Why does a cylinder of cooking gas feel heavier?
In summary, weight carrying illusions often involve extra supports that are hidden in clothing or as part of the object being lifted. This is similar to the example of a man lying down while an elephant climbs a plank placed on him without causing harm. It is important to note that the weight of the cylinder is not just the net weight of the gas, as there is also the weight of the cylinder itself to consider. This illusion may be related to the example given, as the pressure may be lower due to the larger surface area of the object being lifted, making it feel lighter.
avito009
184
We feel a gas cylinder of cooking gas to be heavier if we lift it. But when a kid of 14 kg is lifted it feels a lot easier to lift him than lifting a cylinder of cooking gas weighing 14 kg. Is it because the pressure is low because of larger surface area of the kid?
Is it related to this example? Example: In a circus a man lies down and a wooden plank is kept on him then an elephant climbs this plank and the performer is unhurt.
IS the 14kg the Net weight of just the gas? There would be the addition weight of the cylinder to lift.
I suspect that many of the 'weight carrying' illusions involve extra supports, hidden in clothing or as part of the plank.. The plank is probably supported on either side of his body.
Related to Why does a cylinder of cooking gas feel heavier?
1. Why does a cylinder of cooking gas feel heavier than an empty one?
The weight of a cylinder of cooking gas is due to the gas itself, which is compressed into a liquid form inside the cylinder. This liquid form takes up less space, allowing more gas to be stored in the cylinder and making it feel heavier than an empty one.
2. What is the composition of cooking gas?
Cooking gas, also known as liquefied petroleum gas (LPG), is a mixture of propane and butane gases. These gases are byproducts of natural gas processing and crude oil refining. Propane makes up about 60% of LPG, while butane makes up the remaining 40%.
3. How does cooking gas turn into a liquid inside the cylinder?
Cooking gas is stored at high pressure inside the cylinder, causing it to compress into a liquid form. When the gas is released from the cylinder, the pressure decreases and it returns to its gaseous state. This is why you can see bubbles when using a gas stove or grill.
4. Is cooking gas flammable?
Yes, cooking gas is highly flammable. It is important to handle and store cooking gas properly to prevent accidents. It should be kept away from heat sources and stored in a well-ventilated area.
5. How long does a cylinder of cooking gas last?
The lifespan of a cylinder of cooking gas depends on how often it is used and the size of the cylinder. On average, a standard 20-pound cylinder can last for about 25-30 hours of cooking time. However, it is recommended to have a spare cylinder on hand to avoid running out of gas in the middle of cooking.
  • Other Physics Topics
  • Mechanical Engineering
  • General Engineering
