Why does cold water hurt my teeth but warm water doesn't?
In summary, the author suggests that dentinal pain is due to hydrodynamic mechanism, i.e., fluid force. Based on this theory, when cold water contacts sensitive dentin, the centrifugal fluid movement activates the nerves, causing pain.
iDimension
108
Whenever I brush my teeth and I squish the water around in my mouth, I get an intense sharp pain in some of my top back teeth. I've been to the dentist several times and they say there's nothing wrong with my teeth. However whenever I drink warm water or squish warm water around in my mouth it doesn't hurt.
So why does cold water hurt and warm water doesn't?
Biology news on Phys.org
I am definitely no biophysicist, but here is my guess for what's going on:
The inside of your mouth is already pretty warm, around 98.6##^{\circ}## Fahrenheit. The change in temperature for your teeth is probably much greater when you use cold water than when you use warm water. Also, when in contact with cold water, your teeth thermally contract - maybe they squeeze some nerves. On the other hand, when your teeth are heated, they expand. Perhaps they are not squeezing anything in this case, then.
In healthy teeth, a layer of enamel protects the crowns of your teeth—the part above the gum line. Under the gum line a layer called cementum protects the tooth root. Underneath both the enamel and the cementum is dentin.
Dentin is less dense than enamel and cementum and contains microscopic tubules (small hollow tubes or canals). When dentin loses its protective covering of enamel or cementum these tubules allow heat and cold or acidic or sticky foods to reach the nerves and cells inside the tooth. Dentin may also be exposed when gums recede. The result can be hypersensitivity.
http://www.mouthhealthy.org/en/az-topics/s/sensitive-teeth
There are a number of treatments for sensitive teeth, some are available over the counter such as in toothpaste for sensitive teeth. If the sensitivity continues, I would go back to a dentist and insist that you really have sensitivity and to treat you for it, they have treatments that are better than what you can buy yourself.
But why is it only cold water that hurts my teeth and not warm water? What is so special about cold water?
Perhaps this will help explain, apparently they are not 100% certain, but this hypothesis seems to be a reaonable explanation.
[Brannstrom (1964) has proposed that dentinal pain is due to hydrodynamic mechanism, i.e., fluid force.[22] Scanning electron microscopic (SEM) analysis of “hypersensitive” dentin shows the presence of widely open dentinal tubules.[6] The presence of wide tubules in hypersensitive dentin is consistent with the hydrodynamic theory. This theory is based on the presence and movement of fluid inside the dentinal tubules. This centrifugal fluid movement, in turn, activates the nerve endings at the end of dentinal tubules or at the pulp–dentine complex.[21] This is similar to the activation of nerve fibers surrounding the hair by touching or applying pressure to the hair. The response of pulpal nerves, mainly Aδ intradentinal afferent fibers, depends upon the pressure applied, i.e., intensity of stimuli.[21] It has been noted that stimuli which tend to move the fluid away from the pulp–dentine complex produce more pain. These stimuli include cooling, drying, evaporation and application of hypertonic chemical substances.[23] Approximately, 75% of patients with DH complain of pain with application of cold stimuli.[23] In spite of the fact that fluid movement inside the dentinal tubules produces pain, it should be noted that not all exposed dentine is sensitive. As stated before, the “hypersensitive” dentin has more widely open tubules and thin/under calcified smear layer as compared with “non-sensitive” dentine. The wider tubules increase the fluid movement and thus the pain response.[6,7][/quote]
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3010026/
Likes berkeman and iDimension
I have cold-sensitivity on several of my teeth, predominantly on one or two where I've had a filling put into fill a cavity. I use a toothpaste that (used to) help reduce the sensitivity of my teeth, but its effects appear to have waned as of the past few months. I guess I'll just have to eat less ice cream. :cry:
Same here. I used a sensitive reducing toothpaste for several years. In my case I've had an extensive set of amalgam fillings as this was common practice in New Zealand last century. I've been told that some UK dentists refer to this as the Australasian Trench. In my case increasing sensitivity was a symptom of cracks forming. I've been told this is partly due to repeated thermal expansion and contraction of the huge amalgams.
As I entered my fifties, the toothpaste became less effective and pressure sensitivity started to become an issue. My dentist suggested taking preventative action by replacing the most at risk fillings with crowns over an extended period (one every 6 months). As a result I no longer suffer any sensitivity, and have thus far avoided the need for any root-canals or implants.
When younger, I saw the excellent movie 84 Charing Cross Road, I had not realized that dental expenses featured there were so common in later life.
Likes Drakkith
My dentist told me that if a tooth hurts with warm water, it may be an abscess caused by the death of the nerve. The warmth causes expansion inside the chamber which puts pressure on the nerve. Cold water will bring relief. But if cold or sweet causes pain, it tends to be a cavity.
Related to Why does cold water hurt my teeth but warm water doesn't?
What causes the pain in my teeth when I drink cold water?
The pain you experience when drinking cold water is due to the contraction of your teeth's dentin tubules. These tiny tubes are filled with fluid and when exposed to cold temperatures, they shrink and pull on the nerve endings in your teeth, causing pain.
Why does warm water not cause the same pain in my teeth?
Warm water does not cause the same pain in your teeth because it does not cause the dentin tubules to contract. The temperature of warm water is closer to your body's temperature, so it does not trigger the same reaction in your teeth.
Is this pain a sign of a dental problem?
In most cases, the pain caused by drinking cold water is not a sign of a dental problem. However, if the pain is severe and persists even after drinking warm water, it could be a sign of tooth decay or a cracked tooth. It is important to consult a dentist if the pain is severe or recurring.
Can I prevent this pain from happening?
Yes, there are ways to prevent or minimize the pain you experience when drinking cold water. One way is to avoid drinking extremely cold water and instead opt for cool or room temperature water. You can also try using a straw to bypass your teeth or swishing warm water in your mouth after drinking cold water to help ease the pain.
Is there a way to treat the pain if it occurs?
If you experience pain while drinking cold water, you can try pressing your tongue against the roof of your mouth. This can help reduce the sensitivity of your teeth. You can also try using toothpaste specifically designed for sensitive teeth or using a desensitizing mouthwash. If the pain persists, it is best to consult a dentist for further treatment.
  • Biology and Medical
  • Thermodynamics
  • Earth Sciences
