- #36
leafy
- 73
- 8
Net current = 0
What is the “net current”?leafy said:Net current = 0
Well that's a bit of egg on my face then. That's what I get for not brushing up on my EE101. My apologies.leafy said:Hm... you might have read the diode wrong.
The portion of rotation that charges the batteries will put a mechanical load on the motor, slowing it down. The battery will need to supply current after this to speed it back up. You have created a (bad) motor generator, which is not new as has been discussed.leafy said:Unload motor require current to overcome friction. Loaded motor require current for the load. We assumed ideal, no friction, so the only requirement is current for the load.
Thread is closed temporarily for Moderation...leafy said:But there is current through it. Each time the switch close, current flow to speed up the wheel. Each time current flow to the 24V, curren flow slow down the wheel. Each cycle, there is a speed up and slow down. The net is zero current with is steady state.
I believe that by “net is zero current” you mean that the current speeding up the motor with the 12 V supply is the same as the current slowing down the motor with the 24 V recharging. That is simply false, there is nothing that would require it from a circuits standpoint and, as you noticed, the conservation of energy forbids it.leafy said:Each time the switch close, current flow to speed up the wheel. Each time current flow to the 24V, curren flow slow down the wheel. Each cycle, there is a speed up and slow down. The net is zero current with is steady state.
