Why do we store open bottles of hydrogen mouth down?
  • Thread starter catrinamat
  • Tags
    Hydrogen
In summary: Erlenmeyer flask?Attempt: The bottom of the thistle tube must extend below the surface of the liquid in order to prevent reactive gasses from entering the liquid.In a future lab in which we collect oxygen gas, we will place the bottles mouth up on the table. Why do you think we store the bottles of hydrogen mouth down?Attempt: We store the bottles of hydrogen mouth down in order to keep gas from escaping due to the surface tension of the gas.
catrinamat
https://hunterschools.myschoolapp.com/ftpimages/602/download/download_2996847.pdfQuestions
  1. Why must the bottom of the thistle tube extend below the surface of the liquid in the Erlenmeyer flask?
    1. Attempt: The bottom of the thistle tube must extend below the surface of the liquid in order to prevent reactive gasses from entering the liquid.
  2. In a future lab in which we collect oxygen gas, we will place the bottles mouth up on the table. Why do you think we store the bottles of hydrogen mouth down?
    1. Attempt: We store the bottles of hydrogen mouth down in order to keep gas from escaping due to the surface tension of the gas.
Observations
  1. When instructed by your teacher, light a wooden splint with your Bunsen burner, and carefully insert it into the bottle of hydrogen you have collected. Be sure to hold the bottle upside down. Record your observations.
    1. The splint reacted with the hydrogen, creating a loud "pop" sound.
  2. Place samples of different metals -- calcium, magnesium and sodium -- into three different beakers of water containing phenolphthalein. Observe carefully.
  3. Make a list of the metals in order of decreasing reactivity. Include all of your observations about each reaction and a word equation representing the reaction you observed.
    1. I don't know what a word equation means, but all the metals changed the color of the phenolphthalein on the top layer to a magenta color.
Conclusions
  1. List at least 3 physical properties of hydrogen that you observed.
    1. Reacts audibly with fire
    2. Has high surface tension
    3. Is not flammable
  2. When hydrogen burns in air, liquid droplets are often observed at the mouth of the container. What, specifically, is the origin of these?
    1. From the pressure of the reaction, causing condensation.
Conclusions (2) is incorrect. The reaction is ## 2H_2+O_2 \rightarrow 2H_2 O ##. This reaction can even be explosive. From this it should be obvious why we get some condensation. ##\\ ## For the storing of the bottles mouth down, I'm not completely sure why. The internal pressure in the bottom of the bottle is nearly the same as in the top of the bottle. I need to give this part more thought. ## \\ ## @Chestermiller @Borek It is unclear to me why it would be standard practice to store the hydrogen bottle with mouth down. Perhaps one or both of you can provide a helpful input here. My best instincts looking at the small buoyancy effects tells me this may be unnecessary superstition, rather than something based on sound physics principles. Perhaps I'm missing something. Is it possible the hydrogen in high pressure tank is in liquid form at the bottom of the bottle? :smile::smile: See also https://pureenergycentre.com/hydrogen-storage/
I don't see them storing it with mouth down.:sorry: ## \\ ## Edit: For very temporary storage=a couple seconds, it can be kept in an open-mouthed test tube with mouth down, because it is much lighter than air, and buoyancy effects will make it want to rise upward. This is apparently what they are referring to here. At molecular weight of 2, ## H_2 ## is much lighter than ##N_2 ##, molecular weight 28, and ## O_2 ## molecular weight 32, making for an atmosphere with average molecular weight greater than 30. (Atmosphere is 78% Nitrogen ## N_2 ## and 21% Oxygen ## O_2 ## by molecular number). Using ##PV=nRT ##, and mass density ## \delta=(n)(M.W.) ## where ## M.W. ##=molecular weight, and ## n=## number of moles, you can see why ## H_2 ## is lighter than air, i.e. it has a much lower mass density for a given pressure. It my interest you that the reason clouds, made of water droplets and water vapor, are able to float is because water (vapor) has ## M.W.=18 ##, supplying the necessary buoyancy, being lighter than air.
Likes catrinamat
Additional item: Hydrogen gas is highly flammable and explosive. Didn't you ever hear of the Hindenberg blimp? See https://en.wikipedia.org/wiki/Hindenburg_disaster ## \\ ## In addition, phenolphthalein is a pH indicator. The reaction of sodium ## Na ## with water ## H_2 O ## produces aquaeous ## NaOH ##, (Sodium hydroxide) , which is very basic,(causing the pH indicator to change color=pH of 7 is neutral=pH of base is greater than 7 = see https://www.britannica.com/science/phenolphthalein) along with (diatomic) hydrogen gas (## H_2 ##). Let's see if you can balance the equation for the reaction. ## \\ ## For this experiment , as far as I know, hydrogen gas has limited viscosity , and your comments about surface tension are incorrect and irrelevant. ## \\ ## See also some additions I made to post 2 above, including the "Edit" about why it is stored with mouth downward in an open bottle.
Questions
We cannot see the pdf you linked to because we can't log into your school system for obvious reasons, but I'm guessing you are splitting water into hydrogen and oxygen.
Hints..
1) If the thistle tube was above the surface of the water what might escape back up the thistle tube and why?
2) I assume we are talking about small open collecting flasks/tubes not bottles of compressed gas. In which case is Hydrogen heavier or lighter than air?
Related to Why do we store open bottles of hydrogen mouth down?
1. Why do we store open bottles of hydrogen mouth down?
Storing open bottles of hydrogen mouth down helps to prevent any potential leaks of the gas. Hydrogen is a highly flammable gas, and storing it with the mouth down allows for any gas that may escape to rise upwards and dissipate more quickly.
2. Is storing open bottles of hydrogen mouth down safe?
Yes, storing open bottles of hydrogen mouth down is generally considered safe. As long as the bottle is tightly sealed and stored in a well-ventilated area, there is minimal risk of any hydrogen gas escaping and causing any potential hazards.
3. What happens if we store open bottles of hydrogen mouth up?
If open bottles of hydrogen are stored mouth up, any gas that may escape from the bottle will remain trapped inside and potentially build up pressure, increasing the risk of a leak or explosion. This is why it is recommended to store hydrogen bottles mouth down.
4. Can we store open bottles of other gases mouth down as well?
The method of storing open bottles mouth down is typically used for highly flammable gases, such as hydrogen. For other gases, it may not be necessary or even recommended. It's best to follow the specific storage instructions for each type of gas to ensure safety.
5. Are there any other benefits to storing open bottles of hydrogen mouth down?
In addition to safety, storing open bottles of hydrogen mouth down can also help to preserve the quality of the gas. With the mouth down, any moisture or contaminants in the air are less likely to enter the bottle and potentially affect the purity of the hydrogen gas inside.
  • Electromagnetism
  • Astronomy and Astrophysics
  • Earth Sciences
  • Science and Math Textbooks
17K
