Why Isn't Water-Based Drink Hydration as Effective as Plain Water?
  • Thread starter kenny1999
  • Tags
    Water
In summary, drinking 8 cups of water every day is recommended for maintaining good health. However, other drinks can also contribute to our daily water intake. The reason plain water is considered the best option is because it has no added sugars or other potentially harmful substances. While distilled water has its benefits, it can also strip our body of essential minerals. Ultimately, it is important to listen to our body's thirst signals and make sure we are getting enough water, whether it is from pure water or other water-based drinks.
kenny1999
235
I was taught that we need 8 cups of water every day to keep healthy, but why can't we have other drinks instead of distilled water? Many drinks today contain a lot of water, what is the logic when there is something else it is not considered
to be as good as simple water?
Biology news on Phys.org
Do not drink distilled water! Never!
You could substitute water with soft drinks or beer, but you won't be happy with the nasty side effects! Isotonic drinks are best, which mineral water is to a certain degree or alcohol-free beer.
  • Skeptical
Likes PeroK, atyy and BillTre
I've drunk distilled water.
I'm still alive.
Likes .Scott and russ_watters
I'm still alive.
I have learned that it washes out the minerals in our cells per osmosis.
  • Skeptical
  • Haha
Likes .Scott, atyy and DaveE
I suppose it could, but it doesn't mean its bad in reasonable amounts, as with most things.
Drinking too much salt water, for example, will kill you.
Usually, it is because of the sugar content that gives you too much calorie intake when considering your entire diet. Also, apparently, people that drink more plain water also eat less overall:
https://www.health.harvard.edu/blog/big-benefits-plain-water-201605269675 said:
The researchers found that the participants who drank the most plain water in their daily diet consumed fewer total calories, drank fewer sweetened beverages, and took in less total fat, saturated fat, sugar, salt, and cholesterol. In fact, they discovered that increasing plain water consumption by one to three cups a day could decrease calorie intake by 68 to 205 calories a day.
About distilled water:
https://www.healthline.com/health/can-you-drink-distilled-water#side-effects said:
Some sources claim that drinking distilled water will help detoxify your body and improve your health. Others claim distilled water leaches minerals from your body and could put your health at risk. In reality, neither of these claims is entirely true.
Side effects of distilled water: Pros and cons​
Aside from its flat taste, distilled water doesn’t provide you with minerals like calcium and magnesium that you get from tap water.
Since distilled water doesn’t contain its own minerals, it has a tendency to pull them from whatever it touches to maintain a balance. So when you drink distilled water, it may pull small amounts of minerals from your body, including from your teeth.
Because you already get most of the minerals you need from your diet, drinking distilled water shouldn’t make you deficient. Still, if you’re going to drink distilled water, it’s a good idea to make sure you get your recommended daily servings of fruits and vegetables.
Pros​
Depending on where you live, distilled water could be better for you than tap water. If your town’s water is tainted with harmful chemicals or pesticides, you’re safer drinking distilled.
Cons​
Storing distilled water could be more of a problem. Distilled water can pull in minerals from any material it touches. This means it can absorb trace amounts of plastic or whatever substance is in the container that’s holding it.
Likes berkeman, russ_watters, 256bits and 1 other person
Of course that would be true with any water, or liquid, stored in any container.
There would be some leaching of chemicals regardless, although distilled water would be somewhat more aggressive.
Famous example,
Wine stored in lead glass decanters is a no - no., as the lead would leach into the wine.
Lead pipes for drinking water, contrary to it ( the water ) having minerals, does leach lead into the water.
Likes BillTre and jack action
Lead pipes require a particular pH (low I think), for the lead to leach into the water.
The problem with Flint, MI's plumbing was that they changed the source of their water to one with a different pH, and did not do the proper treatment of the water to correct the pH, to prevent the lead (and internal pipe coatings) from coming off.
Yes, if you choose to drink way too much too quickly. Otherwise, you'll just have to pee a lot. OTOH, your cells may appreciate the dilution of overly concentrated minerals that result from normal water loss.
Honestly, I can't tell if you're joking. Mammals Cellular based life figured this problem out long ago.
