Why do we say that the concentration of solids and liquids are constant?
In summary: I don't know how to put it.So sir, what does it actually mean by "the concentration of liquid and solids are constant" . I'm not getting it.
Adesh
735
191
Concentration of solids and liquids are constant, but it seems to me non-intuitive.
concentration = density/ molar mass
I was introduced to the concepts like molarity, molality , mole fraction, formality, normality etc. during general chemistry and it was said that these concepts are used to measure the concentration of solutions. But as the thing called Chemical Equilibrium came I was surprised when I read "In heterogenous chemical reaction the concentration of solids and liquids are taken to be constant in calculating [itex]K[/itex]"
I did some research and found that people are explaining it like this :-
Let's assume that you have a liquid with density [itex]\rho[/itex] and molar mass [itex]m[/itex] and since units of [itex]\rho[/itex] is [itex]\frac{g}{L}[/itex] and that of [itex]m[/itex] is \frac{g}{mol} therefore [itex]\frac{\rho}{m}[/itex] will have units as[itex] \frac{mol}{L}[/itex] and hence [itex] concentration = \frac{\rho}{m}[/itex] and [itex] \rho= \frac{mass}{volume} [/itex]. Therefore, [itex] conc. = \frac{mass\cdot molar mass}{volume}[/itex] and as you can see all three quantities are constant(volume is constant for solids and liquids) and hence the concentration of solids and liquids are constant.
I agree with that mathematical explanation but what does it mean when we say "that bottle have concentrated NaOH and that bottle have dilute NaOH" isn't it contrary to what has been just described above? I mean if we mix more [itex] CaO[/itex] in water we will get a highly concentrated solution then if we mix just a pinch of [itex]CaO[/itex] in water.
Any help will be much appreciated. I know that I'm having some misconception and therefore I request you all to please help me.
Thank you.
That's not a solution, that's a suspension - you have two separate phases that react only the at the phase boundary.
(Well, CaO easily reacts with water, so the situation is much more complicated, think in terms of sand in water to make things conceptually easier).
I can mix one spoon of sand in a glass of water and will get a solution of say conc. [itex] X[/itex].
But when I will mix five spoons of sand in same quantity of water then according to my knowledge (till now) I should get a solution of concentration more than that of [itex]X[/itex].
Please explain this.
Solution is a homogeneous mixture. Is the mixture of sand and water homogeneous?
No. From personal experience I can say that sand will settle down. Hence composition is not uniform all over.
So it is not a solution and you can't speak about the concentration of sand in water.
Likes Adesh
Yes I think I'm getting you. But if we mix 500 ml of [itex] NaOH[/itex] in 1 litre of water and in a different bottle we mix 900 ml of [itex] NaOH[/itex] in 1 litre of water then what will be the situation? I think that the latter case will be a more concentrated base.
I must express my feelings, you have taught such a great lesson which I missed to notice the significance of. Really I didn't ever notice that concentration is defined only for homogenous mixtures (well it makes sense too, it would be senseless to talk about concentration when concentration itself varies over the solvent).
I just really want to thank you. Thank you so much.
I apologize for this off-topic remark.
Likes Borek
Depends on how much will dissolve. At some point you will get a saturated solution with some solid left, then adding more NaOH will change the amount of solid, but not the concentration of the solution.
The pleasure is all mine :smile:
Likes Adesh
Borek said:
Depends on how much will dissolve. At some point you will get a saturated solution with some solid left, then adding more NaOH will change the amount of solid, but not the concentration of solution
I mean before saturation is attained we can have differently concentrated solutions of NaOH and water.
Here's how I think about the issue. For a reaction between a an aqueous substance and a solid (say the dissolution of solid NaOH(s) into Na+(aq) and OH-(aq) ions), the reaction can occur only at the interface between the solid NaOH and the aqueous solution.
Because equilibrium doesn't depend on the total amount of substance, let's just consider a fixed area of solid NaOH in contact with water. Changing the concentration of Na+ or OH- ions in solution will change the number of these ions that can collide with and react with the surface. However, (by definition) the number of solid NaOH units in contact with the water over that fixed area is fixed and cannot be changed.
Adding more solid NaOH will provide more surface area over which the reaction can occur (speeding up the reaction), but it won't do anything to change the relative abundance of solid NaOH units to Na+ and OH- ions at the interface. Thus, the eqiuilibrium does not change when you change the amount of solid NaOH.
Likes Adesh
First of all thank you so much for replying me. I almost believed that Borek has not replied to me because he has thought that I can't ever understand it but your answer has really given me ample amount of pleasure.
Your answer is very nice, it has cleared all my doubts. I'm really grateful to you for such a nice answer.
Related to Why do we say that the concentration of solids and liquids are constant?
1. Why is the concentration of solids and liquids considered constant?
The concentration of a substance refers to the amount of that substance present in a given volume or mass of another substance. In the case of solids and liquids, the molecules are packed tightly together and do not have the ability to move around freely. This means that their concentration remains constant because the amount of substance in a given volume or mass does not change.
2. Can the concentration of solids and liquids change?
In most cases, the concentration of solids and liquids remains constant. However, there are certain factors that can cause a change in concentration. For example, if a solid dissolves in a liquid, the concentration of that substance in the liquid will increase. Similarly, if a liquid evaporates, the concentration of that substance in the remaining liquid will increase.
3. Is the concentration of solids and liquids affected by temperature?
Temperature does not have a significant effect on the concentration of solids and liquids. While temperature can affect the solubility of a substance, it does not change the concentration of that substance in a given volume or mass. This is because the number of molecules in a substance remains constant, even if their movement may be affected by temperature.
4. How is the concentration of solids and liquids measured?
The concentration of solids and liquids can be measured in various ways, depending on the substance and the situation. In general, it is measured in terms of mass per unit volume (e.g. grams per liter) or moles per unit volume (e.g. moles per liter). Other units of measurement include weight percentage, volume percentage, and parts per million (ppm). The appropriate unit of measurement will depend on the specific substance and the purpose of the measurement.
5. Why is it important to understand the constant concentration of solids and liquids?
Understanding the constant concentration of solids and liquids is important in many scientific and industrial applications. For example, it is crucial in chemistry and biology for accurately measuring and controlling reactions. In industrial processes, it is important for maintaining consistency and quality of products. Additionally, understanding the constant concentration of substances can help with predicting and monitoring changes in the environment, such as water pollution levels.
