Why do gases absorb neutrons less readily than water?
In summary, gases typically have a lower neutron absorption cross-section compared to liquids due to their lower density and the ability of liquids to dissipate excess momentum through interactions between molecules. However, this does not apply to all gases and at certain energies, the cross-sections of liquids and gases may converge. Other factors such as pressure, temperature, and the molecular makeup of the gas can also affect its neutron absorption properties.
leila
Any ideas on the above question?
Leila
I would guess it's because of the same reason that a table is better than catching a drop of water than a net.
I would think the issue has something to do with getting the momentums and energies to match. In a gas, I'm guessing that one can model the neutron / atom interaction a single atom at a time. The result is a difficult reaction because you have to match up the momentum and energies beforehand with the momentum and energies afterwards. That is very restrictive.
For a liquid, the target atom is not alone so the momentum can be got rid of by exciting other atoms.
Maybe thinking about the same situation in playing pool on an infinite pool table would help. With a gas of object balls, it is very easy to end up just touching one. But if there are so many object balls that they are bouncing against one another, then it is possible to quickly get rid of the excess momentum that happens when your cue ball comes in.
Carl
Well that actually depends on the gas. He4 is a very stable nucleus, 2 protons and 2 neutrons in a very stable configuration. So it effectively does not absorb neutrons. On the other hands, He3 interacts non-elastically with neutrons (n,p) with a microscopic cross-section of about 5330 barns. In fact, in certain transient fuel experiments, coils of He3 are used just prior to the test to shield the test rod.
Xe135 has a very high thermal micrscopic cross-section for n-capture 2.647E+6 barns! http://wwwndc.tokai.jaeri.go.jp/cgi-bin/Tab80WWW.cgi?/data2/JENDL/JENDL-3.3prc/intern/Xe135.intern
http://wwwndc.tokai.jaeri.go.jp/cgi-bin/nuclinfo2004?54,135
The other part of this phenomenon is the macroscopic cross-section vs microscopic cross-section.
Each atom has an energy-dependent microscopic cross-section ([itex]\sigma[/itex]) associated with it. The microscopic cross-section is the interaction rate per atom in a target per unit intensity of the incident beam, and in a sense is a probability of interaction. It's unit is the barn and 1 barn = 10-24 cm2.
Multiplying the microscopic by the elements (isotopes) atomic density yields the macroscopic cross-section ([itex]\Sigma[/itex]). The macroscopic cross-section is simply the probability of interaction per unit length of distance traveled by a particle, e.g. a neutron. See example calculation of macroscopic cross-section here - http://www.tpub.com/content/doe/h1019v1/css/h1019v1_117.htm
The density of gases is about 2 or 3 orders of magnitude less than water, which is usually pressurized.
In the orignal question, is density being taken into account? Gases can be made of many different substances, for example steam, which has the same neutron interaction properties as water, but being much lower density, requires more volume.
It's not that simple. See fig 1. from the following paper, which shows that liquid H2 and gaseous H2 have very different cross sections, though the cross sections approach one another at high enough neutron energies:
http://ucn.web.psi.ch/papers/PhysRevLett_94_212502.pdf
Note that the above are total cross sections (most of which is scattering), and not absorption cross sections.
By the way, I read the OP's question as having to do with the phase difference for the target, and replaced "water" with "liquid", so the comparison is of one phase with another for the same target molecule. Otherwise the question doesn't make a lot of sense.
Carl
Lets just say its pressure, temperature, cross section and molecular interaction dependant (in stat mech they call this a potential) and thus complicated =)
But I tend to agree (grossly) with Astronuc in general.
Carl
Carlb: Since that paper is dealing with 'cold' and 'ultra-cold' neutrons, I agree with your assessment of why the cross-sections of liquids and gases are different at those energies. The neutron wavelength is large enough at those energies to interact with multiple atoms rather than just a signle one. Solid carbon-12, for example, has a lot of resonances in its scattering cross-section around 5-10 meV where the neutron wavelength matches up with the spacing of the atoms in the crystal lattice. I could see how it's possible that, even after you correct for density, material of different phases could have different cross-sections. At higher energies, I would expect the cross-sections to converge.
I'm not 100% certain if that's what the OP was after though. If the question is why gases, in general, have a lower cross-section that liquids, then I like what astronuc said: they don't necessarily, once you correct for density.
It is that straightforward, although the calculations are not necessarily trivial.
Each nuclide (isotope) has a unique microscopic cross-section as a function of energy. Given the same isotopic composition and therefore same effective microscopic cross-section, gases have much lower atomic (molecular) density than liquid, say at room temperature to about 300-347°C and under pressure, and therefore lower macroscopic cross-section than liquids.
One has to 'know' the neutron energy spectrum (which is determined by the degree of 'moderation', which is a function of the core materials and their composition) and collapse the microscopic cross-sections, and use the 'appropriate' atomic densities to calculate the appropriate macroscopic cross-sections.
One does have to consider molecular structure at or near 'thermal energies', because molecular dynamics does play a role in the relative speed of neutrons and absorbing materials.
I am thinking the OP is addressing power reactor conditions, rather than 'cold' and 'ultra-cold' neutrons.
Related to Why do gases absorb neutrons less readily than water?
1. Why do gases absorb neutrons less readily than water?
Gases, by definition, have widely spaced molecules and atoms that are not as tightly packed as those in liquids or solids. This means that there is more space between the molecules for neutrons to pass through, making it less likely for them to be absorbed.
2. How does the molecular structure of gases affect their ability to absorb neutrons?
As mentioned, gases have widely spaced molecules and atoms, which means there is less surface area for interactions with neutrons. In comparison, liquids and solids have more closely packed molecules, providing a larger surface area for interactions and increasing the likelihood of neutron absorption.
3. Are there certain types of gases that are better at absorbing neutrons than others?
Yes, some gases, such as helium and hydrogen, have lower atomic numbers and fewer electrons, making them less likely to interact with neutrons. In contrast, heavier gases like xenon and krypton have more electrons and are more likely to absorb neutrons.
4. Does temperature play a role in the ability of gases to absorb neutrons?
Yes, temperature can affect the ability of gases to absorb neutrons. As temperature increases, the molecules of a gas move faster and become more spread out, making it less likely for neutrons to be captured. This is why gases are often used as coolants in nuclear reactors.
5. How does the pressure of a gas affect its ability to absorb neutrons?
The pressure of a gas can also impact its ability to absorb neutrons. Generally, at higher pressures, the molecules of a gas are closer together, providing a larger surface area for interactions with neutrons. This means that higher pressure gases may be more effective at absorbing neutrons compared to lower pressure gases.