Drink when you're thirsty; things which are mostly water.
Likes BillTre and atyy
But what if @fresh_42 is an amoeba, that would explain a lot?
Edit: should have said marine amoeba, freshwater amoebas would probably be ok?
No, but it seems y'all are car batteries.
  • Haha
  • Love
Likes pbuk, berkeman and atyy
I didn't think it mattered too much whether you drink straight water or water-based drinks. But, of course, other drinks have sugars, caffeine or other things that you need to account for in your daily diet.
Likes atyy
The title mentions drinking water, but then one queries about 'distilled' water. 'Drinking water' implies 'clean' or 'potable' water, i.e., water that is 'safe' to drink, as opposed to water that is 'contaminate' with bacteria, harmful organic compounds, minerals or metals (especially heavy metals).
Distilled water is considered safe, but one must not overdo it, since drinking pure water will flush out important elements from the body. However, foods normally make up the minerals and salts we need.
Yes, drinking pure water does flush out minerals from the body. But it would take gallons of water to be harmful. See - water intoxication
https://www.medicalnewstoday.com/articles/318619#water-intoxication
Also known as water poisoning, water intoxication is a disruptionTrusted Source of brain function caused by drinking too much water.
Doing so increases the amount of water in the blood. This can dilute the electrolytes, especially sodium, in the blood.
If sodium levels fall below 135 millimoles per liter (mmol/l), doctors refer to the issue as hyponatremia.
Sodium helps maintain the balance of fluids inside and outside of cells. When sodium levels drop due to excessive water consumption, fluids travel from the outside to the inside of cells, causing them to swell.
When this happens to brain cells, it can be dangerous and even life threatening.
https://www.medicalnewstoday.com/articles/317698#risks
https://www.who.int/water_sanitation_health/dwq/nutrientschap12.pdfAt home, we drink distilled well water, since my wife doesn't trust the well water. I occasionally drink water from the tap. In the past, I've used filtered tap water. Before we started using a distiller, we used bottled tap water that had some mineral content.
My son actually experienced hyponatremia (he feinted one evening while standing next to me, and I barely had time to catch him enough to lessen the impact on the floor and kitchen cabinets), and we were advised by his pediatrician to ensure he had sufficient salt intake.
Likes BillTre
Nobody gave the direct answer: This is a myth, though its origin is unclear, perhaps misread FDA guidance from 70 years ago. The FDA didn't say that only water would do, it said that's how much H2O you need (which varies, by the way). Period.
Obviously most people don't drink 8 cups a day and nobody dies because of it. Most of the water we take in comes from the food and other beverages we drink. As @jack action mentions there may be positive health implications from prioritizing water over other drinks. So there isn't much harm in this myth.
https://www.uab.edu/news/youcanuse/item/11421-busting-the-8-cups-of-water-myth
https://healthblog.uofmhealth.org/womens-health/myth-busting-no-more-8-glasses-a-day
https://www.snopes.com/fact-check/water-works-2/
Likes Laroxe and Rive
That's a myth too, and if you think about it it should be obvious. Almost nothing that we eat or drink has exactly what we need, but it doesn't "wash out" minerals other than by mere dilution/excretion. If you drink any sort of fresh water and then sweat, you lose salt (via osmosis). That needs to be replenished, and the usual method is by eating salty food. There's nothing unique or particularly worse about distilled water. It's fair to say it isn't as healthy as fresh or mineral enriched water, but that's about it.
And note, while the "8 glasses of water a day" myth is largely harmless, this one has some potential harm in denying people clean water they need to survive. That's because when you manufacture water it often comes out distilled. The researchgate article, for example, points out that that's what you get from a solar still. So if people decide to drink their dirty pond water (or NGOs don't support these installations because of the myth), that harms the people who need clean water.
https://www.medicalnewstoday.com/articles/317698#is-it-safe
https://wcponline.com/2003/10/14/distill-ing-truth-online-propaganda/
https://www.researchgate.net/publication/319406161_Dispelling_myths_about_drinking_distilled_water
Likes fresh_42
There are also several different ways to make varying qualities of "clean" water.
I have used many different ones in labs I have worked in.
