Why do we show in this way that it is not the image of the function?
In summary, the proof shows that if there is a function $f$ from a set $A$ to its power set $\mathcal{P}A$, then $f$ cannot be surjective. This is proven by assuming that there exists an element $a \in A$ such that $f(a)=D$, where $D$ is a set defined as the elements of $A$ that are not in the corresponding element of $f(A)$. This leads to a contradiction, showing that $D \notin f(A)$ and therefore $\mathcal{P}A$ is not the image of $f$.
evinda
MHB
3,836
Hello! (Wave)
Theorem:
No set is equinumerous with its power set.
Proof:
Let $A$ be a set. We want to show that if $f: A \to \mathcal{P}A$ (a random function) then $f$ is not surjective.We define the set $D=\{ x \in A: x \notin f(x)\}$ and obviously $D \in \mathcal{P}A$.
We assume that there is a $a \in A$ such that $f(a)=D$.Then we have:
$$a \notin D \leftrightarrow a \notin f(a) \leftrightarrow a \in D, \text{ contradiction}$$
Therefore for each $x \in A, f(x) \notin D$, i.e. $f$ is not surjective.Could you explain me the proof from the point where we assume that there is an $a \in A$ such that $f(a)=D$?We have show that $D \in \mathcal{P}A$ and we want to show that $D \notin f(A)$ in order to show that $\mathcal{P}A$ isn't the image of $f$.
Why do we do it like that? (Worried)
I got it.. We want to show that $D \notin f(A)$.
So we suppose that $D \in f(A)$. That means that there is an $a \in A$ such that $f(a)=D$.
$$a \in D \leftrightarrow a \notin f(a) \leftrightarrow a \notin D$$
So we have found a contradiction..
FAQ: Why do we show in this way that it is not the image of the function?
1. Why is it important to show that it is not the image of the function?
It is important to show that it is not the image of the function because it helps to clarify any misconceptions or misunderstandings about the function. It also allows for a more accurate understanding of the function and its properties.
2. How can we show that it is not the image of the function?
There are several ways to show that it is not the image of the function, such as using counterexamples, disproving the statement with a specific input, or mathematically proving that the image does not match the given function.
3. What is the difference between the image of a function and the function itself?
The image of a function refers to the output values that are produced when the function is applied to a specific input. The function itself is a set of rules or operations that map inputs to outputs. The image is a result of applying the function to an input, while the function is the process that produces the image.
4. Can the image of a function be the same as the function itself?
No, the image of a function and the function itself are not the same. The image is a subset of the function's range, which includes all possible output values. The function itself includes all possible inputs and outputs, and is not limited to just the image values.
5. Why do we sometimes need to prove that the image of a function is not the same as the function itself?
Proving that the image of a function is not the same as the function itself helps to ensure the accuracy and validity of mathematical statements and arguments. It also allows for a deeper understanding of the function and its properties, which can be useful in solving more complex problems.
