decimal computers (in, e.g., many calculators) that do not have this issue. (And of course they can be emulated even on binary computers, as in the Decimal type in C#.)
There are two different approaches to solving equations, graphically and algebraically. Graphically, we can see that the intersection of the graphs of sin(x)/x and x is at x=0, which is the solution to the equation (sin(x)/x) = x. This is because at x=0, the value of sin(x)/x is also 0.
However, when we solve algebraically by setting (sin(x)/x) = 1, we are essentially multiplying both sides by x, which can introduce extraneous solutions. In this case, x=0 is a solution to the equation (sin(x)/x) = 1, but it is not the only solution. This is why we see an infinitesimal, but nonzero, solution when we use this method.
It is important to understand the limitations and potential errors of different solving methods and to use them appropriately depending on the situation. In this case, the graphical method gives us a clear and accurate solution, while the algebraic method may introduce additional solutions that need to be carefully examined.
FAQ: Why Do Different Solving Methods Yield Different Results for (sin(x)/x) = x?
What is "A tale of two solving methods" about?
"A tale of two solving methods" is a story that explores the two main approaches used in problem-solving: the scientific method and the trial-and-error method. It discusses the differences between these methods and their effectiveness in finding solutions.
What is the scientific method?
The scientific method is a systematic approach to problem-solving that involves making observations, forming a hypothesis, conducting experiments, and analyzing data to draw conclusions. It is often used in scientific research and is based on empirical evidence and logical reasoning.
What is the trial-and-error method?
The trial-and-error method is an approach to problem-solving that involves trying different solutions until the desired outcome is achieved. It does not follow a specific set of steps and relies on trial and error to find a solution. This method is often used in everyday problem-solving situations.
Which method is more effective?
The effectiveness of a solving method depends on the nature of the problem and the individual using the method. The scientific method is generally more reliable and efficient for solving complex problems, while the trial-and-error method may be more suitable for simple problems or situations where time is limited.
Can these methods be used together?
Yes, these methods can be used together in problem-solving. The scientific method can provide a framework for conducting experiments and analyzing data, while the trial-and-error method can be used to test potential solutions. Combining these methods can lead to a more comprehensive and successful problem-solving approach.