In labs, now-a-days, distilled water is not considered high quality water. Measurable amounts of non-water molecules can pass through a good distilling apparatus (non-water molecules in the gas phase).
The measurements in labs are usually in electrical resistance of the water. That would not (directly) detect neutral molecules.
Modern lab clean water making machines run the starting water (tap, DI, RO, or distilled water through a series of filtration/reverse osmosis steps to remove charged molecules and organics among other things. This let's them improve upon distillation.
Other than distilled water, you can get DI (De-Ionized) water (either from a lab machine or from special taps in some labs), RO (reverse osmosis) water. Distilled water can also be provided from a central source, however, supplying in the water through long runs of plumbing (or storing it there over long periods when not in use) will probably lead to accumulating contamination from the plumbing (unless super-inert), which is a degradation of the water quality.
For a while I was running an RO machine in my garage to supply really good water for a special fish project. I started with soft tap water with about 34 microSiemans of conductance. After running it through the RO machine (which also had a particle filter (to protect the RO membranes), a carbon filter (charcoal), and a ion binding resin) the water coming out was 3-4 microSiemans.
Its not lab quality, but its real good quality fish water which can be salted up whatever you want.
This is basically how the water in well run research fish labs is done. Large amounts of water is needed, but not like super-high quality lab water.
You could safely drink all of these, if they are not contaminated.
If the cells were exposed directly to distilled water (or other equally weak solutions), than they would have problems in many ways.
However, bodies of metazoan organisms (multicellular animals, like humans) are like space ships for the cells they are made of. As a spaceship has to maintain a proper environment to maintain its human cargo, so must the body provide conditions to keep its cells alive.
Cells in a body are bathed in a body controlled chemical environment which suits them. One of the body's main functions is to maintain those parameters, because not doing that would endanger their cells, and therefore their ability to reproduce.
In most cases, the effect of any distilled water coming in through the digestive system will be modulated by bodily control processes.
Likes Laroxe and russ_watters
Distilled water is considered safe, but one must not overdo it, since drinking pure water will flush out important elements from the body. However, foods normally make up the minerals and salts we need.Yes, drinking pure water does flush out minerals from the body. But it would take gallons of water to be harmful. See - water intoxication
https://www.medicalnewstoday.com/articles/318619#water-intoxicationhttps://www.medicalnewstoday.com/articles/317698#risks
I strongly advise you to boil the water first rather than drinking directly from the tap (even filtered). If you want cool water, boil a lot of it beforehand and let it cool
Depends on where you live. Here it is the best-watched nutrition of all and usually even better than mineral water. No problem to drink it directly. And in Switzerland, it even tastes good.
Likes russ_watters, jack action and BillTre
You could safely drink all of these, if they are not contaminated.If the cells were exposed directly to distilled water (or other equally weak solutions), than they would have problems in many ways.
Hi, before reading your comment carefully soon, can I drink a lot of water-based drink instead of pure, distilled, or tap water
Boiling water will often change water chemically.
If nothing else it will change the amounts of different atmospheric gasses dissolved in the water.
Boiling off CO2 will change the pH. It can redissolve fairly quickly, especially if aerated.
This can change flavor.
That is what the distiller does. I've not had a problem with drinking filtered or unfiltered tapwater.
However, our house sits a top a iron and manganese deposit. We've had the water tested, and it passed, but one of early tests indicated Ni and Cd in the water. I don't know the source, but since Ni, Cd were present, my wife insisted on bottled or distilled water. I'm not concerned about bacteria, which are not detected.
We recently replaced the water heater after we determined that the iron in our water was coming from the water heater, which was close to failure.
Because the cadmium will get them?
  • Haha
Likes Astronuc, BillTre and fresh_42
I believe the Cd and Ni readings were spurious (or perhaps transient); I know we have a certain amount of Fe and Mn, which are removed by a green sand filter. Others tests gave less than detectable. No bacteria were found, although we can get certain bacteria, so we have 'shocked' the well with chlorine bleach. My wife preferred to use bottled water until we got a distiller.
I've been meaning to have another test/analysis done.
I'm still alive.
Lol. . . but, it might make your toe nails long and brittle and break easily, too.
