Why do we judge time by light?
In summary: From the perspective of the stationary person, the ball is going diagonally, so it takes longer to go from floor to ceiling. This is because the ball has a horizontal component of velocity in addition to the vertical component which becomes longer the faster the train moves.In summary, the conversation discusses the use of matter and light to keep track of the rate of time. While light is a constant in all reference frames and can be used to derive other measurements, such as time, there are other factors to consider such as the accuracy and precision of different types of clocks. The current definition of time is based on the oscillations of a cesium atom, but in the past, it was based on astronomical measurements and a
Wizardsblade
148
I have been trying to figure this out in my head and I just can’t make sense of it. Why don’t we use matter, i.e. an oscillating spring, to keep track of the rate of time? I know light has a constant velocity in all reference frames, but does that make it a better source for an accurate rate of time? Any ways this was just buggin me and I thought I would hear what all you guys had to say. Thanks.
Put your mind at ease. Matter, such as an oscillating spring, is used to keep track of the rate of time. Light is not used.
Einstein uses light as a constant when he proves length contraction and time dilation doesn't he? I.e. if there is a light source L meters from a mirror it will take L / c seconds for the light to make the trip. Then from 2 reference frames d (distance the light traveled) and d' can be measured. If I’m not mistaken (which I am frequently) this setup constitutes a basic clock. If he would have used a spring when proving contraction and dilation there wouldn't be special relativity.
He starts off saying the laws of physics are the same in all inertial reference frames. This leads to light being constant, which can then be used to derive the rest.
X
jackle said:
He starts off saying the laws of physics are the same in all inertial reference frames. This leads to light being constant, which can then be used to derive the rest...
This is the first postulate of special relativity, what leads to a Lorentz type transformation, not the actual Lorentz transformation.
jackle said:
...This leads to light being constant, which can then be used to derive the rest.
The speed of light being constant is an experimental fact, and is not explained by the first postulate. There are sevreral facts that could be taken as "second postulate", e.g. the famous E=mc^2. The laws of physics could be the same in all inertial reference frames and even speed of light different in any inertial frame, what would lead to a modification of _Maxwell laws, for example.
How does that make a clock? Do you intend to stand there with a stop watch or something and time the light beam? The spring in the watch is what is measuring time, not the light beam.
The current acutal definition of time is a certain number of oscillations of a cesium atom. (This has been in use since 1967).
see for instance
http://simple.wikipedia.org/wiki/SI
This is not exactly a spring, but it is very close to a quantum equiavalent to it. A spring-mass clock will give very similar results, but with much less precision, since atoms are all identical and springs are not.
For the units and defintions used when Einstein was formulating relativity take a look at
http://physics.nist.gov/cuu/Units/history.html
After the establishment of the Meter Convention on May, 20 1875 the CIPM concentrated on the construction of new prototypes taking the meter and kilogram as the base units of length and mass. In 1889 the 1st CGPM sanctioned the international prototypes for the meter and the kilogram. Together with the astronomical second as unit of time, these units constituted a three-dimensional mechanical unit system similar to the CGS system, but with the base units meter, kilogram and second.
Thus you will see that the second, in Einstein's time, the primary standard for time was based on astronomical measurements, and that the meter was based on a standard prototype bar in Paris.
These were the defintions of units when relativity was formulated, and relativity applies to measurements in terms of these units, as well as more modern and accurate systems of units, which have changes as we have found more accurate ways to measure both time and distance (see the first wikipedia URL or the NIST site for current SI standards for time and distance).
Spring clocks have absolutely nothing at all to do with the problem, I really have no idea why you think they would.
This is true. I'm going to bed.
:cry:
Einstein used the following reasoning:
1) given the postulates, you can build a perfectly working clock with light rays
2) we can calculate what this clock would show when it is moved
3) since different types of clocks must change the same way with velocity, we can indirectly calculate what every type of clock would show - that is: time.
of course you can use any clock you like, but afaik you can derive SR only from light clocks. That´s enough, because all sorts of clocks must agree.
