Why do we *subtract* enthelpy of lattice formation?
In summary, during the calculation of enthalpy of lattice formation, the Born-Haber process is used and the enthalpies of all the intermediate steps are added together. However, the enthalpy of lattice formation is subtracted instead of added like the other enthalpies. This is because NaF already exists before the solid is formed and it is being removed from the sequence. The process proceeds logically as solid sodium becomes gaseous sodium becomes ionized sodium gas, while diatomic fluorine gas becomes monatomic fluorine gas becomes ionized fluorine gas, and then ionized sodium gas combines with ionized fluorine gas to form a lattice, which becomes sodium fluoride gas (NaF).
aleksbooker
Hello all,
I'm in gen chem 2 and we're going over how to calculate the enthalpy of lattice formation. The way given is to use the Born-Haber process and add the enthalpies of all the steps in between.
e.g. [itex]Na_{(s)} --> Na^+_{(g)} + e^- [/itex] (388kJ)
There are three or four of these, and we combine (add) them to find the enthalpy of reaction. I know how to *do* the problem, subtracting for both sides to determine the value of the missing variable. Here's where I'm confused:
Why is it that everything else is added, and only enthalpy of lattice formation is subtracted?
(enthalpy of sublimation of sodium) + (enthalpy of sodium ionization) + (enthalpy of fluorine atom formation?) + (enthalpy of fluorine ion formation) - (enthalpy of lattice formation) = enthalpy of sodium fluoride reaction
That fourth operation, why is it subtraction and not addition?
Technically NaF already exists before the solid is formed.
@Borek, you mean we subtract NaF because it already exists?
I don't understand what that means. Are we removing it from the sequence?
As far as I understand, it proceeds logically: solid sodium becomes gaseous sodium becomes ionized sodium gas, while diatomic fluorine gas becomes monatomic fluorine gas becomes ionized fluorine gas, and then ionized sodium gas combines with ionized fluorine gas to form a lattice (which requires enthalpy of lattice energy) which becomes sodium fluoride gas (NaF). How does NaF exist before going through this process?
Related to Why do we *subtract* enthelpy of lattice formation?
1. Why is it important to subtract the enthalpy of lattice formation?
Subtracting the enthalpy of lattice formation allows us to determine the enthalpy of a reaction. This is important because it helps us understand the energy changes that occur during a chemical reaction.
2. What is the enthalpy of lattice formation?
The enthalpy of lattice formation is the amount of energy released or absorbed when one mole of a compound is formed from its constituent elements in their standard states.
3. How do we calculate the enthalpy of lattice formation?
The enthalpy of lattice formation can be calculated by taking the difference between the enthalpy of the products and the enthalpy of the reactants in a chemical reaction.
4. Can the enthalpy of lattice formation be negative?
Yes, the enthalpy of lattice formation can be negative if the formation of the compound releases energy. This means that the compound is more stable than its constituent elements in their standard states.
5. How does the enthalpy of lattice formation affect the stability of a compound?
The enthalpy of lattice formation is directly related to the stability of a compound. A more negative enthalpy of lattice formation indicates a more stable compound, as it takes less energy to break apart the compound into its constituent elements.
13K
10K
  • Atomic and Condensed Matter
