Why do we see spectral LINES, not circles/triangles etc?
In summary: A rainbow is an example of a geometry where you get circles.The spectrograph maps the image of the slit onto a screen.The spectrum itself has the wavelengths laid out in a line because the diffraction grating is made up of linear slits arranged in parallel.
girlinphysics
25
We were looking at the spectral lines of sodium in class and I was wondering, why do we see lines, and not any other shape like circles?
We can't answer your question very well, if you don't give us some details. Without the exeprimental setup, we can not figure out about the shape of the spectra you observe.
We had a sodium lamp set up in the lab with a spectrometer and were told to measure the diffraction angle of the doublet components in the sodium spectrum. We saw lines like this: http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/modpic/picklespectrum.jpg
I was just curious as to why spectra occur as lines, not other shapes.
Was the light beam passed through a straight line slit? It usually is so the straight lines are effectively images of the slit.
The light coming from the sodium lamp was incident on a slit of adjustable width (we made it very narrow until the spectrum could be seen). We also used a diffraction grating.
The spectrograph maps the image of the slit onto a screen. If it was a circular diaphragm instead of the slit you would see a circular spot with monochromatic light. If you used Mercury vapour lamp you would see circles of different colour. If the slit was made of the form of a cat you would see a cat spectrum. ;)
ehild
To see this, make the slit wider, and see what happens to the spectrum lines. They should widen out into "spectrum rectangles" which overlap if they're wide enough.
Some theory of atomic line transitions should have been explained in your class. You should look up some resources on spectral line shape. It's not really a line, but a Voigt profile.
The spectrum itself has the wavelengths laid out in a line because the diffraction grating is made up of linear slits arranged in parallel. If you had a different grating (say, circular bands), the shape of your spectrum would change.
If you want to be purist, it might be better to call spectral lines 'Spectral Maxima' and 'Spectral Minima'. That would take care of the particular method you use for analysing a spectrum.
If you were to display the spectrum of a radio signal as a set of 'lines', people would complain because a two dimensional graph can show the value of amplitude on the y-axis with the frequency (or wavelength) plotted on the x axis. But that's also the form in which data of optical spectra is displayed for serious analysis.
If a vertical slit of light goes through a prism, the colors get sorted out nicely. A place for each frequency and each frequency in it's place. Martha Stewart would say "It's a good thing". But if the light goes through another shape (like the outline of a cat, as a previous post said), then the light spectrum of the tail would get smeared over the light spectrum of the head, and there would be a jumbled mess of light frequencies at anyone spot, all from different parts of the cat. That would be useless.
It depends on the grating constant and the size of the aperture, also on the optical arrangement. The diffracted light should be focused to a screen. My students did that experiment with a grating , using a Hydrogen lamp and apertures of different shapes. So the spectral "lines" became well separated "spectral dots", letters and traffic signs.
If you use a laser as light source, the diffraction pattern consists of spots of about circular shapes.
ehild
Related to Why do we see spectral LINES, not circles/triangles etc?
1. Why do we see spectral lines instead of other shapes?
The spectral lines we see in a spectrum are a result of the absorption or emission of specific wavelengths of light by atoms or molecules. These atoms and molecules have specific energy levels, and when they absorb or emit light, it is in the form of discrete energy packets, resulting in spectral lines. Other shapes, such as circles or triangles, do not have this discrete energy level structure and therefore do not produce spectral lines.
2. What causes the spectral lines to appear in a spectrum?
The spectral lines in a spectrum are caused by the absorption or emission of specific wavelengths of light by atoms or molecules. This occurs when an electron in an atom or molecule jumps from one energy level to another, releasing or absorbing energy in the form of light. The specific wavelengths of light that are absorbed or emitted correspond to the energy difference between the two energy levels.
3. Why do the spectral lines have different colors?
The different colors of spectral lines correspond to different wavelengths of light. Each element has a unique set of energy levels, and therefore, it absorbs or emits specific wavelengths of light. The color of the spectral line is determined by the wavelength of light that is absorbed or emitted by the element.
4. Can we see spectral lines with the naked eye?
While we cannot see individual spectral lines with the naked eye, we can see the overall pattern of spectral lines in a spectrum. This pattern is a result of the combination of all the individual spectral lines produced by different elements in the source of light.
5. Why are spectral lines important in science?
Spectral lines are important in science because they provide valuable information about the composition and properties of different substances. By studying the specific wavelengths of light that are absorbed or emitted by elements, scientists can identify the elements present in a substance and determine other properties such as temperature and density. Spectral lines are also used in fields such as astronomy to study the composition of stars and galaxies.
  • Other Physics Topics