You don't need a watch, you just count how many times the light has bounced back and forth compared to a pre-defined interval that that represents, a la pervect's statement that a second is defined as a specific number of "oscillations" of a cesium atom. You could do the same thing with a bouncing beam of light. You don't measure the oscillations, you just count 10 and define that 10 oscillations=1 second.
What is wrong with this argument?
Let a train be moving with velocity [tex]u[/tex] relative to a "stationary" person. Let one tick of a clock be when a ball, with a constant velocity [tex]v[/tex] (we ignore gravity) relative to the train, goes from the floor of the train to the ceiling which is [tex]d[/tex] meters. Relative to the train, its measurement of time [tex]t = d/v[/tex]. Relative to the stationary frame, the ball travels a distance of [tex]d'=\sqrt{u^2t'^2+d^2[/tex] with velocity [tex]v'=\sqrt{u^2+v^2}[/tex]. So the time [tex]t'[/tex] relative to the stationary frame is [tex]t'=d'/v'=\sqrt{\frac{u^2t'^2+d^2}{u^2+v^2}}=\sqrt{\frac{u^2t'^2+v^2t^2}{u^2+v^2}}[/tex]
So [tex]t'^2=\frac{u^2t'^2+v^2t^2}{u^2+v^2} \rightarrow t'^2(u^2+v^2)-t'^2u^2=v^2t^2 \rightarrow t'=t [/tex].
Therefore, since the laws of physics are the same in every reference frame, time is the same as well.
The problem with this argument is that the velocity of the ball is not v' = sqrt(u^2+v^2) at sufficiently high velocities.
Note that the speed of light was observed to be constant before the idea of keeping time with a "light clock" was proposed. Until the speed of light was shown to be constant, there was no reason to propose using a light clock to measure time.
Just a quick note on timekeeping in Einstein's time. (No pun intended). While the primary standard for time in 1905 was astronomical time, chronometers were aparently used as a secondary standard.
http://earlyradiohistory.us/1905tim.htm
talks about how the US Naval observatory used a Frodsham clock (exact details of operation unspecified, but was probably a balance wheel) that was frequently reset based on astronomical events (the primary time standard).
Frodsham has a website, but no information :-( - other sources indicate they were apparently highly respected clock-makers of the time, Frodsham being able to boast that their company made the clocks for the Queen of England.
For the purposes of relativity, the primary astronomical time standard would not be particularly useful, as one cannot accelerate the entire solar system. Instead, one would have to rely on secondary time standards, like chronometers of the period, to measure the passage of time on a moving object.
Quartz clocks apparently did not appear until the 1930's, according to
http://inventors.about.com/library/weekly/aa072801a.htm, and from a later page in the same source, atomic clocks first appeared about 1949 with an amonia based clock from the National Institute of Standards.
Pendulum clocks were also used in the period, and were among the most accurate clocks available in the 1900's according to this article, even as late as the 1920's. According to the first URL, however, the US Naval Observatory (USNO) did not use pendulum clocks on a routine basis in 1905, though apparently some pendulum clocks were in experimental use. Although accurate, pendulum clocks would probably not be suitable for use in a moving environement - the ship chronometer of the period would be best suited to any application that was not in a stationary, vibration-isolated room.
That's as much as I could find out with a bit of googling - I'm not by any means an expert on history.
Rebel said:
...The laws of physics could be the same in all inertial reference frames and even speed of light different in any inertial frame, what would lead to a modification of _Maxwell laws, for example...
What are the consequences in such a universe? Is it self consistent?
:rolleyes:
I guess it would be a long way from our own...
Isn't time just a measuring unit?! there is no real such thing as time, it is concentric/circular. Hence God saying he is alpha and omega. The reason we cannot fathom eternity is because of the way we've been taught to believe what time is. We always measure it in a straight line. Motion and energy. What happens if you have no motion or energy to measure? If light ceases to exist in the universe, does time? I don't know what physics says about this yet.. but it seems like quite the illusion to me at the moment.
