Why do neutron stars have such powerful magnetic fields?
In summary, the insanely powerful magnetic field present in a neutron star is generated by the high tangential velocity of electrons, which is a result of the star's collapse into a smaller radius. The vast majority of the magnetic field does not originate from the neutron's spin, but rather from the motion of charged particles, including protons and electrons, in the interior of the neutron star. Despite a majority of the particles being squeezed into neutrons, the presence of protons and electrons keeps the star conductive and allows for the generation of a strong magnetic field. The electrons, which typically move faster than protons in this type of matter, likely contribute the most to the magnetic field.
Gevorg
The sources I've looked at claim the magnetic field is present because there are still some electrons in the neutron star.
Here is how I understand their reasoning: a star's radius significantly decreases when it collapses into a neutron star, ultimately decreasing its moment of inertia. In order to conserve angular momentum, it obtains a tremendous angular velocity. Thus the magnetic field is generated due to the high tangential velocity of the electrons.
Still, I am not convinced that the residual amount of surviving electrons is entirely responsible for the insanely powerful magnetic field. Although they lack charge, is there some other property of neutrons that allows them to contribute to the magnetic field? Could it have something to do with their dipole moments?
Thank you
I have little expertise in this area, but neutrons do have spin 1/2. The nuclear magneton ## \mu_N ## is about 1/1800 of the Bohr magneton, so that the magnetic field from a single neutron would be much smaller than that from a single electron spin. If the neutron density is high enough, and the neutron spins become aligned, the magnetic fields that are generated could be quite large. A very interesting question. I will need to google it and/or study the additional responses. ## \\ ## Editing: A google of the topic suggests the strong magnetic fields are caused by protons and electrons, (the neutron star also contains protons and electrons), that are in motion in the interior of the neutron star. The moving charged particles apparently generate most of the magnetic field. The vast majority of the magnetic field of a neutron star apparently doesn't originate from the spin of the neutron.
Likes Gevorg
The material in stars is relatively conductive. In a conductive fluid, the magnetic field lines are more or less "frozen in" to the fluid. This is known as Alfven's theorem. Since the units of magnetic field are a flux density (Webers per m^2 for example), as the radius of the star decreases, the magnetic field increase as 1/R^2. So if a star like the sun with a radius of ~ 1 million km collapses to a neutron star with a radius of 10 km, the magnetic field is increased by a factor of (10^5)^2 = 10^10. So the sun's magnetic field of 1 Gauss would increase to 10^10 Gauss. On top of this, many stars have much higher magnetic fields to begin with, and start with much larger radii. So it is fairly easy to get magnetic fields of 10^12 to 10^14 Gauss, or even higher.
Likes Gevorg and Charles Link
Thank you for the reply phyzguy. What I still don't understand is what continues to generate the magnetic field when a majority of the electrons and protons are squeezed into neutrons.
In the google, approximately 10% of the particles are still bare protons and electrons. Apparently they keep the neutron star conductive and allow for the processes that @phyzguy described.
Editing: A google of the topic suggests the strong magnetic fields are caused by protons and electrons said:
Thank you for the edit. I would think that the presence of protons would make the magnetic field weaker. Electrons and protons moving in the same direction generate magnetic fields in opposite directions; would they not cancel one another out?
Electric fields would cause these particles to move in opposite directions. In many plasmas, the electrons move much faster than the protons because of the heavier proton mass. Perhaps most of the magnetic field is due to electron motion.
Neutron star matter has very high electrical conductivity. I don't know all of the details, but not all of the matter is neutrons, and there are still a significant number of protons and electrons. And the density is so high that even a small fraction of the component particles being charged leads to a very high conductivity. This is an old paper, but they state:
"THE time for the magnetic field of a neutron star to decay by ohmic dissipation plays an important part in theories of pulsars1–3. The decay time for the lowest mode in a spherical star of radius R and of constant electrical conductivity σ is given by4,5 Previous estimates3 of σ(≈6×10^22s−1) lead to values of τD ≈ 4 × 10^6 yr for R = 10 km. This time is relatively short on the evolutionary time scale of pulsars. We show below that σ is at least six orders of magnitude greater than the estimate quoted above. Consequently τD is greater than the age of the universe, and flux decay in neutron stars is therefore completely negligible."
Likes Charles Link
FAQ: Why do neutron stars have such powerful magnetic fields?
Why do neutron stars have magnetic fields?
Neutron stars have magnetic fields because they are formed from the collapse of massive stars. During this process, the conservation of angular momentum causes the star's magnetic field to become compressed and intensified.
What makes the magnetic fields of neutron stars so powerful?
The powerful magnetic fields of neutron stars are a result of their small size and incredibly high rotational speeds. This combination creates a phenomenon known as "magnetic dynamo," where the rapid rotation generates and amplifies the star's magnetic field.
How do neutron stars maintain their magnetic fields?
Neutron stars maintain their magnetic fields through a process called "flux freezing." This means that the magnetic field lines are anchored to the star's surface and rotate along with the star, maintaining their strength and intensity.
Can neutron stars lose their magnetic fields?
It is possible for neutron stars to lose their magnetic fields over time. This can happen through a process called "decay," in which the magnetic field gradually weakens and dissipates. However, this process is very slow and can take millions of years.
How do neutron star magnetic fields affect their surroundings?
The powerful magnetic fields of neutron stars can have a significant impact on their surroundings. They can create intense radiation beams and trigger powerful phenomena such as X-ray bursts and gamma-ray bursts. They can also influence the behavior of matter in their vicinity, leading to the formation of accretion disks and jets.