Just like Tom's . . . . :eek:
Kidneys were developed to handle this, as they retain what's useful and keeps the right concentration too.
Isotonic drinks are the only ones which are supposed to not wash out anything (still not absolutely true, but close enough): yet together with usual food intake, isotonic drinks may mean unnecessary stress for the kidneys.
As always, extremities can be nasty.
It's just like the good old 'an apple a day will keep the doctor away'. Has some merit, but tells nothing about the reasons, thus forever remains incomplete.
A different (maybe more useful) rule of thumb: drink enough clean water just to keep your pee light yellow, and that'll do.
You need water both to maintain balance and to be used as a flush (for the kidneys). If the latter is working fine without unnecessary stress, then the former requirement is already satisfied.
I was curious regarding the title (I was going to post, “so we do not die of thirst”)
Reading the comments it is clearer now
I have never actually drank distilled water, I imagine it is quite tasteless?
Anyway there was a big thing/TV ads regarding isotonic drinks after sports, I thought it was nonsense at the time.
A reason to waste money on bottled drinks when tap water will do just as well.
Same with bottled water.
We replenish salts/ minerals lost in urine when we eat again was my thinking.
I'm in the Swiss Alps at the moment and the price of bottled water at the mountain huts is 12CHF for 1.5 litres! It's about half that in French and Italian huts. It does have to be helicoptered in, so 5 Euros a bottle is fair enough. But not double that.
That leaves four options: pay up and laugh off the expense; get seriously dehydrated (not recommended); carry a lot of water up to the huts (I've tried this); or, what I do, drink the glacier water using purification tablets.
The Swiss mountain guides never tire of telling me off for doing this! But, as I drink 4-5 litres a day, it's not an option to pay Swiss prices.
  • Wow
Likes pinball1970
Let me add tannins and alcohol to that list.
Tannins are in teas, coffee, wine, and many fruit drinks.
They are normally harmless - but if you rely on non-meat sources for iron, don't take it with your spinach (or other iron source) because it will precipitate the iron before any of it reaches your blood stream.
Alcohol is a diuretic - so it isn't very good at hydrating you.
Don't count fruit juices as fruit. They have way more sugar than nutritious pulp.
Most soft drinks have huge amounts of sugar.
Sugar, aside from adding calories, also bumbs up you triglycerides because the fructose can only be handled by your liver. It's very similar to the way alcohol is processed.
So if your looking to get 8 cups a of water a day - I would suggest making at least four of those cups plain old water (on the rocks).
Related to Why Isn't Water-Based Drink Hydration as Effective as Plain Water?
1. Why is drinking water important for our health?
Drinking water is essential for our overall health and well-being. It helps to regulate our body temperature, aids in digestion, and carries nutrients and oxygen to our cells. Additionally, drinking enough water can prevent dehydration, which can lead to fatigue, headaches, and other health issues.
2. How much water should we drink each day?
The recommended amount of water to drink each day varies depending on factors such as age, gender, and physical activity level. Generally, it is recommended to drink 8-10 glasses of water per day, or about 2 liters. However, it is important to listen to your body and drink more water if you are feeling thirsty or if you are engaging in physical activity.
3. What are the benefits of drinking clean water?
Drinking clean water is crucial for maintaining good health. It helps to prevent the spread of waterborne diseases and can improve the taste and smell of water. Clean water also contains important minerals that our body needs, such as calcium and magnesium, which are essential for healthy bones and teeth.
4. How does drinking water impact the environment?
The production and distribution of drinking water can have an impact on the environment. For example, the use of plastic water bottles contributes to pollution and takes a toll on natural resources. However, choosing to drink tap water or using reusable water bottles can help reduce our carbon footprint and protect the environment.
5. What are some alternative sources of drinking water?
In addition to tap water, there are several alternative sources of drinking water. These include filtered water, bottled water, and natural spring water. Some people also choose to drink other beverages such as tea, coffee, and juice, which can also contribute to our daily water intake. However, it is important to be mindful of added sugars and other additives in these beverages.
  • Biology and Medical
22K
11K
  • Math Proof Training and Practice
  • Astronomy and Astrophysics
