Why do I see stars as a point in the sky?
In summary: W light bulb at a distance of 1 km with a 100W light bulb at a distance of 10 km. The light from the closer light bulb will be about 4 times as bright as the light from the more distant light bulb. However, the light from the closer light bulb will only be seen as bright if you are right on top of it! The light from the more distant light bulb will be seen at a much greater distance.In summary, the limiting factor for how far away you can see a star is the resolution of your eye and the distance to the star. The farther away the star, the smaller the angle at which the light can enter your eye and the dimmer the star appears.
oneamp
219
The light from stars radiates out from them as a sphere. When a part of the surface of the light sphere reaches the earth, it is far enough away from the star so that each point on that part of the surface of the sphere near the Earth has about the same light energy. But, I only see a point, not what I presume that part of a sphere would look like (filling the entire sky.) Why is this?
Thank you
Thank you
Only the photons pointed directly at you enter your eye where you can see them. You're correct in that there is an expanding sphere of photons from the star spread out over the whole Earth (and beyond). But the photons from the same star that land in your neighbor's back yard or across town don't enter your eye so you don't see them.
Why do you presume that?
Thank you
The reason that you see all stars as 'points' is that your eye has only a finite resolution (much smaller pupil than even cheap bino's). There is no way that your eye can distinguish which side of a distant star the light is coming from so you just see a tiny blob of light.
You can see many of the planets as actual discs because they subtend a big enough angle - even Venus looks like a 'little Moon' because it is a big enough object.
Any optical system (telescope) has a finite resolution and even the nearest stars are still registered as points, afaik. The advantages of a larger aperture are twofold - firstly, the light gathering is much greater so you can see fainter objects and secondly, the larger the aperture, the better you can resolve what looks to the eye as a bright blob / point into two or more objects. Because of the resolution of your eye, a brighter star may look bigger, because more of your receptors get enough light to register that something is there.
PS @oneamp You need to distinguish between thinking about light spreading out from a source (On a cone or over a sphere) and the cone of light that your eye accepts. Your eye only intercepts a tiny proportion of the light output from a star (yes - that's obvious) and the star only occupies a small proportion of your total field of view (that's obvious too - but some of your question seems to be conflating the two ).
Google suggests that you can see stars that are perhaps 1500 light years away with the naked eye. So the light from these stars is spread out over an enormous sphere of that radius...yet still enough photons arrive at your eye.
The fact is that our visual perception is pretty well logarithmic and we perceive an amazing range of contrast - from individual photons to almost direct sunlight (1kW per sq m - but that will harm your retina, of course, if sustained). This Wiki article discusses the factors governing the visibility of stars. If you bear in mind that only the very biggest / brightest stars at great distances are visible to the naked eye and that, to see them, you need to be young and fully dark adapted (no light pollution), the actual numbers are likely to be in the right ball park. (I am ignoring red shift, here but 1500LY is really pretty close in cosmological terms).
If you double the distance of a source, you are 'only' reducing the perceived brightness by a factor of four. This is the same, whether going from 1 km to 2 km or from 750LY to 1500LY. This "6dB reduction by doubling the distance" is a bit counter intuitive but it accounts for how the feeble radio transmissions (a very few Watts) from the deepest space probes can still be detected. Compare this with the sort of losses you get through a medium like glass (or RF cables) where the loss (in dB) is proportional to the distance. A cable to the Moon would never work - let alone a cable to a nearby star.
This should put it into perspective.
Alpha Centauri A is 4.37 LY or 4.13x1016 meters from us. I'll assume that the diameter of Alpha Centauri A is similar to our sun (1.39x109 meters). Using similar triangles to calculate the diameter of a disc that is one meter away yields
X / 1 = 1.39x109 / 4.13x1016 meters
X = 3.36x10-8 meters
The best that the human eye can discern is a fraction of a millimeter, say 1x10-4 meters. Alpha Centauri A is four orders of magnitude smaller than what our eyes can pick out, relative to the disc that is one meter from our eyes.
Space is VERY VERY big.
That figure refers to 'resolving power' or ability to separate a blob into two distant objects. Actually 'seeing' the star just depends upon the amount of light power entering the eye. What you actually see could be a whole bunch of stars, close together.
But, light from the distance greater than 1500 light years can reach us. Isn't it?
Larger objects, such as the galaxy in Andromeda, are much further away - yet we can still see them. This is because they contain many stars - perhaps 100 billion stars, and 2 million light years away.
So it is about the amount of light; the light from a single star is too faint for the human eye to see; the ancients documented about 3,000 stars - that's about how many you can see from one point on the earth. Double that if you travel a lot!
Hence telescopes that track the motion, forming an image over time.
Consider the following picture, in which laser is placed in a dark room. Though, laser is unidirectional, one can see it. The reason I might assume must be because of the scattering of light by the dust particles coming in its way (related to tyndall effect).
One must observe here that the intensity of light reaching us, is the least of the total intensity. From this, I prefer saying that even a mere intensity of light coming from the star is enough to see it.
Of course you are right. It was just an example, involving a large distance. A star, four times brighter, would be visible at 3000LY.
I am under the impression that, even a star which is not brighter as four times the original, will be visible to us. Read my last post in this thread, to know why I think so.
Related to Why do I see stars as a point in the sky?
1. Why do stars appear as points in the sky?
Stars appear as points in the sky because they are extremely far away from Earth. Their distance causes them to appear very small, and our eyes are not able to distinguish their size, making them look like points of light.
2. Why do stars twinkle?
Stars twinkle because of the Earth's atmosphere. The atmosphere is constantly moving, which causes the light from stars to bend and distort as it reaches our eyes, making them appear to twinkle.
3. Why do stars have different colors?
The color of a star depends on its temperature. Hotter stars appear blue or white, while cooler stars appear red or orange. This is due to the different wavelengths of light the star emits based on its temperature.
4. Can we see all the stars in the sky?
No, we can't see all the stars in the sky. The number of stars visible to the naked eye is limited by light pollution and the human eye's ability to distinguish faint objects. There are billions of stars in the universe, but we can only see a small portion of them from Earth.
5. Do stars move in the sky?
Yes, stars appear to move in the sky due to the Earth's rotation on its axis. This movement causes the stars to appear to rise in the east and set in the west, just like the sun does. However, stars also have their own movements and can appear to move in relation to other stars over time.
  • Astronomy and Astrophysics
  • Other Physics Topics
  • Art, Music, History, and Linguistics
