Why do I always get 0 values in the radiation part? (MCNP5)
In summary, the MCNP output provides data on various parameters such as energy, stopping power, range, radiation, beta**2, density, rad/col, drange, dyield, and yield for different particles (n, mev). The data shows that as the energy of the particles increases, so does the stopping power, range, and radiation. However, the beta**2, density, rad/col, drange, dyield, and yield remain constant. The output also includes collision and total radiation values for each energy level.
  • #36
PSRB191921 said:
no gridconv in in the bin folder and mdata in the files folder
I got such error in separate folder.mdata and gridconv are in separate folders
  • #37
first you can run mcnp :
MCNP6 i=SPCr.txt o=SPCr.o mdata=meshbinary
second run gridconv
at the question "Enter name of input file" put "meshbinary"
at the question "what do you want to name your file" put "meshascii.txt"
Normally a file name meshascii.txt is created: it is the result !
Likes emilmammadzada
  • #38
second run gridconv
The application gave an error again
  • #39
you must bin in 32 bits try meshbin instead of meshbinary (too long)
  • #40
it was the same again
  • #41
what is your input file ?
  • #42
This
  • spc.txt
  • #43
strange no problem for me
  • Skeptical
  • #44
Could the method be different in mcnp5?
  • #45
and if you run
MCNP5 i=spc.txt o=spc.o
  • #46
Now it's been like this
  • #47
of course ! MCNP5 does not transport proton !
you must try with MCNPX or MCNP6 !
  • Sad
  • #48
Unfortunately I don't have mcnp6 (
  • #49
so you can't. Only MCNPX or MCNP6 can transport protons
  • #50
I was just starting the mcnp application. So I don't have much information about the application and I wanted to learn.(
  • #51
I wrote mcnpx instead of mcnp5, something like this happened
  • #52
yes it will be ok because MCNPX transports proton
  • #53
Now which app is mine mcnp5 or mcnpx?))
  • #54
both
  • #55
PSRB191921 said:
both
I wish I could solve this gridconv problem too, it would be great for me
  • #56
I think that has been solved. Before you were putting your input file into gridconv, not the mdata file produced by mcnpx. It is fine to put the mdata file in the same directory as gridconv.exe but if the exe is in your bin directory with mcnpx.exe it should work. You must be in the directory where the mdata file is before you run gridconv.
Edit,
At the point gridconv asks 'Do you wish to continue?' you can hit enter for 'no' because at that point the text file has been created. Then you can hit return again to exit the program.
Likes emilmammadzada and PSRB191921
  • #57
Edit,
yes the app worked correctly.
  • mehbinascii.txt
Likes Alex A
  • #58
Thank you very much for helping me on these matters.
  • #59
PSRB191921 said:
both
Likes PSRB191921 and Alex A
