Why does a cyclotron only impart linear momentum?
In summary, the conversation discusses the setup and operation of a cyclotron, which uses a static magnetic field and alternating high voltage to accelerate particles. While the alpha particle is moving within the dee, it experiences a force causing it to move circularly and acquire angular momentum. However, it is noted that alpha particles do not have spin, so the angular momentum is not due to spin. The conversation also mentions the cancellation of nuclear magnetic resonance by alpha particles and the impossibility of increasing their spin.
bwana
82
TL;DR Summary
Why is only linear velocity measured on alpha particles accelerated by a cyclotron?
I read the Wiki page
https://en.wikipedia.org/wiki/Electron_cyclotron_resonance
as well as this answer here
How does a cyclotron work?
and it describes a setup where one has a cyclotron which has a static magnetic field pointing up through the dees and there is an alternating high voltage across the dees. An alpha particle is attracted to a negatively charged plate so it moves towards the 'negative dee'. It moves in a circle because of the Lorentz force of the perpendicular magnetic field. When it gets around the semicircle, the voltage is flipped so now the particle jumps across and is accelerated from one dee to the other. I interpret this to mean that acceleration only happens when moving across one dee to the other. However, as the alpha particle is moving withing a dee, it is experiencing a force causing it to move circularly. Technically, the particle is being accelerated here too, but instead of acquiring linear momentum, it is acquiring angular momentum.
However, people smarter than me have said that alpha particles don't spin
Can the rotation of an alpha particle be measured?
Can someone enlighten me as to why alpha particles don't get angular momentum in a cyclotron?
"Centrifugal force". Newton's Law "object in motion ..." in the "dee", the magnetic field acts as centripetal force. When particle is out of dee it goes straight because no other force is on it. Because 2 neutrons and 2 protons the alpha cancels out nuclear magnetic resonance. Nucei rotation?
Even if alpha particles would have a spin: That's a particle property, you can't increase that spin. The direction of that spin can change, although it typically won't align itself with the external field on its own.
It isn't acquiring angular momentum there as it is a radial force. On the other hand: It is acquiring angular momentum from the electric field. But that's a property of the particle motion which has nothing to do with its spin.
Related to Why does a cyclotron only impart linear momentum?
1. Why is a cyclotron used to impart linear momentum?
A cyclotron is used to impart linear momentum because it is a type of particle accelerator that uses a combination of electric and magnetic fields to accelerate charged particles along a circular path. This results in a constant and controlled increase in the particles' speed, thus imparting linear momentum.
2. How does a cyclotron impart linear momentum?
A cyclotron imparts linear momentum by using a combination of electric and magnetic fields to accelerate charged particles along a circular path. As the particles move in a circular motion, they gain speed and momentum, resulting in a linear momentum in the direction of their motion.
3. Can a cyclotron impart angular momentum as well?
No, a cyclotron can only impart linear momentum. This is because the particles are accelerated along a circular path, which results in a linear motion in the direction of their motion. Angular momentum, on the other hand, is a measure of an object's rotational motion.
4. Why is a cyclotron more efficient at imparting linear momentum compared to other particle accelerators?
A cyclotron is more efficient at imparting linear momentum because it uses a constant magnetic field to accelerate the particles, rather than an alternating field like in other particle accelerators. This allows for a continuous acceleration of the particles, resulting in a more efficient transfer of momentum.
5. Are there any limitations to the amount of linear momentum that a cyclotron can impart?
Yes, there are limitations to the amount of linear momentum that a cyclotron can impart. This is due to the limitations of the magnetic field strength and the size of the particle accelerator. As the particles reach higher speeds, the magnetic field may not be strong enough to keep them on a circular path, limiting the amount of linear momentum that can be imparted.
9K
  • Classical Physics
