Why do double displacement reaction occur?
In summary: The net ionic reaction is AgNO3 and NaCl dissociates into ions in aqueous solution and forms the products mentioned above which are more stable than the reacting compounds.
Quotes
30
What's the reason for which double displacement reaction occur? Why there is a need for ion exchange between two compounds? They are already in a bonded state, a stabilised one. So what benefit would a double displacement reaction give?
The ionic reaction
AgNO3 +NaCl - - - - > AgCl(ppt) + NaNO3
(I think that due the reason that Eored for Ag is more than for Na the reaction must have occurred. But still it doesn't seem satisfying... Please explain. Thanks in advance.)
Chemistry news on Phys.org
Doesn't mean they can't bond better, getting more stabilized.
But your example is trivially wrong - it is not AgNO3 that reacts with NaCl. Write the net ionic reaction and you will see what is really happening.
AgNO3 and NaCl dissociates into ions in aqueous solution and forms the products mentioned above which are more stable than the reacting compounds. Is this correct?
It doesn't say anything about why - and how the situation described differs from - say - the mixture of NaCl and KNO3.
NaCl and AgNO3 are both ionic compounds capable of dissociation in water. So when aqueous solutions of both of these compounds are mixed you will have one contain of water which has Na+, Ag+, Cl-, and NO3- ions dissolved in it.
But wait, nothing is stopping these ions from interacting and colliding with one another in the aqueous environment. AgCl is not able to dissolve in water though, so when Ag+ and Cl- find each other, they stay that way as AgCl and crash out (precipitate).
The same dissociation happens when any two soluble ionic compounds are mixed. The difference is, do they for something that is insoluble in the environment they are in or not?
Related to Why do double displacement reaction occur?
1. Why do double displacement reactions occur?
Double displacement reactions occur because of a transfer of cations and anions between two reactants, resulting in the formation of new products. This type of reaction is driven by the exchange of ions, as they seek to form more stable ionic compounds.
2. What is the driving force behind double displacement reactions?
The driving force behind double displacement reactions is the formation of more stable ionic compounds. This is achieved through the exchange of ions between the reactants, resulting in the formation of new products with stronger ionic bonds.
3. How do you know if a reaction is a double displacement reaction?
A reaction is considered a double displacement reaction when the products formed are two new compounds, with the cations and anions of the original reactants switched. This type of reaction is also known as a metathesis reaction.
4. Can double displacement reactions occur with all types of compounds?
Yes, double displacement reactions can occur with all types of compounds, as long as they contain ions that can be exchanged. However, some compounds may be more likely to undergo this type of reaction depending on their chemical properties and reactivity.
5. What are some examples of double displacement reactions?
Some examples of double displacement reactions include the reaction between sodium chloride (NaCl) and silver nitrate (AgNO3) to form sodium nitrate (NaNO3) and silver chloride (AgCl), and the reaction between calcium hydroxide (Ca(OH)2) and sulfuric acid (H2SO4) to form calcium sulfate (CaSO4) and water (H2O).
