Why do we use BRST in Yang Mills and where does it come from?
  • A
  • Thread starter formodular
In summary, the BRST transformation comes from the Yang Mills Faddeev Popov gauge fixed action as a symmetry of the action after shifting ##A##. The symmetry transformations are very complicated, mixing bosons and fermions (SUSY?).
formodular
34
Hi!
Where does the BRST transformation come from and why?
Peskin brings them into the Yang Mills Faddeev Popov gauge fixed action
as a symmetry of the action after shifting ##A## (treating it as the outcome of a Gaussian integral over some field ##B##)
but the symmetry transformations are very complicated, mixing bosons and fermions (SUSY?):
Why you want it and why it takes this form is mysterious.
This source tells you:
"Since we have more fields than gauge fields ##A##, to maintain the general idea of gauge covariance for physics, it is natural to look for a symmetry that encodes the definition of the gauge symmetry acting on ##A##, but also generalizes it in a consistent way on the new fields. This symmetry must interchange the gauge fields and the ghosts, in order to ensure the compensations between these fields in closed loops for any choice of gauge. Such a symmetry between fields of different statistics is the BRST symmetry."
Can this be expanded/explained more simply with more details (or even just explaining what it means fully), and can we say why we choose the transformations as written above, as it is very interesting!
I recommend the treatment in Srednicki's text, ch.74.
First of all, BRST symmetry is a symmetry of the gauge-fixed action. Whether we want it or not is irrelevant; it's there.
Then, having discovered that it is there, we can use it to derive properties of correlation functions of fields, known as the Slavnov-Taylor identities, which are generalizations of the Ward-Takahashi identities of QED.
Thank you.
Three points on that:
1. Yes Srednicki is good, you can say I am just asking why he does what he does in that chapter.
2. The passage I quoted seems to tell us that we can predict BRST will exist by counting the number of fields. Furthermore we could also predict it by looking at loops. Hopefully somebody can explain this (read: dumb it down) so it becomes obvious :DD
3. If we ignore this and take the perspective that BRST is just there whether we like it or not, the question still becomes - why do we even want it!?
One thought, which someone may understand nicely:
If we think of Gupta-Bleuler quantization of covariant Abelian Maxwell, we imposed the Lorentz gauge condition ##\partial^{\mu} A_{\mu}## on the space of states. Notice this condition is related to gauge invariance symmetry of the action.
Since the Lorentz Gauge condition is a scalar it should satisfy Klein-Gordon, and it does. This apparently means the state space is invariant under time evolution.
If we try to re-create this in the Non-Abelian case we find the scalars do not satisfy Klein-Gordon because of the curvature terms, so the state space defined by the Gupta-Bleuler method is not invariant under time evolution.
On this alone it seems we need to find a new symmetry of the action and then use this to derive some new condition generalizing ##\partial^{\mu} A_{\mu}## and then make it hold on the space of states.
If you then simply analyze the ghost Faddeev-Popov Yang-Mills action, term by term, looking for some symmetry, you can derive the BRST transformations explicitly, as in Srednicki.
The shocking thing, which perhaps illustrates my flawed understanding of Gupta-Bleuler, is that the charge (derived in Srednicki) corresponding to the BRST current, in the Abelian case, reproduces the Fourier space version of Gupta-Bleuler. That is shocking, no?
So we want BRST because we want a symmetry of the action which we can use to create a state space. Why it takes either the GB or BRST form is now a bit confusing, as it seems one is a Fourier expansion of the other in the Abelian case, hinting at something deeper!
I seem to be missing the bigger picture but closer, hope someone sees it :smile:
BRST is a global symmetry of the gauge-fixed action, including the Faddeev-Popov ghosts, and it's crucial to prove the manifest renormalizability as well as the gauge invariance of the S-matrix elements due to the corresponding Slavnov-Taylor identities. See, Weinberg, QT of Fields II for a complete proof (using the method by Zinn-Justin).
The extension of the Gupta-Bleuler formalism working in Abelian gauge symmetries to the non-Abelian case is pretty complicated and makes also heavy use of the BRST symmetry. The method is very well explained in the following papers by Kugo et al:
T. Kugo and I. Ojima, Manifestly Covariant Canonical Formulation of the Yang-Mills Field Theories. I, Progress of Theoretical Physics, 60 (1978), p. 1869–1889.
http://dx.doi.org/10.1143/PTP.60.1869
T. Kugo and O. Ojima, Manifestly Covariant Canonical Formulation of Yang-Mills Field Theories. II: SU (2) Higgs-Kibble Model with Spontaneous Symmetry Breaking, Progress of theoretical physics, 61 (1979), p. 294–314.
http://dx.doi.org/10.1143/PTP.61.294
T. Kugo and I. Ojima, Manifestly Covariant Canonical Formulation of Yang-Mills Field Theories. III—Pure Yang-Mills Theories without Spontaneous Symmetry Breaking, Progress of Theoretical Physics, 61 (1979), p. 644–655.
http://dx.doi.org/10.1143/PTP.61.644
One learns a lot on gauge theories following the operator method, but it's very hard to understand without first looking the more straight-foward path-integral formulation, which is much more natural in understanding, why you have to introduce the Faddeev-Popov ghosts and why BRST symmetry has to mix bosons and fermions (similar to SUSY).
For the proof of renormalizability you get away in a much simpler way by using the socalled background-field gauge. There you work with simple Ward-Takahashi identities rather than the more complicated Slavnov-Taylor identities of BRST symmetry for more general gauges. This is, because in the background-field gauge you get a gauge invariant quantum action, and the proof becomes as simple as for the Abelian case (QED).
Likes A. Neumaier and dextercioby
Related to Why do we use BRST in Yang Mills and where does it come from?
1. Why is BRST used in Yang-Mills theory?
The BRST (Becchi-Rouet-Stora-Tyutin) symmetry is used in Yang-Mills theory because it allows us to maintain gauge invariance while also incorporating the concept of broken symmetry. This is important in Yang-Mills theory because it explains the dynamics of gauge bosons, which are responsible for the strong force between particles.
2. How does BRST maintain gauge invariance?
BRST maintains gauge invariance by introducing a set of ghost fields that cancel out the contributions of unphysical states in the theory. These ghost fields are anti-commuting, meaning they have no physical interpretation, but they allow for the cancellation of unphysical states while preserving the gauge symmetry.
3. Where does the concept of BRST come from?
The BRST symmetry was first introduced in the 1970s by Becchi, Rouet, Stora, and Tyutin as a way to quantize gauge theories, specifically Yang-Mills theory. It was later developed and refined by various physicists, including Kugo and Ojima, who showed that it could also be used in other gauge theories such as gravity.
4. How does BRST relate to broken symmetry?
BRST relates to broken symmetry by providing a way to incorporate the concept into the theory without breaking gauge invariance. In Yang-Mills theory, the gauge symmetry is broken when the Higgs field acquires a non-zero vacuum expectation value. The BRST symmetry allows for the inclusion of this broken symmetry in the theory while maintaining gauge invariance.
5. Are there any limitations to using BRST in Yang-Mills theory?
While BRST is a powerful tool for understanding Yang-Mills theory, it does have some limitations. For example, it only applies to theories with a local gauge symmetry, and it does not provide a complete solution to the problems of confinement and chiral symmetry breaking in quantum chromodynamics (QCD). Additionally, the BRST formalism can be complicated and requires advanced mathematical techniques, making it challenging to apply in certain situations.
  • Beyond the Standard Models
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
