Why do reversible reactions occur in the first place?
In summary, reversibility in chemical reactions occurs due to the presence of a catalyst that provides an alternative route with a lower activation energy. The concentrations of the reactants also play a role, as seen in the example of a reversible reaction where the escape of a product leads to an irreversible reaction. However, under certain conditions, all reactions can be considered reversible. The transition state for a reverse reaction is the same as for the forward reaction, as molecules at the transition state can go either forward or backward. This is due to the principle of microscopic reversibility and the energy provided by thermal motion.
TheExibo
55
It is generally said that reactants react so that they can achieve a lower energy state. Then why does a reversible reaction occur in the first place?
If catalysts lower activation energy both ways in a reversible reactions by making the transition state less thermodynamically unfavourable, then why is it that the transition state sometimes decides to go backward to form the reactants?
Chemistry news on Phys.org
A catalyst provides an alternative route for the reaction with a lower activation energy." It does not "lower the activation energy of the reaction"..
The concentrations of the reactants is important ... if one of the reactants exits the system ...Ca CO3 + 2HCl → CaCl2 + H2O + CO2↑... here the CO2 escapes and the reaction is called 'irreversible' ... If the CO2 was retained in the reaction environment then the reverse reaction would also be occurring and equilibrium would be reached ,
I believe it's true that all reactions could be considered reversible under some conditions.
To put it another way ...in the reaction above , the solution will contain all the ions , bumping into one another and reacting , going in both directions ... the reaction which requires most energy input will occur less frequently.
Right but how can a transition state decide to go backwards? Or is a reverse reaction a completely different mechanism with a different transition state?
TheExibo said:
... but how can a transition state decide to go backwards?
I don't see why not ...it just requires a large input of energy from random molecular/ionic motion , this back reaction will be much more less frequent than the reaction going the other way.,,, effectively undetectable .
The reverse reaction proceeds with the same transition state. Remember that chemcial reactions are thermally driven, and thermal energy provides the energy to overcome the activation energy required. Molecules that at the transition state can either go forward or backward (in fact the transition state can be defined as the point in the energy landscape where 50% of the molecules will become product and 50% of the molecules will go back to being reactants. All of this comes from the principle of microscopic reversibility. (see also http://www.ilpi.com/organomet/microscopic.html)
Related to Why do reversible reactions occur in the first place?
1. Why do some chemical reactions go in both directions?
Reversible reactions occur because the products of the reaction can also react with each other to form the original reactants. This means that the reaction can proceed in both the forward and reverse directions until a state of equilibrium is reached.
2. What determines the direction of a reversible reaction?
The direction of a reversible reaction is determined by the relative concentrations of the reactants and products. If the concentration of the reactants is higher, the reaction will proceed in the forward direction, and if the concentration of the products is higher, the reaction will proceed in the reverse direction.
3. Can reversible reactions be influenced or changed?
Yes, reversible reactions can be influenced or changed by altering the conditions of the reaction. This can include changing the temperature, pressure, or concentration of the reactants and products. These changes can shift the equilibrium of the reaction towards the desired direction.
4. How do reversible reactions affect chemical equilibrium?
Reversible reactions play a critical role in establishing and maintaining chemical equilibrium. As the reaction proceeds in both the forward and reverse directions, the concentrations of the reactants and products will eventually reach a state of balance, where the rate of the forward and reverse reactions are equal. This is known as the equilibrium state.
5. What are the practical applications of reversible reactions?
Reversible reactions have numerous practical applications in various fields such as industrial processes, pharmaceuticals, and environmental science. In industrial processes, reversible reactions are used to produce desired products and increase reaction efficiency. In pharmaceuticals, reversible reactions are utilized to synthesize drugs and other chemical compounds. In environmental science, reversible reactions play a role in maintaining the balance of chemical compounds in ecosystems.
  • Materials and Chemical Engineering
  • Biology and Medical
