Why do we need to supply air to the cathode of a hydrogen fuel cell
In summary, a simple hydrogen fuel cell works by sending hydrogen fuel to the anode (negative terminal) where it is separated into positive and negative ions. The electrons from the negative ions travel through an external wire, providing electricity. Air is also sent to the cathode (positive terminal) to neutralize the positive ions and balance the reaction equation. Without air, the system would still work, but there is a limit to how many ions can accumulate in one place. By adding air, the positive ions can be neutralized and produce water as a byproduct.
srinaath
52
I am trying to understand the working of simple hydrogen fuel cell.
We have anode (negative terminal), cathode (positive terminal), catalyst at anode to separate negative and positive ions of hydrogen atoms and electrolyte which allows only positive ions.
We will be sending hydrogen fuel at anode where both positive and negative ions separated. electrons goes through external wire providing electricity. Also i read that we will be sending air to cathode. Why is that required? I mean without air won't the system still work? positive ions will still travel though electrolyte
Kindly provide me some insight.
Producing/yielding what?
Start with the reaction equation.
There is a limit to how many of those ions can accumulate in anyone place. You need to provide electrons to neutralise those positive ions. Oxygen will do that for you and hey Presto - you have neutral water.
At the end the equations must balance! --- Electrons that come out of the cell must return! H2 in one side and gives up an electron, and O2 in the other and takes an electron - when they meet in the middle - they get happy (lower energy state) and make water.
Related to Why do we need to supply air to the cathode of a hydrogen fuel cell
1. Why is air needed in a hydrogen fuel cell?
The air is needed to supply oxygen for the cathode reaction in the fuel cell. This reaction combines with the hydrogen from the anode to create a flow of electrons, which generates electricity.
2. What role does the cathode play in a hydrogen fuel cell?
The cathode is one of the two electrodes in a hydrogen fuel cell. Its main purpose is to receive the flow of electrons from the anode and combine them with oxygen from the air to produce water and release energy in the form of electricity.
3. Can any type of air be used in a hydrogen fuel cell?
No, only pure and dry air can be used in a hydrogen fuel cell. Any impurities or moisture in the air can affect the performance and efficiency of the fuel cell.
4. How is the air supplied to the cathode in a hydrogen fuel cell?
The air is usually supplied through an air intake or inlet on the fuel cell. It is then directed to the cathode where it is used in the cathode reaction to generate electricity.
5. Is the amount of air supplied to the cathode important?
Yes, the amount of air supplied to the cathode is crucial for the proper functioning of a hydrogen fuel cell. The right balance of air and hydrogen is needed for the chemical reaction to occur and produce electricity. Too little or too much air can affect the efficiency and performance of the fuel cell.
  • Electrical Engineering
  • Electromagnetism
  • Materials and Chemical Engineering
  • Atomic and Condensed Matter
