Why do my sprites turn into black squares after I show an AdMob video?
  • Thread starter Thread starter Darkmisc
    Video
A game developed in Godot is experiencing an issue where sprites turn into black squares after playing a rewarded video ad using AdMob and Shin-Nil plugins. The user has attempted several troubleshooting steps, including changing the graphics backend, rendering mode, disabling VSync, and checking texture settings, but none have resolved the issue. There is speculation that the problem may stem from the plugin causing sprite data to be reinitialized or altering sprite pointers in memory. Users are encouraged to investigate potential side effects related to the plugin based on others' experiences.
Darkmisc
TL;DR Summary
I've made a game in Godot that works fine. However, after I play an AdMob video, all the sprites become black squares.
Hi everyone
I've made a game in Godot and added AdMob ads to it using the Shin-Nil plugins.
The game works fine when I run banner ads. However, after I play a rewarded video, all my sprites turn into black squares.
I've tried the following suggestions from ChatGPT and none of them work.
  1. Change the graphics backend. Go to Project > Project Settings > Rendering > Quality > Driver and try changing the graphics backend to a different one, such as GLES3 or Vulkan.
  2. Change the rendering mode. Go to Project > Project Settings > Rendering > Quality > Rendering > Mode and try changing the rendering mode to a different one, such as Spatial or 2D.
  3. Disable VSync. Go to Project > Project Settings > Rendering > Quality > VSync and disable VSync.
  4. Check your project settings. Go to Project > Project Settings > Rendering > Quality > Texture > Flags and make sure that the Filter and Mipmaps options are enabled.
Does anyone know why the videos are causing my sprites to turn into black squares?Thanks
Technology news on Phys.org
I would search with google. It’s well known that ChatGPT solutions are totally believable but highly unreliable. When they fail then you must search to find your answer.
the only thing I can think of is something reinitialized your sprite data to be all zeros or something changed the sprite pointer to another area of memory. Since you mentioned using a plug-in you should look for what side effects others have experienced with it in the past.
Likes phinds and Darkmisc
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
