MHB Why do you divide the components by the magnitude when finding a unit vector?
To find a unit vector, each component of the vector is divided by its magnitude to ensure the resulting vector has a length of one. For the vector v = <3,4>, the magnitude is calculated as ||v|| = 5, leading to the unit vector <3/5, 4/5>. This process maintains the direction of the original vector while normalizing its length. The derivation shows that setting the magnitude of the scaled vector equal to one leads to the conclusion that the scalar used for division is the magnitude itself. Understanding this method is essential for accurately determining unit vectors in any given direction.
hatelove
Say for example v = <3,4>
I was taught to divide each component by the magnitude in order to get the unit vector, i.e.
3^2 + 4^2 = ||v||^2
5 = ||v||
So the unit vector of that vector is <3/5,4/5> or 1/5<3,4>
But if I forgot that I had to divide the components by the magnitude, I would not know how to get the unit vector. So I guess I am asking why you divide the components by the magnitude in order to get the unit vector?
Mathematics news on Phys.org
3^2 + 4^2 = ||v||^2
5 = ||v||
The unit vector in the same direction as \( {\bf{v}} \) is a scalar multiple of \({\bf{v}}\), call it \(\lambda {\bf{v}}\), then as it is a unit vector \[\lambda {\bf{v}}.\lambda {\bf{v}}=\lambda^2 {\bf{v}}. {\bf{v}}=\lambda^2 ||v||^2=1\]
etc
CB
3^2 + 4^2 = ||v||^2
5 = ||v||
This is the same thing CB wrote essentially, just added an example to see the steps.
Looking at the vector you provided we can derive the scalar with which we must divide to get a unit vector. If v = <3,4> then |v|=5 as you already posted. Now let's look at the vector [math]v_1=\frac{1}{S}<3,4>[/math]. When you multiply a vector by a scalar the magnitude changes but the direction does not so this is perfect for what we are trying to find.
So [math]|v_1|=\sqrt{ \left( \frac{3}{S} \right)^2+ \left( \frac{4}{S} \right)^2}[/math]. Now set the magnitude equal to one and solve for S.
[math]1^2 = \left( \frac{3}{S} \right)^2+ \left( \frac{4}{S} \right)^2[/math][math]1^2 = \left( \frac{9}{S^2} \right)+ \left( \frac{16}{S^2} \right)=\frac{9+16}{S^2}=\frac{25}{S^2}[/math]
[math]S^2=25[/math] thus [math]S= 5[/math]. Even though -5 is another choice if we divide by -5 we change the direction of the vector so it can't be the unit vector, thus 5 is our only option.
If you go back and change the vector <3,4> for a generalized vector <a,b> the same steps will lead to [math]S^2=a^2+b^2[/math] and when we take the square root of both sides we get that S is the same as the magnitude.
I don't believe I've committed any major errors that aren't allowed with scalars and vectors as the conclusion is correct so I hope this helps show where that formula comes from.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
