Why do Stirling engines have low power/weight?
In summary: There are in any case better engine cycles for practical power generation on larger scales .From my understanding, it might make sense for a land based fixed unit. However, larger engines would be more practical for portable applications.
Hercuflea
596
49
I have heard that Stirling engines are not in wide use because they have a low power-weight ratio. Why is this?
It would seem to me that the Beta type stirling engine (with 1 cylinder) would be very efficient because it only has like 3 major moving parts...flywheel crankshaft and piston and only one cylinder to wear out. I can't seem to find info about the total power output of the original stirling engine designed in the 1800s...anyone know this?
You are mixing a few different concepts. Stirling engines are efficient, but power to weight ratio isn't efficiency. Efficiency is power out divided by power in.
The reason they have a low power to weight ratio is that they use heat exchangers to move heat in and out rather than burning fuel, which carries energy more densely and releases it more quickly.
So why are Stirling engines still not in wide use in stationary/steady state power applications?
Low power to weight ratio --- really low --- means they are expensive to make and cumbersome to operate.
+1 on that . Also :
They do not scale up to large sizes very well . Multiple reasons but main one is that the gasses that can be used in practical versions are poor conductors of heat and it becomes more difficult to get effective heat exchange as the cylinder volumes become larger .
When deciding which engine cycle to use for an application theoretical efficiency is only one of many factors to be considered .
Just for interest : the Stirling cycle is used very effectively to produce liquid gasses : Stirling Cryogenics
So what would be the most practical external combustion engine?
I would think that the typical definition of "practical" requires choosing as an answer, the type(s) that are used in real life. Cars, for example, primarily use the Otto cycle since it is most practical for that application.
I guess to clarify...what would be the most practical external combustion engine for energy production? The Otto cycle is internal combustion.
Also, what do you think about the added benefits of Stirling and other external combustion engines in comparison to ICEs? I.e. Maintenance costs would be extremely low since none of the combustion products make contact with any lubricants.
Sorry, I missed the "external" part.
The most common for power applications is the Rankine* cycle.
*Autocowrecked fail corrected. Thanks @Merlin3189
Based on the Ivanpah Solar Power Facility, my guess is steam turbines.
https://en.wikipedia.org/wiki/Ivanpah_Solar_Power_Facility#Power_towers
The LPT 550 solar system produces electricity the same way as traditional power plants – by creating high temperature steam to turn a turbine.
For a land based fixed unit, it might make sense. From my research over the last hour, state of the art Stirling engines are 64 times more massive for a given output compared to automotive sized gasoline fueled engines.
Likes Hercuflea
Where were you able to find data about power output for medium-large sized Stirling engines? Everything I see on Google is just about tin can DIY engines.
The applications I have in mind are for small to mid scale power generation in remote/underdeveloped communities. I also think they could work well in cargo ships.
Is the power to weight ratio for a rankine cycle external combustion engine significantly greater than for a Stirling engine?
A few different places:
A Swedish company that makes them: SUNBOX FOR SOLAR PARKS
Provided me with an image that I grossly estimated the mass at 1000 kg. I may be off by +/- a factor of two or more.​
A paper written in Finnish: Utilization of Stirling engine vehicle use
Provided me with the thermal efficiencies of Stirling vs Other types of engines.​
et al, for ICE power to mass ratio​
I had to interpolate some of the data to come up with my "64 times" comment.
From the paper written in Finnish, I was able to extract that Sterling engines are roughly as thermally efficient as internal combustion engines. So given their power to mass ratio disparity, I'm thinking they are going to be only good for a very niche market/problem.
I don't even know what "rankine cycle" means. I'm a retired mail room clerk. Sorry!
jack action said:
Bwah! Hahahaha!
I watched the video, and they mentioned "improved fuel economy". Being somewhat old, I kind of remember what typical fuel economy was back then. So I skimmed through the rest of your links. I was not disappointed in my memory.
Phase I Results from the Stirling Powered Vehicle Project
Fuel Economy
Fuel economv for the Stirling-powered van in
the expediter mission was reported by the Air
Force to be 6.3 mpg with all fuels used during the
10-month evaluation period. Fuel economy numbers
include fuel usage for both the gas-fired, front window
defogger and the rear-compartment heating
system. This compares with an average of 4.3 mpg
for four gasoline-powered vans and 8.1 mpg for
nine diesel-powered vans used at Langley in similar
missions during the same period.
I suppose 6.3 mpg was good compared to 4.3 mpg.
Related to Why do Stirling engines have low power/weight?
1. Why is the power-to-weight ratio of Stirling engines lower compared to other engines?
The Stirling engine operates on a closed cycle, which means it has a fixed amount of working fluid and does not require a constant supply of fuel. This design results in a lower power-to-weight ratio compared to other engines that have a continuous supply of fuel.
2. How does the design of Stirling engines affect their power-to-weight ratio?
The design of Stirling engines, specifically the high-pressure and low-pressure cylinders, leads to a larger physical size and weight compared to other engines. The larger size is necessary for the Stirling engine to achieve efficient heat transfer and maintain a stable temperature gradient.
3. Can the power-to-weight ratio of Stirling engines be improved?
Yes, the power-to-weight ratio of Stirling engines can be improved through advancements in materials and manufacturing techniques. The use of lightweight and high-strength materials, such as carbon fiber, can reduce the weight of Stirling engines without compromising their structural integrity.
4. Are there any limitations to increasing the power-to-weight ratio of Stirling engines?
One limitation to increasing the power-to-weight ratio of Stirling engines is the trade-off between power and efficiency. Higher power output often results in lower efficiency, and vice versa. Therefore, engineers must carefully balance these factors when designing Stirling engines.
5. How does the operating temperature affect the power-to-weight ratio of Stirling engines?
The operating temperature greatly influences the power-to-weight ratio of Stirling engines. Higher temperatures result in better engine performance, but also require more complex and expensive materials and cooling systems. Therefore, engineers must consider the trade-offs between performance and cost when selecting the operating temperature for a Stirling engine.
  • Mechanical Engineering
12K
