Why do natural Moons revolve around planets?
In summary, moons revolve around planets because they are in orbit, which means they have a certain acceleration that balances out the gravity between them. The reason they do not crash with the planets is because they have enough initial velocity to maintain their orbit. This is similar to the trajectory of a cannonball being dependent on its velocity, with the only difference being the angle of depression. In cases where the initial velocity is not enough to maintain orbit, the object will either crash into the planet or go off into space. The force of velocity does not play a role in keeping objects in orbit, rather it is the balance between gravity and the object's own energy and angular momentum.
officialmanojsh
Why do Moons revolve around planets? If because of gravitational pull, why won't they clash with planets. Please help me get answer to this question!?
Astronomy news on Phys.org
Hi officalmanjosh,
Here's a picture of 'Newton's cannonball':
There are three trajectories depicted. In all three cases the gravity is pulling the cannonballs in towards the centre of the Earth.
And yet, trajectory C is not crashing onto Earth.
Can you tell us what you think is the main difference between the three? What makes B fall farther than A? What does the cannon do with the cannon ball?
Hello to you too Bannersnatch, the answer is Centripetal force. Even acceleration of ball C is correct. Am I right about why canon ball C today's like that.?
The only force acting on all three balls is the gravitational force. In the case of ball C this force will act as the centripetal force. But let's not get into that now.
Try and think of what makes ball B fall farther than ball A. What does the cannon do with the balls?
Angle depression of canon and force of which it shoots canon balls varies from ball a to b to c. Angle of depression of firing ball C is @horizontal line
Alright. Notice that the picture depicts (or at least should depict) the cannon as shooting at the same angle in all three cases. That leaves the 'force of a shot', or acceleration it imparts to the ball in the barrel.
Therefore, as the three balls leave the barrel and are no longer accelerated, they all have different velocities.
That's the only difference.
Can you now formulate the reason for the ball C not crashing into Earth, and similarly, the reason why satellites are not crashing either?
No. Although the scale of the picture makes it hard to see, in all three cases the cannonball leaves the cannon at the same angle (horizontal) and only the muzzle velocity is different. The slowest-moving ball (A) seems to making a steeper angle, but what's really going on is that because it's moving more slowly it doesn't travel as far left to right in the time that it takes it drop by a given amount as do the other two.
[edit: Bandersnatch beat me to it :) ]
It would be better if you finally say complete answer bro! ;)
Sorry, that's not how this site works (most of the time). We're here to help people understand physical concepts, and not being spoon-fed the answers is how people learn best. Getting there yourself is how you develop intuition.
If you want a straight answer, just type your question in google.
I hope I've got the answer. Hey Bannersnatch, is answer mass?
Hey am I right bandersnatch bro?
It's the same in all three cases.
So imagine that the moon is the cannonball. As it is introduced at some initial time into our system.
In cases A and B from Bandersnatch's diagram above, the moon crashes into the Earth and we all die. In case C, it falls into a nice orbit.
I would argue that there would even be a case d where the moon goes off into space and does not come back.
In all cases, the mass, angle, etc. are all the same, only one difference as stated in posts 7 & 8 is velocity.
Luckily air resistance in space is negligible, so the moon will likely continue to orbit for a while.
What force does velocity impart on an object?
That is the force that has to balance with gravity to keep it orbiting.
There is - with enough initial velocity the cannonball would head off into space on a hyperbolic trajectory.
This is incorrect. Velocity does not 'impart a force'. There is no force working against gravity to keep something in orbit. The object simply has to go fast enough so that as it falls it continually misses the ground.
Likes davenn
Something in orbit has lots of energy and angular momentum
Gravity preserves total energy and angular momentum
So something in orbit will tend to stay in orbit until acted upon by some other huge force
Related to Why do natural Moons revolve around planets?
1. Why do natural Moons revolve around planets?
The natural moons revolve around planets because of the force of gravity. A moon is attracted to a planet because of its mass, and as a result, it orbits around the planet.
2. Is there a specific reason for the direction of the moon's orbit?
Yes, the moon's orbit is determined by the direction of its initial velocity and the gravitational pull of the planet. If the moon's initial velocity is perpendicular to the planet's gravitational pull, it will have a circular orbit. Otherwise, it will have an elliptical orbit.
3. Can moons have moons?
Yes, moons can have moons, also known as "moonmoons" or "submoons." However, it is unlikely for a moon to have its own moon due to the complexities of gravitational forces and orbital stability.
4. How many moons can a planet have?
The number of moons a planet can have varies greatly. For example, Saturn has 82 known moons while Mercury has none. The number of moons a planet has depends on its size, distance from the sun, and formation process.
5. Do all planets have moons?
No, not all planets have moons. The inner planets, Mercury, Venus, Earth, and Mars, do not have any moons. The outer planets, also known as gas giants, tend to have more moons due to their larger size and stronger gravitational pull.