Your best taking this to the philosophy forums. Time is real, a measurement is real, therefore time is real. If time doesn't exist, then how can it be circular? Something isn't inheriently a circle if it doesn't exist. And when God said he was the alpha and the omega, it ment a beginning and an end, there is no beginning or end if time is a circle.
What makes you think we can't fathom eternity? And we don't always measure time in a straight line, their are many theories that deal with circular time.
Measuring what? Be more specific. Presumably if there is no energy or motion in a system, you will measure zero velocity and zero energy.
Yeah, well stop being so philosophical for a second, look at the fact and you'll see the obvious conclusion.
No, seconds are a unit, time is a dimension like the three spatial dimensions, and it is, most certainly, real.
I agree, a question about "what is real" is definitely a philosophical question, not a scientific one.
thanks for your guys feedback. You're right, but i don't get this last post... science is about what is real. We wouldn't even have science without questioning. We wouldn't even have physics, remember how Einstein came to his conclusions? Pure brainstoriming about what is real. Philosophy and science have to work together.
No, he brainstormed about things that are real, he didn't brainstorm over whether or not they are real, like you are.
I think the question "Is time real" is more a philosophical question, but a very fair and interesting one to ask in philosophy.
What IS a scientific issue that has been answered clearly is to know that any statement about the time of an event in the universe has absolutely no meaning independently. The time of an event must reference a location (a reference body in space in motion) to have any meaning.
My limited understanding is that that's one bottom line about time.
Eon.
This was my original preponderance. Light was shown to have a unique property (constant velocity in all internal reference frames), so why did we decide to use it as a clock? We knew it didn't follow the usual propagation rules of matter... If Einstein had used eok20's ball for a clock, why couldn't he have said that light has unique properties? This would lead to a time and space constant relativity.
Science is about what we can measure, and how to predict the outcome of experiments.
We know how to measure time, so it's a suitable subject of the investigation of science, regardless of whether or not it's "real".
I would say that scientists, as a whole, tend to be realists, because some philosphical positions don't expect the universe to be predictable and understandable. Since the goal of science is to predict and to understand the universe, one would expect that scientists would have a philosophy in which this was possible. Of course, this is somewhat of a meta-philosophical point, a philosophy about philosophies.
As far as time goes, one can regard it as fundamental, which relativity, being a classical theory, does, or one can perhaps take the view that time is only an approximation, valid over large distance scales, something that doesn't work at a small enough scale - i.e. time might be like Wheeler's quantum foam. I gather that this is how at least some string theorists view time, though I'm not terribly familiar with string theory.
The problem is that just assuming that time _could_ be an emergent phenomenon based on other more fundamental phenomenon is not sufficient to make predictions, thus it is not a scientific hypothesis. Remeber, the goal of science is to make predictions, not to engage in endless philosphical arguments.
If you accept that time as measured by clocks is useful in everyday life, it becomes worth studying, regardless of ones philosophy about what it "really" is.
The first reply answered your question. We DO use matter to measure the rate of time...
Light is NOT used to define time... Time is time. And light happens to go at the same speed in all inertial frames (in terms of that time). If we didn't already have a notion of time we wouldn't even be able to say that light has a constant speed in all inertial frames... If time is only defined in terms of the speed of light, then "the speed of light is constant in all inertial frames" turns into a truth by definition, and not an experimental truth. The concept of time is independent of the speed of light. And through experiment and observation we find that light has a constant speed in all inertial frames in terms of this notion of time that we ALREADY have.
The laws of physics are the same in all inertial frames... Suppose we have a digital clock that passes from 2:00 to 2:01 in some inertial frame (suppose it is at rest). So 1 minute passes.
