- #36
lavinia
- 713
What is intuitive seems to refer to what can be visually seen or imagined and circular motion, (rotation through an angle), is intuitive as is changing the length of a measuring rod that is pointed in some direction. These two operations, change of length and rotation through an angle, are the two components of complex multiplication. If one thinks of i as rotation through 90 degrees, i is just as intuitive as 1 which is rotation though zero degrees or -1 which is rotation through 180 degrees.
So if real numbers are intuitive or "real" so are the complex numbers.
What is less intuitive - at least to me - are the real numbers themselves. For instance,one can think of rational lengths as the total of all possible divisions of integer lengths (some number of measuring sticks laid side by side)using ruler and compass constructions. After a bit of thought one can see how one might go about making one that you are given, that is you could define a mathematical procedure for making it. This involves a high level of mathematical abstraction. It is not intuitive but rather deductive or at least requires deduction before a visual picture can be achieved if even possible.
If one extends the idea of ruler and compass constructions to the plane, one gets some irrational numbers and again with some thought one can imagine how one might go about constructing such a number e.g. the square root of 2. But again we are in a world of abstraction and mathematical procedures. What does it even mean to say that one can intuit the number sqrt( 2 + sqrt( 2 + sqrt(2))/27?
Gauss showed that all linear lengths that can be constructed with a ruler and a compass are iterated square roots but this does not come close to all of the real numbers. There are even lengths of regular polygons that can not be constructed in this way e.g. the length of the side of a regular septagon. Is this length intuitive?
Mathematicians conceived of the real numbers in various ways but not using algorithms or intuitions. Rather they came up with the idea of the metric completion of the rational numbers. But one can not intuit these numbers because there are uncountably infinitely many of them. There is no procedure even to generate any except a paltry countable subset.
There is a subfield of the real numbers for which there do exist algorithms, that is if a computer were allowed to run forever it would be able to express the number in terms of limits of rational numbers. These are called computable numbers. For instance the square root of 2 and π are both computable. One might say that in principle a number is "real" or worse "intuitive" if it is computable. There are only countably many computable numbers so this excludes almost all real numbers.
