mapa
- 29
Why does a wave go up and down? What forces cause waves to go up and down? In order for a particle to be a specific frequency would depend on what?
Forces push it up and down. Consider a spring-mass system. You start it by pushing it down and then releasing it. Then the spring provides the force to keep it oscillating.mapa said:Why does a wave go up and down? What forces cause waves to go up and down?
A particle isn't a wave, so the question makes no sense. What determines the frequency of a wave is the strength of the spring (the restoring force) and the magnitude of the mass (resistance to the restoring force).In order for a particle to be a specific frequency would depend on what?
Dav333 said:But what about a photon moving up & down? Is there a force pushing it up/down? Wouldn't the force run out after billions of light years travel? (sounds silly due to my lack of knowledge)
Do you mean the particle is not a wave because its got the wave/particles duality & sometimes acts more like particle than a wave & vice verse?
thanks
Waves have different frequencies because they are caused by different types of disturbances or sources. For example, sound waves are caused by vibrations in matter, while light waves are caused by electromagnetic radiation. These different sources result in waves with different frequencies.
Wave frequencies are determined by the speed at which the wave travels and the wavelength, which is the distance between two corresponding points on the wave. The frequency is calculated by dividing the speed of the wave by the wavelength.
The frequency of a wave is directly proportional to its energy. This means that as the frequency increases, so does the energy of the wave. This is why waves with high frequencies, such as gamma rays, have more energy than waves with lower frequencies, such as radio waves.
Yes, waves of different frequencies can travel at the same speed. This is because the speed of a wave is determined by the medium it is traveling through, not the frequency. For example, all electromagnetic waves, regardless of their frequency, travel at the speed of light in a vacuum.
Waves with higher frequencies have shorter wavelengths, which means they can interact with smaller objects and details. This is why higher frequency waves, such as X-rays, are used in medical imaging to see inside the human body. Lower frequency waves, on the other hand, can travel longer distances and are used for communication purposes.