Now we put the digital clock in a spaceship going at some speed v... we reset it at 2:00... now inside the spaceship the clock passes from 2:00 to 2:01... Now how much time has passed inside the spaceship? By the principle of relativity... everything should be exactly the same during the physical process of the clock going from 2:00 to 2:01... So if 1s passed when the clock was at rest... then 1s passed inside the spaceship... since we've repeated exactly the same experiment in the spaceship.
Time is intrinsically connected (sort of by definition) to physical processes... a unit of time measures how long a physical process takes... The same physical process (such as a digital clock going from 2:00 to 2:01) in a different inertial frame by definition takes the same amount of time within that frame.
We could redefine time... but why do so? There is no reason. And when we're on the spaceship it still feels to us like 1 minute passes when the clock passes from 2:00 to 2:01 (what we feel is identical I suppose because the physical process in our brains is identical). So it doesn't make sense to me to define time differently when we're in a spaceship as opposed to at rest.
So to answer your question... time is already defined independent of the speed of light...
Please correct me if I'm wrong here... Although the principle of relativity is an experimental truth... with regards to time it could be taken as a truth by definition of sorts: "Time is defined identically in all inertial frames." So if 1 min is defined as the time a digital clock takes to go from 2:00 to 2:01 in the rest frame... then 1 min is also the time it takes for the digital clock (now at rest in a moving frame) to go from 2:00 to 2:01 in the moving frame.
It seems mighty inconvenient to redefine time when you're in a different inertial frame. I don't think there's anything theoretically wrong with doing it, but it seems impractical. You'd have to pick some absolute frame, and go from there...
huh? Can i just ask a few questions here... Yes he did brainstorm about what was real.. because it wasn't real before he came along. First he brainstormed, then he proved it.
[Quote pervect]"We know how to measure time"
We don't know how to measure time... time is what we use to measure what we see. Time IS the measurement... this is what I'm trying to get at. I just feel like there is something more... I'm trying to figure out what it is, and it's something only I can do on my own, because i don't think anyone else understands me. I think there is a better way to truly understand what time is aside from numbers.
learningphysics said:
If time is only defined in terms of the speed of light, then "the speed of light is constant in all inertial frames" turns into a truth by definition, and not an experimental truth. [/tex]
I don't dissagree with you, but could you agree that Time Dilation is definded in relativity, i.e. rate of time is definded to be nonhomogenious throughout space/time.
[/tex]
We already have a notion of time, but when Einstien uses a light clock in his thought expirements instead of a pendulium (or other matter based clock) is it possible that the (at that time presumed unique) charastics of light could in some way alter how time was view.
As has been mentioned before if Einstein had used a bouncing ball instead of light relativity would be much differnt today.
You seem to be assuming that time itself is a human construct. It is not, any more than "length" is. It is simply a name we use to describe a dimension we observe to exist. How time works is not a human construct either. It was derived mathematically and proved experimentally, but we couldn't have just done the derivation differently and changed what we observe.
The only thing that is truly a human construct is our definition of the units we use - the number of shakes of a cesium atom that we define as a "second".
Just because no one knew how time worked before Einstein came along doesn't mean he invented it - he only discovered it. So it most certainly was real before he figured it out.
Sorry, i did use the word real out of context... didn't define it .. in saying real, i was referring to previous known existence. Invent and discover are one and the same. You could say everything is waiting to be discovered.. it's just waiting for someone to put the blueprints together.
  • #31
As an engineer, I don't see it that way at all (and I doubt scientists and artists do either). Devices such as cameras and staplers are objects and they are products of the minds of their inventors. Despite what Michelangelo said, the statue of David was not there before he removed the excess marble. The laws of physics are there already and are simply waiting to be discovered.
Something that is invented does not exist (is not real) before you invent it - something that you discover is real before you discover it. Ie, mount Everest was most certainly there before anyone knew it was there.
I think you are using the words "discover", "invent", and "real" incorrectly.
