Why do we use Bohr's model of the atom in electrostatics?
In summary, the Bohr model of the atom is not used in electrostatic because it fails in regards to electromagnetic radiation and the orbital magnetic moment. It is also inconsistent because an accelerated charge radiates.
Magnetons
Why we use Bohr's model of atom in electrostatic?
Can you explain your question a little bit more and what you have in mind? Can you offer an example where Bohr's model is used in electrostatic?
Likes Magnetons
Because in electrostatics we don't have to worry about electromagnetic radiation, cause that's where Bohr's model fails. The electron (because it does circular orbit hence it has centripetal acceleration) would radiate energy (as all charges that have acceleration do), hence it would start losing energy and fall into the nucleus.
Likes Magnetons and kuruman
Bohr's model also fails in regard to the orbital magnetic moment. However, this is also not relevant in electrostatics.
Likes Delta2
We
I mean we consider k,l,m... Shells where electron is present according to Bohr. Why?
Who is "we"? I don't do that. If I talk about shells than I mean orbitals with the same principal quantum number.
Likes Magnetons
If you are asking why the energy levels are quantized, @Delta2 gave you an answer by considering what would happen if they were not: the electron would spiral into the nucleus which would mean that the hydrogen atom is unstable.
Is this answer to your “why” satisfactory?
Likes Magnetons, DrStupid and Delta2
That’s not Bohr’s model, it’s what we get when we solve Schrödinger’s equation for electrons bound electrons.
Likes Magnetons, Vanadium 50 and Delta2
How do you see that? Yes, it’s what we get when we solve Schrödinger’s equation. But it is also consistent with Bohr’s model. Do I miss something?
Likes Magnetons
Who uses the Bohr model of the atom? I only know it from high school, where it was reluctantly taught by our physics teacher, because she had to, because it was mandatory in the curriculum. Directly after that she taught us the Schrödinger equation...
There is some hope that it gets abandoned from the curricula of our high schools, because the didactics community (at least in Germany) has finally come to the conclusion how bad it is to still teach this model. It only works for the hydrogen atom, because of the large symmetry of that system. It provides a wrong qualitative picture of the hydrogen atom, which is not a little disk but a sphere (in its ground state). It is also intrinsically inconsistent, because an accelerated charge radiates, and a model where you ad hoc state it doesn't radiate, if it is on certain orbits is not a solution of this contradiction.
All this is solved by modern quantum theory, which was discovered independently in three versions by Born, Jordan, and Heisenberg (matrix mechanics) in 1925, by Schrödinger (wave mechanics) 1926, and Dirac (algebraic approach called "transformation theory" at this time) in 1926. It does not only resolve the intrinsic inconsistencies of the old quantum theory (among them wave-particle dualism) but also quantitatively describes all known phenomena correctly.
Likes nsaspook, Magnetons and Delta2
FAQ: Why do we use Bohr's model of the atom in electrostatics?
Why is Bohr's model of the atom important in electrostatics?
Bohr's model of the atom is important in electrostatics because it provides a simplified and visual representation of the structure of an atom. This model helps us understand how charged particles interact with each other and how electric fields are created and influenced by the arrangement of electrons in an atom.
How does Bohr's model of the atom explain electrostatic forces?
Bohr's model of the atom explains electrostatic forces by showing how electrons are arranged in energy levels around the nucleus. These energy levels determine the overall charge of the atom and how it interacts with other charged particles. The model also explains how the distance between the nucleus and the electrons affects the strength of the electrostatic force.
What are the limitations of using Bohr's model in electrostatics?
One limitation of using Bohr's model in electrostatics is that it is a simplified representation of the atom and does not account for the complex behavior of electrons. It also does not take into account the effects of quantum mechanics, which are necessary for a more accurate understanding of electrostatics at the atomic level.
Can Bohr's model be used to calculate electrostatic forces?
No, Bohr's model is not suitable for calculating precise values of electrostatic forces. It is a qualitative model that helps us visualize and understand the underlying principles of electrostatics, but it does not provide numerical calculations or predictions.
Are there any other models of the atom that can be used in electrostatics?
Yes, there are other models of the atom that can be used in electrostatics, such as the quantum mechanical model. This model takes into account the wave-like nature of electrons and provides a more accurate understanding of their behavior in electrostatic interactions. However, Bohr's model is still useful for conceptualizing and explaining electrostatics at a basic level.
