- #36
trambolin
- 341
Do you occasionaly revive this topic?
zgozvrm said:You can never stop this division: You cannot say that 1 million "3's" will exactly equal 1/3, nor can you say that 1 million and 1 "3's" equals 1/3, etc.
CRGreathouse said:Do you think Gib Z was suggesting you could?
Ahahahahah! Sorry, this was hilarous.HallsofIvy and trambolin said:Since nobody took the burden to give the famous example for these debates,
LaTeX Code: <BR>3\\frac{1}{3} = 3(0.333333\\ldots) \\Longrightarrow 1 = 0.999999\\ldots<BR>
Just to stir up the soup.
OMG, please don't!
Hurkyl said:Divided parts? Who said anything about divided parts?
Algr said:zgozvrm,
What is odd is you start out saying one thing, and then give an example that proves exactly the opposite. There is no place in math where an unfinished equation can prove anything. It seems to me that if a math problem can't be completed, then it has no answer. You can't simply assume that because the running total seems to be approaching 1/3 that that it must arrive at it.
statdad said:"I simply proved that it was by showing the inverse" - no, you didn't. Your work indicates that the result is true, but it doesn't qualify as a proof.
No, statdad was saying that your informal demonstration does not qualify as proof.zgozvrm said:So you're saying that showing that x/y = z doesn't prove that z = x/y!
zgozvrm said:2) I never said the equation was "unfinished," only that you can never finish the long division, as it continues forever.
Once you stop appending 3's, you will have come to some finite number of 3's (and therefore, an EXACT decimal number) and this value will NOT exactly equal 1/3. The value ONLY equals 1/3 exactly, if the series of 3's continues forever.
By the way, the same holds true for 1/9 = 0.11111..., 2/9 = 0.222222..., or for that matter 2369/9999 = 0.2369236923692369...
D H said:No, statdad was saying that your informal demonstration does not qualify as proof.
alxm said:So what if the division 'continues forever'? That doesn't mean you can't know the result. It doesn't mean the answer isn't a 'real' number. (I can't ever write all the decimals in Pi. So?). The statement doesn't have any relevance or significance, but is exactly what confuses people.
alxm said:No, infinitely, not 'forever'.
alxm said:It's not about what you can practically add up in an amount of time. It's an infinite series, and 'infinite' means infinite in math. Not 'a really big number'. And an summation mark means a sum, not a command to 'add up these numbers'.
alxm said:(It) doesn't mean that its value isn't finite, or exactly calculable.
Just for the sake of accuracy, your LaTeX script was almost correct. Here is what I'm sure you meant.alxm said:By the way, any number, whether it has recurring decimals or not, can be written as an infinite series in an infinite number of ways, e.g. [tex]1 = \sum^\infty_{n=1}\frac{1}{2n}[/tex]
The value of that sum is exactly 1. The fact that a human being manually summing up the numbers would never 'reach' 1 doesn't enter into it. You're not making anything clearer by saying that, you're bringing up exactly what gets people mixed up.
If you mean finite, then say finite. Words like "exact" and "definite" suggest a meaning that is flat out wrong here.I merely stated that you couldn't come up with an exact (finite, if you will) decimal representation of 1/3
arildno said:Furthermore, zgozvrm:
You cannot utilize the fact that division SEEMS to yield 0.3333... as an "answer" to ague for that 0.3333... IS a "number".
You might simply be misapplying the process called "division" on an illegitimate object, invoking thereby the well-known GIGO principle.
Indeed you did!zgozvrm said:You guys are killing me!
I never stated that the division SEEMS to yield 0.3333... Rather, I stated that the division DOES yield 0.33333...
which is clearly evident by doing the long division.
And, since when is dividing 1 by 3 "illegitimate"?
arildno said:Indeed you did!
And how do you know that is something meaningful??
How do you know it is legitimate, and indeed, applicable to the particular case 1/3?
Indeed I am.zgozvrm said:Are you for real?
Not obvious at all.1) "1/3" is a fraction that can be represented by dividing 3 into 1.
zgozvrm said:This discussion is beyond converting fractions to decimals and vice-versa, so if that is beyond your level of math, then so is this discussion.
zgozvrm said:You guys are all over-thinking this. Algr didn't seem to believe something was true, I showed him a way to see that it WAS in fact true, therefore, I proved it to him.[/b]
Indeed, Algr!I think you are UNDER-thinking things, Zgozvrm. You can't assume that a proof is correct simply because it gives you the answer you want. That is circular logic
Algr said:Edit:
In your latest proof, I don't have a problem with step 1, but in step 2, there is no final result of the division. The "..." simply represents a failure to complete a process that can never be completed.
No, we don't.zgozvrm said:Wow! Apparently you guys don't believe the basic laws of math nor that division is a valid "algorithm" with non-zero numbers.