  • #32
But they do already exist... they are all bi-products of discovering of the mechanics that make them work... which already exist(inside the laws of this universe)... and are only waiting to be discovered. I am a scientist and a philosopher. Everytime an invention is made, it's just the discovering of laws that allow them to be created and carry out the functions they are able to carry out. I understand what you're saying, don't get me wrong, i am just looking at things a bit larger.(i agree to disagree, as i think both of our points are right, on different levels) Discover and invent are synonyms. So are real and exist. I re-defined what i meant by real. I don't know what you meant by artists.. so please don't be offended if i took you wrong, but artists don't necessarily invent or discover anything, they create paintings from previous discoveries such as paint and paper... and use their imaginations to project the image. Although this is getting interesting on how different professions might view the concept of discover/invent/create.
  • #33
I want to be a little bit hypothetical just so we can think a little bit differently about the definitions... one might call them "inventions" today... but say we're around for another 2 million years... and inventions are pretty much... done with... would they switch to being called discoveries?
  • #34
I think of it like this... every answer one could possibly desire... lay dorment in their brain. If you want the answers, you need to get the information. When you get the information, the answers become clearer.
  • #35
To answer your question we can consider the situation where you use both the the light clock and the bouncing ball.
Start in the frame where the light clock is at rest. The ball bounces straight up and down, and in the time it takes the ball to make the round trip the light clock ticks x times. Assume that there is a device that records both the ball bounces and ticks of the light clock, say a piece of tape that both the ball and light leave a mark on they bounce back and forth. The piece of tape moves relative to the light clock such that you get a mark from the ball followed by a series of marks made by the light followed by another mark made by the ball.
Something like this:
o...o...o...o...o
Know consider how things appear from the a frame in which this whole apparatus is moving. The light and ball still bounce back and forth and still make marks on the tape. However, the light and ball follow a zig zag path as seen from this frame. Now the light must travel at c, so in traveling a longer zig zag path rather than a shorter straight up and down it will take a longer time between each mark made on the tape as seen from this frame. (we see time dilation)
Now, if as you suggest, the Bouncing ball would give a new type of relativity, then its time between marks would be would not change at all, or change by a different factor. But then this observer would see the marks made on the tape look maybe like this:
0...0...0...0
With fewer light marks between each ball mark.
But how can two observers see a different number of marks on the same piece of tape? Especially when at the end of this experiment both observers and the tape could be put in the same room.
The answer is that they can't, and therefore the bouncing ball must undergo the same time dilation as the light clock does, so that at the end, both observers agree as to how many light marks are between each ball mark.
Thus using a bouncing ball instead of a light pulse will give you the same relativity.
<h2>1. Why do we perceive time differently in different lighting conditions?</h2><p>Our perception of time is influenced by the amount of light present because light helps us to establish a sense of rhythm and structure in our daily lives. In low light conditions, our brains may struggle to accurately process visual information, leading to a distorted perception of time.</p><h2>2. How does light affect our perception of time?</h2><p>Light helps to regulate our internal body clock, or circadian rhythm, which controls our sleep-wake cycle and other physiological processes. This rhythm is closely linked to our perception of time, and disruptions in light exposure can cause our perception of time to feel altered.</p><h2>3. Why do we use light-based devices, like clocks, to measure time?</h2><p>Light-based devices, such as clocks and watches, have become the standard for measuring time because they provide a consistent and reliable reference point. The movement of the hands or digits on these devices helps us to visually track the passage of time and stay synchronized with others.</p><h2>4. How does light help us to understand the concept of time?</h2><p>Light is essential for our understanding of time because it allows us to observe and measure the changes that occur in our environment. For example, we can use the position of the sun in the sky to determine the time of day, or we can use light-based devices to track the passing of seconds, minutes, and hours.</p><h2>5. Can light itself be used as a unit of measurement for time?</h2><p>While light can be used to measure time in some contexts, it is not a practical unit of measurement for everyday use. The speed of light is incredibly fast, and using it as a unit of time would result in very small and difficult to comprehend measurements. Instead, we use other units, such as seconds and hours, for more practical and relatable measurements of time.</p>
Related to Why do we judge time by light?
9K
