Why do the subsets in a partition have to be nonempty?
In summary, a partition of a set X is a set of nonempty subsets of X that allows for the definition of equivalence relations and integration, making it a useful and convenient convention.
Ragnarok7
50
"A partition of a set X is a set of nonempty subsets of X such that every element x in X is in exactly one of these subsets."
I was just wondering why the subsets must be nonempty. Is it just convention/convenient or is it because it would violate something else?
Thanks!
The empty set does not belong to any set of equivalence classes.
Thanks!
I think it's just a matter of definition.
Certainly, if you don't follow this, many results about partitions will need to be tweaked.
There is nothing mathematically wrong in including the empty set also when considering partitions but that is not how it has been done.
Partitions are used to generate equivalence relations on a set, and vice versa.
It is sometimes useful to consider partitions of the empty set itself; intuitively one feels that this partition should be unique, which is only possible if there are NO possible empty sets in a partition (convince yourself that this indeed comprises the only partition possible in the definition you gave for an empty set X).
Typically partitions are used to define a Riemann or Lebesgue integral.
For that to work, we need to be able to define a limit where the partition becomes infinitely fine grained, meaning each subset in the partition should be of size greater than or equal to $\varepsilon >0$.
In other words: not empty.
Wrong kind of partition: the kind the OP is talking about might be a partition into singleton subsets, which would be fine...but such a partition would be rather unsuitable for integration.
FAQ: Why do the subsets in a partition have to be nonempty?
Why can't the subsets in a partition be empty?
The subsets in a partition cannot be empty because a partition, by definition, is a collection of nonempty subsets that cover the entire set. If one or more subsets were empty, then they would not cover the entire set and the partition would not be valid.
What is the purpose of having nonempty subsets in a partition?
The purpose of having nonempty subsets in a partition is to ensure that every element in the original set is accounted for in at least one of the subsets. This is important for accurately representing the entire set and its relationships with its subsets.
Can a partition have subsets that are both empty and nonempty?
No, a partition cannot have subsets that are both empty and nonempty. As mentioned earlier, a partition must consist of nonempty subsets that cover the entire set. Having subsets that are both empty and nonempty would violate this requirement.
What happens if a partition has only one nonempty subset?
If a partition has only one nonempty subset, then it essentially becomes the same as the original set. This defeats the purpose of creating a partition in the first place, which is to break down the set into smaller, more manageable subsets.
Are there any exceptions to the rule that subsets in a partition must be nonempty?
No, there are no exceptions to this rule. The definition of a partition states that it must consist of nonempty subsets, and this rule must be followed for a partition to be considered valid.
