Why do oceans look blue from orbit?
  • B
  • Thread starter Warp
  • Tags
    Orbit
In summary, the blue in oceans comes from reflection of the sky. The atmosphere doesn't look deep blue from space, because it absorbs most of the light.
Warp
128
This is something that one seldom stops to think about, but I suddenly thought of it myself: Why do oceans look deep blue when photographed from orbit?
Oceans look blue when looked from the shore because they are reflecting the sky... But the atmosphere doesn't look deep blue when photographed from orbit! Surely if the atmosphere were deep blue when looked from this perspective, then eg. clouds would be heavily blue-tinted, yet they are white in all the photographs (with, perhaps, at most a very, very slight and faint bluish tint to them). Also all the land would look like looked through a blue filter.
If oceans are reflecting the sky and that's why they look deep blue from orbit, that would mean that the atmosphere looks deep blue only when looked from one side, but not the other. This seems incomprehensible.
Likes Greg Bernhardt
The reflectivity of the ocean is quite low (compare the clouds and the water in typical images) because most of the light energy is absorbed; what you see is the result of different levels of absorption for different wavelengths. Longer wavelengths are absorbed in water so the light that's backscattered from the oceans will be predominantly blue.
The atmosphere itself doesn't absorb much light so any effect is slight. The blue sky that we see from Earth is, in fact, not 'very blue'; it has plenty of the longer wavelengths in it (Research Rayleigh scattering) but, psychologically, we see the bluish colour as a strong blue.
Our appreciation of the colour is based on the context. Viewing from the surface, we see the sky with black space behind it. Viewed from space, the background (land and sea) is bright and it swamps any sensation of colour from the whispy atmosphere. This is a bit like the way a one way mirror works although it transmits the same amount of light both ways.
Likes FactChecker
When you are up close to the ocean as on a boat some waters have a define purple hue. Consider Homer's "wine dark seas"
So, water looks blue, because it's blue. Got it.
Uh ... if you fill a shallow pan with either fresh water or saltwater would you expect to see any blue?
If there was enough of it!
A block of ice looks blue, but not an ice cube...
That's as good a reason as any. Colour is totally subjective or we wouldn't be impressed by the feeble colours on a rainbow or a blue sky or the 'red' sunset. They would all measure as low saturation colours.
You don't need to dive to much of a depth in order to see the way red wavelengths are absorbed preferentially.
If it looks blue the object is reflecting bluer wavelengths into your retina. The pigments there are more responsive in this wavelength.
From space? Same thing I guess, blue green reflected redder longer absorbed
Related to Why do oceans look blue from orbit?
1. Why do oceans look blue from orbit?
The oceans appear blue from orbit due to the way sunlight interacts with the water molecules. Sunlight is made up of all the colors of the rainbow, but blue light has a shorter wavelength and is scattered more easily by the water molecules. This scattering causes the blue light to bounce off the surface of the ocean and be reflected back to our eyes, making the ocean appear blue.
2. Does the color of the ocean change depending on the location?
Yes, the color of the ocean can vary depending on the location. The amount of blue light scattered by the water molecules depends on the amount of particles and substances present in the water, such as algae or sediment. In areas with high concentrations of these particles, the water may appear greener or browner instead of blue.
3. Can the color of the ocean change over time?
Yes, the color of the ocean can change over time. Natural factors such as weather patterns, currents, and tides can affect the amount and type of particles present in the water, causing the color to vary. Human activities, such as pollution and climate change, can also impact the color of the ocean over time.
4. Do all bodies of water appear blue from orbit?
No, not all bodies of water appear blue from orbit. Lakes and rivers, for example, may appear different colors depending on the amount of sediment or algae present. In addition, bodies of water with high levels of pollution or human activity may also appear a different color from orbit.
5. Can the color of the ocean be seen from space without the use of satellites?
Yes, the color of the ocean can be seen from space without the use of satellites. Astronauts on the International Space Station have reported seeing the blue color of the ocean from their vantage point in orbit. However, satellites provide a more accurate and consistent view of the ocean's color and can capture images of a larger area at once.
  • Other Physics Topics
  • Astronomy and Astrophysics
