Why do most subwoofers work best in a corner?
  • Thread starter Loren Booda
  • Tags
    Work
In summary, the Klipschorn Principle uses the walls of the room as effective extensions of the speaker itself, which results in improved bass. This effect applies only to sub-woofer frequencies, and can be achieved with either a bookshelf speaker or a subwoofer placed in a corner.
Loren Booda
3,125
Besides reinforcing bass, doesn't placing a subwoofer in a corner disperse resonances more effectively throughout the room? If so, how?
I don't really understand everything that goes on, but the bass reinforcement thing is called the "Klipschorn Effect" or "Klipschorn Principle", after Paul Klipsch.
From http://www.arcticcorsair.f9.co.uk/audio/terminology.html#K
Book shelf speakers seldom have efficiency above one percent. For the Klipschorn (an invention of Paul Klipsch), it's something about 30%. The horn-loading makes it far more efficient, but the speakers really have to be big. The Klipschorn principle uses the walls of the room as effective extensions of the speaker itself. This effect applies only to sub-woofer frequencies.
Low frequency audio does not suffer from multi-path interference as much as mid and high frequencies do, because the wavelength is relatively long compared to the distance to the wall surfaces.
Sorry I couldn't offer more info, but that might get you started.
planish,
At least you have something to woof about! It is sometimes hard to find a room whose symmetry will accommodate Klipschorn speakers.
That's the beauty of the thing. You don't need Klipschorn speakers to take advantage of the effect. An inexpensive bookshelf speaker placed in a corner will have improved bass. Or (better yet) a single sub-woofer of any design, placed in a corner.
Whoa there...the instance of the Klipsch horn is different because it is a horn.
More generally, placing a standard monopole subwoofer in the corner as opposed to out in the room results in an increase in output for a couple reasons:
- when you place the subwoofer in the corner, you are dissipating the same power over a smaller area- notice a spherically diverging wave at a given distance in the corner has 1/8 of the surface area of one in freespace because you are radiating into 1/8 of the sphere
- the radiation impedance is higher in the corner thus increasing efficiency
- when placed in the corner, the subwoofer excites all modes in the room just as if you pluck a string at the very end, but in 3 dimensions
One thing to keep in mind is that although this does provide more output, because you are exciting all modes the frequency response will vary wildly throughout the room. If you are only concerned with sheer output, this may not be a problem, but if you want the sound to be consistent over a multi-person listening area, it probably will be. In that case other options may be more suitable.
If this has not been clear, please let me know and I will clarify. Perhaps you should check out this website http://www.kettering.edu/~drussell/demos.html to see some animations and get a feel for what I mean by "modes".
FAQ: Why do most subwoofers work best in a corner?
Most subwoofers work best in a corner because the corners of a room provide reinforcement to low-frequency sound waves. This is due to the corner acting as a waveguide, which amplifies the bass frequencies and produces a fuller and more powerful sound.
Is it necessary to place a subwoofer in a corner?
No, it is not necessary to place a subwoofer in a corner. While it may provide better bass response, subwoofers can still work well in other locations in the room. It ultimately depends on the acoustics of the room and personal preference.
Can I still get good bass if I don't place the subwoofer in a corner?
Yes, you can still get good bass if you don't place the subwoofer in a corner. Other factors such as the size and quality of the subwoofer, the positioning and orientation of the subwoofer, and the room acoustics can also affect the bass response.
How do I determine the best placement for my subwoofer?
The best placement for a subwoofer can be determined through experimentation. Start by placing the subwoofer in the corner and listening for the bass response. Then, move the subwoofer to different locations in the room and listen for any changes in the bass. Choose the placement that provides the best overall sound for your specific room.
Can placing a subwoofer in a corner cause distortion or uneven bass?
Placing a subwoofer in a corner can cause distortion or uneven bass if the subwoofer is not properly set up. It is important to adjust the subwoofer's volume, crossover, and phase settings to ensure a smooth and balanced bass response. Additionally, using multiple subwoofers can also help distribute the bass evenly throughout the room.
