I Why do we use low-coherence light in Optical Coherence Tomography?
Low-coherence light is essential in Optical Coherence Tomography (OCT) because it allows for depth resolution and accurate distance measurement. Using coherent light would result in continuous wave (CW) radar-like behavior, which complicates distance determination. Instead, low-coherence light introduces modulation through noise, enabling the identification of reflections from different layers, such as the retina. By comparing the noise envelope of the reflected signals, a peak indicates when the light paths are equal, facilitating depth exploration. This method effectively reconstructs images of internal structures with high resolution.
red65
Hello , I study the principles of optical coherence tomography, where we emit light and by the refraction that we detect we reconstruct and image, but I don't understand why we use low coherence light , if i want to measure the refracted light i would prefer to have coherent light so that the difference in the scattered light will depend only on the form and distance of the object that refracted the light .
can anyone tell me where is the flaw in my reasoning, thanks.
Science news on Phys.org
As far as I can see, it is a radar, looking at the reflections from the various layers of the retina. If we use a pure coherent source, we have in effect a CW radar. This does not allow distance determination; the source must be modulated to obtain distance information. An ordinary radar uses a pulse modulated source to do this. With OCT, by using a non coherent source, the source is modulated by noise. By comparing the noise envelope of the signal reflected from the retina and that from a reference mirror, a peak will be obtained when the two paths are equal. It looks as if the mirror is moved back and forth slightly to explore the reflected signal intensity from various depths.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
