B Why does a magnet attract metal objects?
Magnetism involves magnetic fields that influence charged particles, but the attraction of metals like iron occurs due to unpaired electrons in ferromagnetic materials. These unpaired electrons align with magnetic fields, allowing metals to respond to magnets effectively. While designing a magnet-based musical instrument, it's important to note that not all metals are magnetic, with iron-based alloys being the most responsive. However, using magnets in a guitar pickup requires amplification, as the energy generated is minimal and can dampen the string's vibration, affecting sound quality. Understanding these principles is crucial for successful instrument design.
withoutname
Hi, there! I am studying magnetism right now and I can’t understand how does a magnet work. I read that the magnet has a magnet field, which influences only charged particles with velocity. But then how does magnet attracts metal objects, e.g iron nail? I read that in metals there are free electrons, which are moving outside of the atom shells. But the average velocity component of these electrons in any direction is zero, so then the magnetic force is also zero…
At all I want to design my own musical instrument, which uses only magnets and no electricity. So I tried to determine how a magnet would act on a metal guitar string eg. and what forces are acting in this configuration.
Welcome, @withoutname !
Not all metal are attracted by a magnet.
Alloys based on iron, like the materials used in common magnets, respond the best.
Copied from:
https://en.wikipedia.org/wiki/Magnetism
"A ferromagnet, like a paramagnetic substance, has unpaired electrons. However, in addition to the electrons' intrinsic magnetic moment's tendency to be parallel to an applied field, there is also in these materials a tendency for these magnetic moments to orient parallel to each other to maintain a lowered-energy state"
This is what a guitar pickup does.
https://en.wikipedia.org/wiki/Pickup_(music_technology)#Magnetic_pickups
Unfortunately for your project this requires amplification since this results in very little energy. Extracting more energy will at some point before you get a useful amount of energy out of it start to dampen the string too fast or otherwise effect the sound.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
