Why do strong oxidizers and hydroxide not react with each other?
  • Thread starter ShawnD
In summary, hydroxide is a strong reducing agent, while most oxyacids are strong oxidizing agents. However, when placed in a strong hydroxide solution, these oxyacids do not react. Additionally, potassium nitrate and sodium hydroxide do not react, and sodium hypochlorite is made by bubbling chlorine gas into sodium hydroxide, indicating that hypochlorite does not react with hydroxide.
ShawnD
Hydroxide is a strong reducing agent, probably the strongest that can exist in water.
Oxyacids without the hydrogen are all strong oxidizing agents, but most oxyacids (all?), without their hydrogen, can be put in a strong hydroxide solution and nothing will happen. Oxidation of organics with potassium permanganate is often done in the presence of a strong base. Potassium nitrate and sodium hydroxide don't seem to react. Sodium hypochlorite is made by bubbling chlorine gas into sodium hydroxide, so obviously hypochlorite does not react with hydroxide, or it does at a rate so slow that it's almost nonexistent.
Shouldn't something happen between oxyacids and hydroxide?
Chemistry news on Phys.org
[tex]\displaystyle {OH^-}[/tex]
doesn't react with water to give
[tex]\displaystyle {H_2}[/tex].
What do you mean? Their coniugated base?
Not all.
[tex]\displaystyle {H_2SO_3, ~H_2CO_3, ~H_3PO_4,~H_3BO_3}[/tex]
are not (for example) and not even their coniugated bases:
[tex]\displaystyle {HSO_3^-, ~SO_3^{2-},~HCO_3^-,~\displaystyle{ecc.}[/tex]
Yes, an acid-base reaction :smile:
The reason why strong oxidizers and hydroxide do not react with each other is due to their opposite chemical properties. As mentioned in the content, hydroxide is a strong reducing agent, meaning it has a strong tendency to gain electrons and reduce other substances. On the other hand, strong oxidizers, such as oxyacids, have a strong tendency to lose electrons and oxidize other substances.
In the presence of a strong base like hydroxide, the oxyacid molecules are surrounded by a large concentration of hydroxide ions. These ions act as a shield, preventing the oxyacid molecules from coming into contact with other substances and oxidizing them. This is why, in most cases, oxyacids do not react with hydroxide.
Additionally, the reaction between oxyacids and hydroxide is thermodynamically unfavorable. The formation of a strong base like hydroxide from an oxyacid requires a large input of energy, which makes the reaction highly endothermic. As a result, the reaction between oxyacids and hydroxide is very slow, if it occurs at all.
In conclusion, the strong reducing nature of hydroxide and the strong oxidizing nature of oxyacids make them incompatible with each other. The presence of a strong base like hydroxide prevents oxyacids from reacting with other substances, and the thermodynamics of the reaction also make it unlikely to occur.
FAQ: Why do strong oxidizers and hydroxide not react with each other?
1. Why do strong oxidizers and hydroxide not react with each other?
Strong oxidizers and hydroxide do not react with each other because they are both highly stable compounds with strong chemical bonds. These bonds cannot be easily broken by the other compound, making it difficult for a reaction to occur.
2. Can strong oxidizers and hydroxide react under any conditions?
In some cases, strong oxidizers and hydroxide can react under extreme conditions such as high pressure or high temperatures. However, under normal conditions, they will not react with each other.
3. What happens if strong oxidizers and hydroxide are mixed together?
If strong oxidizers and hydroxide are mixed together, they will remain as separate compounds and will not undergo a reaction. This is because their chemical structures and properties do not allow them to react with each other.
4. Are there any exceptions to the rule that strong oxidizers and hydroxide do not react?
There are some exceptions to this rule. For example, in the presence of a catalyst, strong oxidizers and hydroxide may react with each other. Additionally, in some reactions involving organic compounds, strong oxidizers and hydroxide may react with each other indirectly.
5. Why is it important to understand why strong oxidizers and hydroxide do not react with each other?
Understanding why strong oxidizers and hydroxide do not react with each other is important in order to safely handle these chemicals. If they were to react with each other, it could result in a dangerous and potentially explosive reaction. Knowing how they behave and interact with other compounds can help prevent accidents in the laboratory or industrial settings.
