Why do some QM books start with Polarization?
In summary, textbooks that start off discussing polarization are probably using it to motivate the fact that particles have discrete angular momentum degrees of freedom and that only one polarization (or spin) axis can be measured at a time. These two facts combine to yield some puzzling outcomes. Suppose that light is sent through an x-axis polarizer so that all comes out either +x or -x polarized. Say we then block the -x polarization and let the remaining light pass through another x-axis polarizer. What comes out the other end? Unsurprisingly, +x polarized light. It gets spooky when you place a third polarizer oriented along a different axis in between these two. Suppose this third one is a z-axis polar
alexis12
I'm an undergraduate in Physics and just cracked open some QM books, some seem to start with polarization and a strange way of introducing operators, while others start with the wavefunction and then go into harmonic oscilators, then the hydrogen atom etc..
What does polarization have to do with QM?
The polarization of light is associated with the spin of the photon. Textbooks that start off discussing polarization are probably using it to motivate the fact that particles have discrete angular momentum degrees of freedom and that only one polarization (or spin) axis can be measured at a time. These two facts combine to yield some puzzling outcomes. Suppose that light is sent through an x-axis polarizer so that all comes out either +x or -x polarized. Say we then block the -x polarization and let the remaining light pass through another x-axis polarizer. What comes out the other end? Unsurprisingly, +x polarized light. It gets spooky when you place a third polarizer oriented along a different axis in between these two. Suppose this third one is a z-axis polarizer, so you've got x, z, x polarizers. Like last time, you block the -x coming out of the first. What comes out of the final polarizer? Both +x and -x. This is the essence of the nuttiness of quantum measurement: the intervening z-axis polarizer acts to "reset" the system.
You may have heard of the Stern-Gerlach experiment: it's the analogous setting for electrons and some books start with that.
It also happens to a be nice way to get students comfortable with bra-ket notation, understanding superposition of states, and learning about angular momentum operators.
Likes bhobba
A single photon goes through a certain type of polarizer (tourmaline crystal) either completely or not at all. A classical wave would not behave that way.
FAQ: Why do some QM books start with Polarization?
Why is polarization often the first concept introduced in quantum mechanics books?
Polarization is often the first concept introduced in quantum mechanics books because it is a fundamental property of light and it can be easily understood using classical physics. This allows readers to build a foundation of understanding before moving on to more complex quantum concepts.
How does understanding polarization help in understanding quantum mechanics?
Understanding polarization is important in quantum mechanics because it is a key aspect of the wave-particle duality of light. It also lays the groundwork for understanding the concept of superposition, where light can exist in multiple polarization states simultaneously.
What are some practical applications of polarization in quantum mechanics?
Polarization has many practical applications in quantum mechanics, such as in quantum cryptography, where the polarization of photons is used to encode and transmit information securely. It is also used in various imaging techniques, such as polarized light microscopy.
Are there different types of polarization in quantum mechanics?
Yes, there are different types of polarization in quantum mechanics, including linear, circular, and elliptical polarizations. These refer to the direction and shape of the oscillation of the electric field of light.
Can polarization be observed in everyday life?
Yes, polarization can be observed in everyday life. For example, polarized sunglasses reduce glare by selectively blocking certain polarization states of light. Some LCD screens also use polarization to control the orientation of light and produce images.
12K
