MHB Why do we use CMYK color for printing?
  • Thread starter Thread starter shivajikobardan
    Color Printing
CMYK is preferred for printing materials like brochures and business cards because it effectively represents a wider range of lighter colors compared to RGB. In RGB, light is emitted, meaning colors are created by adding light, while in CMYK, colors are produced by absorbing light, leading to darker results when multiple layers are applied. Using RGB for printing can result in muddy and inaccurate colors due to the differences in color mixing methods. The mathematical relationship between the colors shows that cyan, magenta, and yellow are the inverses of red, green, and blue, with black added to enhance depth. Printing professionals often refer to these colors in terms familiar from primary school, despite their technical differences.
shivajikobardan
I will tell my research that i have done earlier here.
CMYK is used for print pieces like brochurers and business cards.
For RGB we need to start on black paper but we can't add light until we reach white because light can't be painted on surface, what does this bold content means to say?
in a monitor, light is being emitted (or added)when you add r,g,b you get white...in ink light is being absorbed(or subtracted) and when you absorb r,g,b you get black
if rgb is used, you get strange, muddy, and incorrect colors from printer. (but the question is why)
cmy cover most lighter color range quite easily compared to rgb.
I want if possible some mathematical representations of this...thanks
Technology news on Phys.org
Paint absorbs light. When we apply multiple layers of paint, more light is absorbed and the resulting color is darker.
Light is additive. Adding more light of a different color makes it lighter.
The painting colors cyan, magenta, and yellow are the opposite of the monitor colors red, green, and blue.
We might put that in formula form as $cyan = 1 - red, magenta = 1 - green, yellow = 1 - blue$.
Since mixing colors equally generally isn't quite gray, black is added as an additional color. The K in CMYK stands for blacK.
Btw, printing professionals tend to refer to cyan, magenta, and yellow as the colors blue, red, and yellow, which is what we learn in primary school as the primary colors..
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
21K
