Why do water streams get thinner as they fall?
In summary, the task is to develop an equation for determining the radius of a stream of water below the faucet, taking into account the initial velocity and acceleration due to gravity. The relevant equations are the area of a circle, volume of a cylinder, and the equations for velocity and displacement. The initial velocity of the water is 7.67cm3/s and the faucet opening is .96 cm. The forces on a cylindrical section of the stream are being considered, along with the volume flow rate and its potential change with distance. Additionally, the relationship between downward velocity and cross sectional area is being examined."
goleynik
Develop an equation that will allow you to determine the radius of the stream (r) at any distance (y) below the rim of the faucet.
It would seem that the initial velocity of the water coming out of the faucet and the acceleration due to gravity have something to do with the radius of the stream at any point.
The only equations needed are :
Area of a circle,
Volume of a cylinder,
v=vo + at
y=yo + vy0t+ 1/2 at2
I solved for a faucet opening of .96 cm and determined that the water exits at 7.67cm3/sI don't even know if what I found is relevant but I am really stuck and any help would be greatly appreciated.
What are the forces on a small cylindrical section of a stream of falling water?
In terms of the cross sectional area of the stream and the downward velocity of the water, what is the volume flow rate of the water? Is the volume flow rate out of the faucet constant? Does the volume flow rate change with distance below the faucet? If the downward velocity of the water is increasing with distance from the faucet, what is happening to the cross sectional area?
Chet
Related to Why do water streams get thinner as they fall?
1. Why do water streams get thinner as they fall?
Water streams get thinner as they fall due to the force of gravity. As the water falls, it gains momentum and the force of gravity pulls it downwards, causing it to spread out and become thinner.
2. Does the height of the waterfall affect the thinning of water streams?
Yes, the height of the waterfall does affect the thinning of water streams. The higher the waterfall, the longer the stream has to fall and gain momentum, resulting in a thinner stream.
3. Are there any other factors that contribute to the thinning of water streams?
Aside from the force of gravity, other factors that can contribute to the thinning of water streams include wind, air resistance, and the shape of the waterfall. These factors can affect the trajectory and spread of the falling water.
4. Can the thinning of water streams be reversed?
In most cases, the thinning of water streams cannot be reversed. Once the water has gained momentum and started to fall, it will continue to spread out and become thinner until it reaches a surface or body of water.
5. Is the thinning of water streams a natural occurrence?
Yes, the thinning of water streams is a natural occurrence and is caused by the laws of physics. It is a result of the force of gravity acting on the moving water and is seen in waterfalls, fountains, and even raindrops.
15K
