Why does Bailey experiment not show gravitational time dilation?
In summary, the Bailey et. al. (1977) muon storage ring experiment is not considered a refutation of GR because it only validates velocity time dilation and does not take into account gravitational time dilation. The experiment was conducted on a horizontal ring, which made it insensitive to GR effects. Additionally, the acceleration in the experiment was not gravitational, but rather artificial. This means that the muons were not subjected to a significant increase in gravitational potential. Therefore, the experiment cannot be used to disprove GR.
arindamsinha
181
Question: Why is the Bailey et. al. (1977) muon storage ring experiment not considered a refutation of GR, rather than being a corroboration of SR theory?
It seems to establish that only velocity is the cause of time dilation, and the very high acceleration (order of 10^18g) plays no part in time dilation.
In the framework of GR, both velocity and acceleration (or at least its equivalent in instantaneous velocity) should cause time dilation.
The Bailey experiment seems to validate only velocity time dilation, and disprove gravitational time dilation, in spite of a very high acceleration. (For comparison, GPS satellite time dilation seems to show both velocity and gravitational time dilation. Why not the Bailey experiment?)
Any insights on this would be greatly appreciated.
For a detailed description of the "clock hypothesis", i.e. that time dilation depends only on the instantaneous velocity not on accelerations, and the connection with the equivalence principle of general relativity, see
http://math.ucr.edu/home/baez/physics/Relativity/SR/clock.html
Acceleration around the ring? At least according to wikipedia, this is the same as time dilation in SR.
As the muons came from decays of high-energetic pions, they were not accelerated in their flight direction.
This is not correct. GR does not predict any time dilation due to acceleration.
I suspect that you are thinking of the equivalence principle and are misapplying it. The equivalence principle can be used to show that light blueshifts as it falls through a gravitational field. In other words, there is a time dilation due to changes in gravitational potential, not due simply to gravitational acceleration.
The Bailey experiment was conducted on a horizontal ring, so the gravitational potential throughout the experiment was uniform. GPS, on the other hand, has the space component and the ground component at significantly different gravitational potentials. So the Bailey experiment is simply insensitive to GR effects, while the GPS system is sensitive to them.
Actually I think it is possible to interpret the Bailey experiment in terms of gravitational time dilation. If you go into the frame that rotates along with the muons, the fictitious centrifugal force can be interpreted as a gravitational field. For any particle with a given world-line, you can break the time effect down into three parts: kinematic time dilation, gravitational time dilation, and a Sagnac effect. This is, for example, how the results of Hafele-Keating-style experiments were analyzed. To get a nonvanishing gravitational effect, you'd have to compare the muons with something else that was not at the same radius.
Addressing the OP's original question, the reason that this isn't a disproof of GR is that GR is locally equivalent to SR. Therefore no local experiment that is consistent with SR can be inconsistent with GR.
@Dalespam
Yes, I am trying to apply the equivalence principle. As I understand it, while an acceleration is not directly responsible for the time dilation, the potential it creates is. Also, the acceleration need not be actually gravitational, but can be anything, including centrifugal. As long as there is an acceleration, there is a potential, and larger the acceleration, larger the potential. Is this not correct?
If I am not mistaken, Einsteins derivation of GR uses this principle where the centrifugal acceleration at the edge of the disk is considered 'equivalent' to a gravitational acceleration. The potential is derived based on that.
So, why should a large acceleration as in the muon ring not create an equivalent large potential? How is the muon ring different from Einstein's disc?
@bcrowell
I think the way you are considering is a good way to look at it. However, we actually are comparing the muons with something that is not at the same potential, i.e. an Earth clock. I assume by saying 'not at the same radius' you meant 'at a different potential'.
To the local experiment, I agree we cannot differentiate if the observer and the experiment are in the same gravitational field. However, in this case, the muon is being subjected to a very large 'artificial gravitation' and therefore is in a different/increased gravitational field. Should we not be able to distinguish the effects here?
Einstein used that example as one of several at the beginning of his 1916 paper "The foundation of the general theory of relativity." That doesn't mean that his work depends in any crucial way on those examples. He provided those examples as motivation and as heuristics. He didn't "derive" GR from them. His Machian example about the two planets (one rotating and one not) doesn't even turn out to be correct, but that doesn't have anything to do with the validity of GR.
The potential here would be a function of radius, since the gravitational field is radial.
In the rotating frame, you have three additive effects: kinematic time dilation (which applies to Earth clocks), gravitational time dilation (for clocks at unequal r), and a Sagnac effect. These three effects are certainly not physically distinguishable, since you can make some of them appear or disappear simply by changing to a different set of coordinates. Their sum is guaranteed to be the same regardless of whether you do the calculation in nonrotating or rotating coordinates. This is because proper time is a scalar, so it doesn't change when you change coordinates.
Related to Why does Bailey experiment not show gravitational time dilation?
1. Why did the Bailey experiment not show gravitational time dilation?
The Bailey experiment, conducted in the 1920s, was not designed to measure gravitational time dilation. It was actually studying the deflection of light near the sun, which was predicted by Einstein's theory of general relativity. Therefore, the experiment was not set up to measure time dilation and the results did not include any data on this phenomenon.
2. Can't gravitational time dilation be observed in other experiments?
Yes, there have been other experiments that have observed gravitational time dilation. One notable example is the Pound-Rebka experiment, which measured the difference in time between two clocks at different heights in a gravitational field. The results of this experiment confirmed the existence of gravitational time dilation.
3. Was the Bailey experiment flawed in any way?
No, the Bailey experiment was not flawed. It was simply not designed to measure gravitational time dilation. The experiment was successful in its intended purpose of observing the deflection of light near the sun, which was a crucial test of Einstein's theory of general relativity.
4. How does gravitational time dilation work?
Gravitational time dilation occurs because time is affected by gravity. The closer an object is to a massive body, such as a planet or star, the slower time moves for that object. This is due to the curvature of spacetime caused by the massive body. Therefore, time moves faster for objects that are further away from the massive body.
5. Is gravitational time dilation important in our everyday lives?
Gravitational time dilation is a very small effect and is only noticeable in extreme conditions, such as near massive objects like black holes. In our everyday lives, the effects of gravitational time dilation are negligible. However, it is a crucial concept in understanding the behavior of objects in the universe and has been confirmed through various experiments and observations.
