Why Does a Photon Not Have a Spin Component Sz=0?
  • Thread starter ndung200790
  • Tags
    Photon
In summary, the conversation discusses the problem of a photon having spin=1 and three values of Sz, but only having left and right handed polarizations. The issue is explained in two ways: the replacement of spin by helicity for massless particles, and the elimination of two polarizations through gauge fixing in quantum electrodynamics.
ndung200790
519
Please teach me this problem:
Photon has spin=1,so there are three values of Sz=-1,0,1.But I know that a real photon has only left and right handed polarizations.There is not longitudinal polarization.Because of that there not exist states with Sz=0.I don't understand this problem.
Please give me a favor to explain this for me.
Thank you for advanced.
There are two ways to discuss this problem.
1) For massless particles one should replace spin by helicity; the symmetry is then an E2 rotation in the spatial (transversal) 2-plane which results in two helizities +1 and -1 (this is what you call usually spin +1 and spin -1).
For a good reference see Ryder's book on quantum field theory
2) For massless photons (quantum) electrodynamics has an U(1) gauge symmetry. Usually one eliminates one A-component via gauge fixing but essentially one can show that one eliminates two! This is best understood in the A°=0 gauge. This gauge is nice b/c a) A° is an unphysical field b/c there is no time derivative and therefore no canonical conjugate momentum (the diagonal terms in the F-tensor are zero). So let's set A°=0. A° acts as a lagrangian mutiplier; the equation of cosntraint is the Gauss law which has to be solved for. This is equivalent to eliminate the longitudinal photon. The Gauss law reflects the fact that after gauge fixing A°=0 there is still a gauge symmetry left, namely the gauge symmetry with time-independent gauge functions which do not spoil A° = A'° = 0. So after A°=0 and solving the Gauss law two polarizations have been eliminated.
FAQ: Why Does a Photon Not Have a Spin Component Sz=0?
What is Sz=0 in relation to photons?
Sz=0 refers to the spin quantum number of a photon. It indicates that the photon has zero angular momentum along its axis of travel.
Is Sz=0 the only possible spin state for a photon?
No, photons can have a spin quantum number of +1 or -1 in addition to Sz=0. These different spin states have different properties and can be manipulated for various purposes in research and technology.
How is the spin state of a photon determined?
The spin state of a photon is determined by the direction of its electric and magnetic fields, which are perpendicular to each other and the direction of travel. This can be measured using specialized equipment such as a polarimeter.
Can the spin state of a photon be changed?
Yes, the spin state of a photon can be changed through interactions with other particles or through the use of specialized equipment such as polarizers. This is an important aspect of quantum mechanics and has practical applications in fields such as quantum computing.
What is the significance of Sz=0 in quantum mechanics?
The concept of Sz=0 in quantum mechanics is significant because it helps to explain the behavior of particles at the subatomic level. It is also important in understanding the properties and behavior of light, which is made up of photons with different spin states.
